Posted · Help! Skin support layers inside walls
Cura is forcing skin edge support layers inside the small gap between walls. By means of example, if wall_thickness = .9 and line_width = 0.4, Cura is creating TYPE:SKIN G1 moves  within the gap. How to fix?
Following attempt to override in machine def.json failed...
"overrides":
    "skin_edge_support_layers":
        "enabled": false
