Eel Conductive Filament Under Extrusion Problem on UMS5
Posted
· Eel Conductive Filament Under Extrusion Problem on UMS5
Had the same problem with Proto Pasta on Um3 and fixed it.
The problem is, that the UM print cores have a 3 times thinner heat block then E3D Hotends. You either need to print MUCH slower, or print even hotter. Try printing with 10mm/s. If that fixes it, you know what to tweak.
Filled Filaments appear to need longer to heat up. So you cant feed the hotend as much as with standard materials
KronosMagna 0
