8 hours ago, akkoxe said:Where can I find all the variables of Cura settings?
A bit more readable version of the info derived directly from fdmprinter.def.json can be found here:
http://files.fieldofview.com/cura/Replacement_Patterns.html
8 hours ago, akkoxe said:For example I need "M900 K{layer_z * 0.02}" in G code, but it's "layer_z" variable from prusha. I need the same, but for Cura.
Unfortunately, you cannot do math in replacement patterns in Cura.
But like @Cuq said, there's a neat plugin to help you with Linear Advance settings.
curasurf 5
have a look at this file:
C:\Program Files\Ultimaker Cura 4.8.0\resources\definitions\fdmprinter.def
Cuq 205
For linear advance settings use the Linear Advance plugin
