Heater cartridge (olsson) is loose and cannot be well connected to the heater block
efifogel
Posted · Heater cartridge (olsson) is loose and cannot be well connected to the heater block
Hi All,
I have an Ultimaker 2 with an Olsson head (upgraded about a year ago).
The heater block stopped heating, so I've order a new one from AliExpress and got it.
As much as I fasten the screw in the heater block, the heater cartridge remains loose.
I assume that I got a bad replacement.
1. is there anything I can do to make the connection tight after all?
2. Where is a good place to buy a heater block?
Thanks,
Efi
