Posted · problem in the extruder motor control and temperature
I have some question.
-Is normal that, in the replicator g control panel, al the axes can be conrolled with precision except for the extruder motor?
If i give him some order, there is a big delay waiting for the answer, and most of the time it just don't respond.
I use replicator g 025 with the arduino mega shield 1.5.x and the Built 1 Standard Relase firmware.
-When we generate gcode to print a normal cube, if i use my computer the extruder stepper don't work, if is done by a friend of mine, it does.
What are the important option to check?
-The ultimaker can't mantain the temperature during the print, and we have to say 260° to have 230°.
Thank you all.
    1) Yes. The extrude button from RepG is kind of a hack job.
    2) Most likely cause is the "dimension" plugin is off in Skeinforge.
    3) That's odd. But upgrading to Marlin might help in this case.
    Or, upgrade to SkeinPyPy:
    https://github.com/daid/SkeinPyPy/wiki
    Which will upgrade you to Marlin v1, is known to work with all default settings. And has a better printing interface (PrintRun) where the extrude buttons work instantly.
