405: Method not allowed when trying to send a print job over the API
From the information you provided I don't see any particular reason why this should not work. If your authentication is okay there are a few other reasons you could get a not allowed:
Your request is not properly formatted.
The printer is not ready to accept printjobs. For example, this can happen when you are currently printing. Or if the printer is in any other status than 'idle'. After the a printjob the printer will only go back to idle after you've pressed confirm removal.
You can check the status of the printer using the api /printer/status. I hope this helps for you. If not please let me know.
Jos
Josnoww 15
Hi @xsimplex,
Jos
