Cura removing bottom layer
Ch3vr0n
Posted · Cura removing bottom layer
Project file attached. In the prepare stage there's a bottom layer on the holding the pegs in position (to prevent individual ones from coming loose from the bed). In the preview section that bottom layer gets removed for some reason and only the pegs get printed. I already tried mesh tools > fix modal normals but that doesn't change anything.
xxx_-_connector_d10x10.3mf
