I've encountered same problem. Just download 64 bit version and it will work fine.
Hello - I have done exactly as you, and the same results too, except I'm on 64-bit Ubuntu 14.04. It seems like the last reply here solved it. 2 quick questions: Download the 64-bit version of what? And where is it found? Thank you!!!
Daid 306
The only change I did in the "control" file was setting an architecture for the binaries, this used to be "all" which was incorrect as the package is build for 32bit x86 CPU (and Ubuntu was complaining about this)
Are you running an 32 or 64 bit Mint?
