Hey!
I use because I could not get my retraction to work in cura (4.10) which I used since a year ago of course younger versions then, but since I can now use Matter Control 2.0 where it is possible to adjust retraction and travel speed in cura hands nothing at travel speed and retraction you do not see any major difference. that I have 3 extruders in the same nozzle,
in Cura I have made the right profile for my printer can be printed fine but there will be lots of stringing and ozing ... How can I avoid stringing and ozzing in cura .. my printer is a Geeetech A30T
I have followed many videos on the subject of Retraction but nothing helps in Cura, Matter Control 2.0 where it is possible to get rid of ozzing and stringing easily ...
something is wrong with my cura 4.10...
Please Krister
    • 2 weeks later...
    I just saw this post.  Sorry.
    Did you get this straightened out?  If you adjust the Settings Visibility to "All" you should see the all the retraction adjustments in the Travel settings.
    Additionally, if you have the Printer Settings loaded from the Marketplace make sure "firmware retraction" is turned off.
