Windows 10 Cura 4.10 Crashes on startup.
Telli
Posted (edited) · Windows 10 Cura 4.10 Crashes on startup.
As the title says Cura crashes on startup..n ever had this issue before. Im on Windows 10 and Cura 4.10 this a fresh install all other have been removed including there APPDATA
2021-08-12 14:27:40,770 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin FileLogger
2021-08-12 14:27:40,770 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2021-08-12 14:27:40,773 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
2021-08-12 14:27:40,773 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.10.0
2021-08-12 14:27:40,775 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
2021-08-12 14:27:40,776 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
2021-08-12 14:27:40,778 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2021-08-12 14:27:40,779 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
2021-08-12 14:27:40,781 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
2021-08-12 14:27:40,782 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
2021-08-12 14:27:40,783 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
2021-08-12 14:27:40,785 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2021-08-12 14:27:40,787 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
2021-08-12 14:27:40,789 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
2021-08-12 14:27:40,790 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
2021-08-12 14:27:40,792 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
2021-08-12 14:27:40,794 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
2021-08-12 14:27:40,795 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
2021-08-12 14:27:40,797 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
2021-08-12 14:27:40,801 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin FirmwareUpdateChecker
2021-08-12 14:27:40,808 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin FirmwareUpdater
2021-08-12 14:27:40,814 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin GCodeGzReader
2021-08-12 14:27:40,821 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin GCodeGzWriter
2021-08-12 14:27:40,827 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin GCodeProfileReader
2021-08-12 14:27:40,836 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin GCodeReader
2021-08-12 14:27:40,842 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin GCodeWriter
2021-08-12 14:27:40,849 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin ImageReader
2021-08-12 14:27:40,855 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin LegacyProfileReader
2021-08-12 14:27:40,862 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin LocalContainerProvider
2021-08-12 14:27:40,873 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin LocalFileOutputDevice
2021-08-12 14:27:40,879 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin MachineSettingsAction
2021-08-12 14:27:40,886 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin ModelChecker
2021-08-12 14:27:40,894 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin MonitorStage
2021-08-12 14:27:40,901 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin PerObjectSettingsTool
2021-08-12 14:27:40,907 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin PostProcessingPlugin
2021-08-12 14:27:40,913 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin PrepareStage
2021-08-12 14:27:40,919 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin PreviewStage
2021-08-12 14:27:40,926 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin RemovableDriveOutputDevice
2021-08-12 14:27:40,931 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SentryLogger
2021-08-12 14:27:40,941 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SimulationView
2021-08-12 14:27:40,948 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SliceInfoPlugin
2021-08-12 14:27:40,955 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SolidView
2021-08-12 14:27:40,961 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SupportEraser
2021-08-12 14:27:40,975 - WARNING - [MainThread] UM.Logger.logException [112]: Exception: Failed to load packages for Marketplace
2021-08-12 14:27:40,977 - WARNING - [MainThread] UM.Logger.logException [116]: NoneType: None
2021-08-12 14:27:40,978 - WARNING - [MainThread] UM.Logger.logException [112]: Exception: Failed to load packages for Marketplace
2021-08-12 14:27:40,979 - WARNING - [MainThread] UM.Logger.logException [116]: NoneType: None
2021-08-12 14:27:40,981 - WARNING - [MainThread] UM.Logger.logException [112]: Exception: Failed to load packages for Marketplace
2021-08-12 14:27:40,982 - WARNING - [MainThread] UM.Logger.logException [116]: NoneType: None
2021-08-12 14:27:40,983 - WARNING - [MainThread] UM.Logger.logException [112]: Exception: Failed to load packages for Marketplace
2021-08-12 14:27:40,985 - WARNING - [MainThread] UM.Logger.logException [116]: NoneType: None
2021-08-12 14:27:40,989 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin Toolbox
2021-08-12 14:27:40,994 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin CameraTool
2021-08-12 14:27:41,001 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin MirrorTool
2021-08-12 14:27:41,010 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin RotateTool
2021-08-12 14:27:41,018 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin ScaleTool
2021-08-12 14:27:41,023 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SelectionTool
2021-08-12 14:27:41,030 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin TranslateTool
2021-08-12 14:27:41,036 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin TrimeshReader
2021-08-12 14:27:41,048 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin UFPReader
2021-08-12 14:27:41,054 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin UFPWriter
2021-08-12 14:27:41,061 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin UltimakerMachineActions
2021-08-12 14:27:41,111 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin UM3NetworkPrinting
2021-08-12 14:27:41,120 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin UpdateChecker
2021-08-12 14:27:41,121 - INFO - [JobQueueWorker [0]] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
2021-08-12 14:27:41,140 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin USBPrinting
2021-08-12 14:27:41,150 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade21to22
2021-08-12 14:27:41,157 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade22to24
2021-08-12 14:27:41,165 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade25to26
2021-08-12 14:27:41,171 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade26to27
2021-08-12 14:27:41,178 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade27to30
2021-08-12 14:27:41,183 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade30to31
2021-08-12 14:27:41,189 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade32to33
2021-08-12 14:27:41,194 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade33to34
2021-08-12 14:27:41,200 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade34to35
2021-08-12 14:27:41,207 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade35to40
2021-08-12 14:27:41,214 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade40to41
2021-08-12 14:27:41,220 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade41to42
2021-08-12 14:27:41,226 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade42to43
2021-08-12 14:27:41,232 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade43to44
2021-08-12 14:27:41,238 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade44to45
2021-08-12 14:27:41,245 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade45to46
2021-08-12 14:27:41,251 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade460to462
2021-08-12 14:27:41,257 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade462to47
2021-08-12 14:27:41,263 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade47to48
2021-08-12 14:27:41,271 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade48to49
2021-08-12 14:27:41,279 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin VersionUpgrade49to410
2021-08-12 14:27:41,286 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin SimpleView
2021-08-12 14:27:41,294 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin X3DReader
2021-08-12 14:27:41,303 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin XmlMaterialProfile
2021-08-12 14:27:41,309 - INFO - [MainThread] UM.Logger.info [128]: Loaded plugin XRayView
2021-08-12 14:27:41,312 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [404]: Loading all plugins took 1.1519949436187744 seconds
2021-08-12 14:27:41,320 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
2021-08-12 14:27:41,334 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [175]: Checking and performing updates took 0.014960050582885742
2021-08-12 14:27:41,341 - INFO - [MainThread] UM.Logger.info [128]: Completed loading preferences.
2021-08-12 14:27:41,354 - INFO - [MainThread] UM.Logger.info [128]: Created system tray icon.
2021-08-12 14:27:42,475 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [361]: Loading metadata into container registry took 1.115753412246704 seconds
2021-08-12 14:27:42,484 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
2021-08-12 14:27:42,485 - INFO - [MainThread] cura.CuraApplication.run [797]: Initializing machine error checker
2021-08-12 14:27:42,487 - INFO - [MainThread] cura.CuraApplication.run [802]: Initializing machine manager
2021-08-12 14:27:42,489 - INFO - [MainThread] cura.CuraApplication.run [807]: Initializing container manager
2021-08-12 14:27:42,532 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
2021-08-12 14:27:42,551 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
2021-08-12 14:27:42,572 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.10.0\resources\themes\cura-light\theme.json
2021-08-12 14:27:42,685 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.10.0\resources\themes\cura-light
2021-08-12 14:27:42,927 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
2021-08-12 14:27:42,929 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
2021-08-12 14:27:42,930 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
2021-08-12 14:27:42,930 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
2021-08-12 14:27:42,931 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
2021-08-12 14:27:42,931 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
2021-08-12 14:27:42,932 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
2021-08-12 14:27:42,933 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
2021-08-12 14:27:42,933 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
2021-08-12 14:27:42,934 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
2021-08-12 14:27:42,935 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
2021-08-12 14:27:42,935 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
2021-08-12 14:27:42,936 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
2021-08-12 14:27:42,937 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
2021-08-12 14:27:43,050 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
2021-08-12 14:27:43,117 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [421]: file:///C:/Program Files/Ultimaker Cura 4.10.0/resources/qml/PrintSetupSelector/Custom/MenuButton.qml:42:18: QML Label: Cannot anchor to an item that isn't a parent or sibling.
2021-08-12 14:27:43,132 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2021-08-12 14:27:43,167 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [421]: file:///C:/Program Files/Ultimaker Cura 4.10.0/resources/qml/Settings/SettingView.qml:157:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
2021-08-12 14:27:43,218 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2021-08-12 14:27:43,220 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [100]: There was no auth data or access token
2021-08-12 14:27:43,262 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
2021-08-12 14:27:43,291 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
2021-08-12 14:27:43,293 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [421]: file:///C:/Program Files/Ultimaker Cura 4.10.0/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
2021-08-12 14:27:43,335 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [421]: file:///C:/Program Files/Ultimaker Cura 4.10.0/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:233: TypeError: Cannot read property 'isEnabled' of null
2021-08-12 14:27:43,361 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
2021-08-12 14:27:43,378 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [421]: file:///C:/Program Files/Ultimaker Cura 4.10.0/resources/qml/WelcomePages/WelcomeContent.qml:33:9: QML Image: Binding loop detected for property "sourceSize.height"
2021-08-12 14:27:43,379 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [117]: Creating model checker view.
2021-08-12 14:27:43,385 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [126]: Model checker view created.
2021-08-12 14:27:43,386 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
2021-08-12 14:27:43,415 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [542]: Requesting [updates] metadata from server.
2021-08-12 14:27:43,417 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [126]: No auth data to retrieve the access_token from
2021-08-12 14:27:43,418 - DEBUG - [MainThread] UM.Logger.debug [122]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.6.0/packages/package-updates?installed_packages=ImageReader:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=Toolbox:1.0.1&installed_packages=UltimakerNylon:1.4.0&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=FABtotumTPU:1.4.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=UltimakerABS:1.4.0&installed_packages=ConsoleLogger:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=SentryLogger:1.0.0&installed_packages=PolyWoodPLA:1.0.1&installed_packages=GenericCPEPlus:1.4.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=GenericHIPS:1.4.0&installed_packages=CuraEngineBackend:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=GenericBAM:1.4.0&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=SimpleView:1.0.1&installed_packages=GenericGFFCPE:1.4.0&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=STLReader:1.0.1&installed_packages=GenericCPE:1.4.0&installed_packages=DigitalLibrary:1.0.0&installed_packages=3MFWriter:1.0.1&installed_packages=SolidView:1.0.1&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=UpdateChecker:1.0.1&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=FirmwareUpdater:1.0.1&installed_packages=GenericCFFCPE:1.4.0&installed_packages=UltimakerPC:1.4.0&installed_packages=UltimakerPLA:1.4.0&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=FABtotumNylon:1.4.0&installed_packages=UltimakerCPEP:1.4.0&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=GenericPLA:1.4.0&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=MirrorTool:1.0.1&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=UFPWriter:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=GenericABS:1.4.0&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=MonitorStage:1.0.1&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=FABtotumABS:1.4.0&installed_packages=CameraTool:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=GenericPP:1.4.0&installed_packages=CuraProfileWriter:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=GCodeProfileReader:1.0.1&installed_packages=GenericPVA:1.4.0&installed_packages=GCodeWriter:1.0.1&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=PolyPlusPLA:1.0.1&installed_packages=TranslateTool:1.0.1&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=GenericCFFPA:1.4.0&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=VertexDeltaPET:1.4.0&installed_packages=3MFReader:1.0.1&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=SupportEraser:1.0.1&installed_packages=PolyFlexPLA:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=VertexDeltaABS:1.4.0&installed_packages=SelectionTool:1.0.1&installed_packages=ModelChecker:1.0.1&installed_packages=FABtotumPLA:1.4.0&installed_packages=OBJReader:1.0.1&installed_packages=PreviewStage:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=GenericNylon:1.4.0&installed_packages=AMFReader:1.0.0&installed_packages=X3DReader:1.0.1&installed_packages=GenericGFFPA:1.4.0&installed_packages=UltimakerPP:1.4.0&installed_packages=STLWriter:1.0.1&installed_packages=UltimakerBAM:1.4.0&installed_packages=ScaleTool:1.0.1&installed_packages=GenericPC:1.4.0&installed_packages=RotateTool:1.0.1&installed_packages=GCodeReader:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=OctofiberPLA:1.0.1&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=UltimakerCPE:1.4.0&installed_packages=UltimakerPVA:1.4.0&installed_packages=FileLogger:1.0.1&installed_packages=UltimakerTPLA:1.4.0&installed_packages=GCodeGzReader:1.0.1&installed_packages=SimulationView:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=GenericPETG:1.4.0&installed_packages=XRayView:1.0.1&installed_packages=LocalContainerProvider:1.0.1&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=TrimeshReader:1.0.0&installed_packages=UFPReader:1.0.0&installed_packages=LegacyProfileReader:1.0.1&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=OBJWriter:1.0.1&installed_packages=VertexDeltaTPU:1.4.0
2021-08-12 14:27:43,424 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
2021-08-12 14:27:43,426 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
2021-08-12 14:27:43,427 - DEBUG - [MainThread] cura.CuraApplication.run [851]: Booting Cura took 3.7786552906036377 seconds
2021-08-12 14:27:43,928 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
2021-08-12 14:27:43,934 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
2021-08-12 14:27:43,936 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 NVIDIA 471.68
2021-08-12 14:27:43,939 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   NVIDIA Corporation
2021-08-12 14:27:43,941 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: NVIDIA GeForce GTX 1650 Ti/PCIe/SSE2
2021-08-12 14:27:43,942 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.0.0
2021-08-12 14:27:43,945 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\default.shader]...
2021-08-12 14:27:43,948 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\selection.shader]...
2021-08-12 14:27:43,950 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\select_face.shader]...
2021-08-12 14:27:43,954 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\default.shader]...
2021-08-12 14:27:43,956 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\composite.shader]...
2021-08-12 14:27:43,960 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\overhang.shader]...
2021-08-12 14:27:43,963 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\striped.shader]...
2021-08-12 14:27:43,968 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\transparent_object.shader]...
2021-08-12 14:27:43,970 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\striped.shader]...
2021-08-12 14:27:43,977 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\xray.shader]...
2021-08-12 14:27:43,981 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\xray_composite.shader]...
2021-08-12 14:27:43,984 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\platform.shader]...
2021-08-12 14:27:43,992 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [59]: Loading shader file [C:\Program Files\Ultimaker Cura 4.10.0\resources\shaders\xray.shader]...
Quote
Edited by Telli
    • Telli changed the title to Windows 10 Cura 4.10 Crashes on startup.
