Tab Anti Warping plugin inserts SLOW g1 Speed in gcode!
Posted
(edited)
· Tab Anti Warping plugin inserts SLOW g1 Speed in gcode!
This plugin doesn't generate any G-Code it's just something to create a dedicate geometries and setting them as support element. If you have any issue it's certainly due to your settings, check the parameters in the speed section, and find any small value (support/brim/skirt)
In your case the first initial value for the tab are define by the Skirt/brim Speed .
Note : If you don't have activate any Adhesion type (Build Plate Adhesion types set to None) this parameter is not visible.
Edited by Cuq
Cuq 111
Edited by CuqLink to post
