Posted · No separate brim and skirt settings in 4.10?
Lots of (old) documentation for cura tells me the "skirt" setting is found under bed adhesion, yet when I make every possible setting visible, there is no skirt there in 4.10. Has it been removed since you can now turn the brim into a skirt by adding an offset?
    Maybe the pull down was to tiny for me to hit the right spot :-). Nope. I see what it is - if I'm looking in "select settings" after selecting an stl in the preview it isn't there. Up in global print settings it is there (which makes sense now I think about it, you probably wouldn't want a separate skirt on each part).
