Yes I have a 2A switching regulator in place of the 7812, so no problem there.
Is there an easy way of making the heater2 output active only when printing?
The heater2 output is coupled to the heater2 temperature sensor.
If you set the heater2 to 100°C target temperature, but the temperature reading never reaches 100°C, then the output will always be switched on
Of course you need a firmware that enables the heater2 output. And you need to solder in some fixed resistors on the heater2 temperature input so that it will always read the same temperature.
-> When the print is done, target temperature will be set to 0°C so the heater will switch off. Make sure heater2 temperature doesn't read below zero degrees
Thanks Jonny, thats kind of what I was thinking. The only drawback is it stops me doing a dual extruder in the future, but I'll give it a go.
You can also use the M42 command to control the 2nd/3th heater output if there is only a single-extruder extruder and no heated bed configured.
Sounds good, but I do have a heated bed... I'll look up M42 though.
Daid 300
I wouldn't draw from the 12V line of the UM electronics, there is a bit too much load on it already. You could use the Heater2 output.
