Hahah I like the ceiling idea but I'm afraid the issue won't be resolved.
What I'm saying is:
The tube bends from the hot end till the feeder.
The filament is curved in a different way than the tube as it's curved to follow the spool profile.
While the filament is being consumed and the spool "spins" the filament may assume a different curvature which is opposite as the one of the bowden tube.
This would cause additional stress and force required from the feeder motor.
By heating the filament we could remove the mechanical stress generated by the form of the spool which was generated at the time the filament was wound on the spool.
Do you think it would work?
Daid 306
I'm wondering what problem you are trying to solve really... my filament doesn't seem to have a problem to bend to the weak curve of the bowden tube.
You could however, remove the "stress" of the tube by hanging your extruder drive from a string on the ceiling above your machine... (I still hope to see photos of this silly idea some day)
