Posted · z hop causing rough surface scars
I am trying to engrave 0.25 mm text into a 2 mm back plate and fill it in with a different color filament later. Without z hop (top print), there is digging between some characters (e.g. "2" to " 3" and "3" to "A") but the overall surface is good.
When I enable z hop (middle) there is some random digging, and the surface appears more dotted/patchy?
I didn't notice a significant difference with z hop only over printed parts (bottom), as the top layer is still not very good.
In all cases I have ironing top layer enabled. Is z hop supposed to affect the top layer like this?
