Posted · SD Card "Read Only" Switch
If you accidentally attach an SD card with the "Read Only" switch activated, Cura will indicate that it cannot save to the SD card.  Even if you fix the issue, move the switch and re-insert the card, Cura still prevents you from writing to the SD card until you close Cura and start it again.  When that happens, I write to the hard drive then copy the file but this just seems like a bug.
          • Heart
        • 4 replies
