Saving postscripts to printer plugin
Posted · Saving postscripts to printer plugin
I have an idea for a plugin but currently do not feel confident enough to create this plugin on my own. I have not started work on any part of this yet but have found existing plugin wiki that exists and have taken a glance at the different example codes that it has.
The idea is as follows:
In either the printer settings window and/or somewhere in the print settings adding a area where you can setup and save post-processing scripts. The idea being that they will be saved and will be automatically applied when slicing your g-code but do not have to be entered each time you switch printers.
Any help would be appreciated because I really don't know how to approach making this plugin.
