The fan is turned on in the start code. Other then that SkeinPyPy doesn't touch the fan at all. Any btw, I am interested, why is that fan behavior useful?
It helps to make the first 3 layers stick better to the substrate. it also prevents some shrinking/lifting off due to slower cooling of the print.
Daid 306
If you want to know how the SF settings are hidden, check the file "fabmetheus_utilities/settings.py" this file is normally used by SF for setting initalization, and I replaced it for SkeinPyPy to load my settings instead of the idiocy of storing settings that SF uses by default. Cura won't give you access to every possible setting. But that is intentional.
