The problem is that the model has conflicting "normals". The top of the model (the "walls") has the normals facing outward, the bottom (the modeled "brim") has the normals facing inward. This confuses Cura. You can sort of see this because the top section has a red "overhang" indication on top, instead of on the bottom.
The easiest fix is to download the Mesh Tools plugin from the marketplace (if you don't have it already), select the model and right-click. Then select Mesh Tools -> Fix model normals. After that the model will slice properly.
If you look carefully at this image (that you posted yourself), you can also see that there is an issue with the normals. Looking at the small section between the tail and the head of the cat from below, you see that you are looking "through" the wall as if it did not exist, and then instead you see the insides of the wall. It looks asif you are staring into a box, as it were. This is due to what is called "backface culling"; the application that made this image did not draw the "back" of the faces. Since all the faces are "inverted", only the "insides" of the walls get drawn.
That did the trick.
I didn't really flinch at the strange representation in SW, since it sometimes loads models that actually slice correctly in a strange manner. But the Mesh Tools extention with 'Fix Normals' did indeed fix the stl model for slicing.
So you're definitely right.
Thanks a lot for your help. ❤️
ahoeben 1,992
ahoeben 1,992
Dacraun 0
That did the trick.
