Cura 4.12 and 4.13 Will Not Slice! (Solved)
Quacker
Posted (edited) · Cura 4.12 and 4.13 Will Not Slice! (Solved)
Found that the profile that loaded at startup was causing the problem. All better now after changing the offending profile to another.
Edited by Quacker
Solution Found
    • Quacker changed the title to Cura 4.12 and 4.13 Will Not Slice! (Solved)
        • 24 replies
