Am I doing something wrong CURA?
I need to flip an object over on the build plate. First of all the only way I can select an object is to select it from the object list at the bottom left corner.  I can't just click on it like I use to do before the last update. So after selecting it from the object list the left menu is enabled.  When I select rotate button roll circles (Red, Blue, Green) show up. Here is the problem. When I click on the control circles to roll the object it simply deselects object. The same happens with the move function. This is on a Mac Book MacOS Monterey 12.1. Cura 4.13.1
