Found the cause... If nVidia Physics engine (span across multiple screens) is enabled, your app corrupts the display. Not sure if it's worth fixing or figuring out, but the easiest fix is to disable Physics span setting in the nVidia control panel when using Cura.
Edited by mikevarga
mikevarga 0
Btw: On occasion this does function correctly...
