Monofilament
v8rick
Posted · Monofilament
Hi all. I am brand new to this
 I made monofilament for 16 years, 0.011mm for paper making ,1.5mm - 4mm cutting line and bigger stuff for tyres, Shift fitter and manager, if only I had stayed could have run some off on nights (with the right profiles). I have heard someone mention Poly pro, we used to use poly pro by the 25Kg bag to run through extruder to purge out the nylon, poly eth, polyester ect' before we stripped extruder for clean out .
I am now looking forward to being a monofilament customer looking for bad winds and "nubs" (lumps in mono)
