FlourX PVDF material
Posted · FlourX PVDF material
Hello,
I recently bought a material called FlourX PDVF made using Arkema Kynar. It can be found in Cura Marketplace so it should work with my Ultimaker S5. As glue I use Nano Polymer adhisive.  I set the printing temperature and build plate temperature initial layer 10°C up. I set bulit plate adhision type as raft. Nothing is working. The material starts to warp after 2h of printing. What could be the solution to my problem?
        • 31 replies
        • 23 replies
