Calibration Routine
RDC
Posted · Calibration Routine
When the printer starts a job, the print core first checks where the glass plate is with both cores.
This is done at the same spot.
Request to change this to about 2mm further apart, as the material from the right core contaminates that of the left core.
Depending on the type of material used, this can clog the core due to the difference in temperature settings between the two.
Thanks.
        • 24 replies
