Bowden Tube being forced out
Posted · Bowden Tube being forced out
I am using an ultimaker S5 pro with the material station. When i try to use any material through core 2 the bowden tube is pushed out and the material doesn't feed.
 Is this a matter of replacing the couple to hold the tube firmly in place? Where can i get these from?
