Adjust a material profile, possible??
JosR
Posted · Adjust a material profile, possible??
Hi All!!
on our Pro Bundle, i want to print with a ''new'' material, and i have a material profile. i have imported this material in our pro bundle, so i can select it when i choose to load the filament through the normal process on the touchscreen.
the material is starting to load/purge at a nozzle temp of 100 degrees celcius, and i need it to be higher, like a lot higher.... 320 degrees celcius.
so my question is, where can i adjust this temp? in the file? i dont see any line which defines the load in/purge temperature.
thanks a lot in advance!
cheers guys
Jos.
        • 30 replies
