first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
Posted · first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
The mouse pointer doesn't line up with the icons on the screen. It is just in Cura and happens everywhere in the program, though the relative misalignment is different in different parts of the screen. As per the pic, when the import/open file icon is highlighted, the mouse pointer is too far down and to the right. To the navigate layers in the Preview window, you have to point the mouse below and to the left of the icon. It makes navigating and selecting the right option a real challenge.
After getting a warning message about my crappy/standard graphics card (Intell(R) HD Graphics 620) when I ran Fusion360 the first time and that program looks a bit fuzzy (so haven't used it). Could that be related to my display issue? I don't know what else to investigate.
    Yes, certain intel drivers have been known to cause this offset in the past. Please check if intel has a newer driver version.
    It has been 5 years since I last saw this issue though: https://github.com/Ultimaker/Cura/issues/2068
    wow, thank you, you were on the money (and took the time to link to the 5 yr old discussion). i had checked my drivers were up to date via Windows but hadn't checked with Intel, just done and didn't fix the problem. i also just realised everyone sees the menu bar at the top of the screen
    There was a time when I knew the issue-number by heart, because it was such a prevalent thing. Good to know you got it worked out.
    No change at all?
    What version of the driver do you use now? My current laptop has the same GPU as yours, and I am not seeing this issue. I use driver version 21.20.16-4664.
    You could try the Cura 5.0 beta, which uses a newer version of the Qt framework which may not have this issue.
    same driver. just tried Cura 5.0 and got the same issues, mouse still off and can't see the menus across the top
    Posted (edited) · first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
    I'm sort of out of ideas then. Perhaps the logs and dxdiag can give us a hint:
    • The log as produced by dxdiag (start -> run -> dxdiag -> save output)
    • The Cura GUI log file, located at %APPDATA%\cura\<Cura version>\cura.log, usually C:\Users\<your username>\AppData\Roaming\cura\<Cura version>\cura.log
    Edited by ahoeben
    thank you.
    i hope this is the log you referred to (i'm a little out of my depth).
    System Information
          Time of this report: 4/24/2022, 06:31:52
                 Machine name: DESKTOP-8FH7TNB
                   Machine Id: {C1137081-AED2-4130-BDA0-FB3920D95453}
             Operating System: Windows 10 Home 64-bit (10.0, Build 19043) (19041.vb_release.191206-1406)
                     Language: English (Regional Setting: English)
          System Manufacturer: HP
                 System Model: HP Spectre x360 Convertible 13-w0XX
                         BIOS: F.45 (type: UEFI)
                    Processor: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz (4 CPUs), ~2.7GHz
                       Memory: 8192MB RAM
          Available OS Memory: 8070MB RAM
                    Page File: 7845MB used, 6880MB available
                  Windows Dir: C:\WINDOWS
              DirectX Version: DirectX 12
          DX Setup Parameters: Not found
             User DPI Setting: 144 DPI (150 percent)
           System DPI Setting: 144 DPI (150 percent)
              DWM DPI Scaling: UnKnown
                     Miracast: Available, with HDCP
    Microsoft Graphics Hybrid: Not Supported
     DirectX Database Version: 1.0.8
               DxDiag Version: 10.00.19041.0928 64bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
            Sound Tab 1: No problems found.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
               Card name: Intel(R) HD Graphics 620
            Manufacturer: Intel Corporation
               Chip type: Intel(R) HD Graphics Family
                DAC type: Internal
             Device Type: Full Device (POST)
              Device Key: Enum\PCI\VEN_8086&DEV_5916&SUBSYS_827E103C&REV_02
           Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
     Device Problem Code: No Problem
     Driver Problem Code: Unknown
          Display Memory: 4163 MB
        Dedicated Memory: 128 MB
           Shared Memory: 4035 MB
            Current Mode: 1920 x 1080 (32 bit) (60Hz)
             HDR Support: Not Supported
        Display Topology: Internal
     Display Color Space: DXGI_COLOR_SPACE_RGB_FULL_G22_NONE_P709
         Color Primaries: Red(0.642578,0.339844), Green(0.313477,0.608398), Blue(0.154297,0.050781), White Point(0.313477,0.329102)
       Display Luminance: Min Luminance = 0.500000, Max Luminance = 270.000000, MaxFullFrameLuminance = 270.000000
            Monitor Name: Generic PnP Monitor
           Monitor Model: unknown
              Monitor Id: CMN1367
             Native Mode: 1920 x 1080(p) (60.001Hz)
             Output Type: Internal
    Monitor Capabilities: HDR Not Supported
    Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
          Advanced Color: Not Supported
             Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdumdim64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10iumd64.dll,C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd12umd64.dll
     Driver File Version: 21.20.0016.4664 (English)
          Driver Version: 21.20.16.4664
             DDI Version: 12
          Feature Levels: 12_1,12_0,11_1,11_0,10_1,10_0,9_3,9_2,9_1
            Driver Model: WDDM 2.1
     Hardware Scheduling: Supported:False Enabled:False
     Graphics Preemption: Triangle
      Compute Preemption: Thread
                Miracast: Supported
          Detachable GPU: No
     Hybrid Graphics GPU: Integrated
          Power P-states: Not Supported
          Virtualization: Not Supported
              Block List: DISABLE_HWSCH
      Catalog Attributes: N/A
       Driver Attributes: Final Retail
        Driver Date/Size: 21/04/2017 9:30:00 AM, 94384376 bytes
             WHQL Logo'd: Yes
         WHQL Date Stamp: Unknown
       Device Identifier: {D7B78E66-1A56-11CF-B461-6EA2B9C2D835}
               Vendor ID: 0x8086
               Device ID: 0x5916
               SubSys ID: 0x827E103C
             Revision ID: 0x0002
      Driver Strong Name: oem48.inf:5f63e534fccdbc6c:iKBLD_w10_DS:21.20.16.4664:pci\ven_8086&dev_5916&subsys_827e103c
          Rank Of Driver: 00D10001
             Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
             DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  {E07EC519-E651-4CD6-AC84-1370CCEEC851}  {BCC5DB6D-A2B6-4AF0-ACE4-ADB1F787BC89}  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  {91CD2D6E-897B-4FA1-B0D7-51DC88010E0A}  DXVA2_ModeVP8_VLD  {442B942A-B4D9-4940-BC45-A882E5F919F3}  {97688186-56A8-4094-B543-FC9DAAA49F4B}  {1424D4DC-7CF5-4BB1-9CD7-B63717A72A6B}  {C346E8A3-CBED-4D27-87CC-A70EB4DC8C27}  {FFC79924-5EAF-4666-A736-06190F281443}  {F416F7BD-098A-4CF1-A11B-CE54959CA03D}  {BF44DACD-217F-4370-A383-D573BC56707E}  {2364D06A-F67F-4186-AED0-62B99E1784F1}  {28566328-F041-4466-8B14-8F5831E78F8B}  {6B4A94DB-54FE-4AE1-9BE4-7A7DAD004600}  {8C56EB1E-2B47-466F-8D33-7DBCD63F3DF2}  DXVA2_ModeHEVC_VLD_Main  {75FC75F7-C589-4A07-A25B-72E03B0383B3}  DXVA2_ModeHEVC_VLD_Main10  DXVA2_ModeVP9_VLD_Profile0  DXVA2_ModeVP9_VLD_10bit_Profile2  {76988A52-DF13-419A-8E64-FFCF4A336CF5}  {80A3A7BD-89D8-4497-A2B8-2126AF7E6EB8}  {50925B7B-E931-4978-A12A-586630F095F9}  {49761BEC-4B63-4349-A5FF-87FFDF088466}
       Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                         {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
            D3D9 Overlay: Supported
                 DXVA-HD: Supported
            DDraw Status: Enabled
              D3D Status: Enabled
              AGP Status: Enabled
           MPO MaxPlanes: 1
                MPO Caps: Not Supported
             MPO Stretch: Not Supported
         MPO Media Hints: Not Supported
             MPO Formats: Not Supported
        PanelFitter Caps: Not Supported
     PanelFitter Stretch: Not Supported
    Sound Devices
                Description: Speakers (Realtek High Definition Audio(SST))
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0295&SUBSYS_103C827E&REV_1000
            Manufacturer ID: N/A
                 Product ID: N/A
                       Type: N/A
                Driver Name: RTKVHD64.sys
             Driver Version: 6.0.1.8095 (English)
                WHQL Logo'd: Yes
              Date and Size: 17/03/2017 9:30:00 AM, 5697024 bytes
                Other Files:
            Driver Provider: Realtek Semiconductor Corp.
             HW Accel Level: Emulation Only
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
                Description: Microphone Array (Realtek High Definition Audio(SST))
      Default Sound Capture: Yes
      Default Voice Capture: Yes
                  Cap Flags: 0x1
               Format Flags: 0xFFFFF
    Video Capture Devices
    Number of Devices: 1
               FriendlyName: HP TrueVision FHD RGB-IR
                   Category: Camera
               SymbolicLink: \\?\usb#vid_064e&pid_3401&mi_00#6&2045b01b&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
                   Rotation: 0
               Manufacturer: Suyin
                 HardwareID: USB\VID_064E&PID_3401&REV_0011&MI_00,USB\VID_064E&PID_3401&MI_00
                 DriverDesc: HP TrueVision FHD RGB-IR
             DriverProvider: SunplusIT
              DriverVersion: 3.6.8.9
          DriverDateEnglish: 5/21/2020 00:00:00
        DriverDateLocalized: 21/05/2020 12:00:00 AM
                    Service: SPUVCbv
                      Class: Camera
              DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
                ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
                ProblemCode: No Problem
      BusReportedDeviceDesc: HP TrueVision FHD RGB-IR
                     Parent: USB\VID_064E&PID_3401\HF2066-P98B-OV07-REV0101
          DriverProblemDesc: n/a
               UpperFilters: n/a
               LowerFilters: n/a
                      Stack: \Driver\ksthunk,\Driver\SPUVCbv,\Driver\ACPI,\Driver\usbccgp
          ContainerCategory: n/a
              SensorGroupID: n/a
                       MFT0: n/a
                       DMFT: n/a
        CustomCaptureSource: n/a
      DependentStillCapture: n/a
         EnablePlatformDMFT: n/a
                  DMFTChain: n/a
     EnableDshowRedirection: True
         FrameServerEnabled: n/a
            AnalogProviders: SPITProvider
                 ProfileIDs: n/a
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver: n/a
          Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
          Device Name: HIDI2C Device
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x04F3, 0x2493
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
          Device Name: Logitech Download Assistant
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xB01B
            FF Driver: n/a
          Device Name: HP Wireless Button Driver
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x0001, 0x0001
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    + USB Root Hub (USB 3.0)
    | Vendor/Product ID: 0x8086, 0x9D2F
    | Matching Device ID: USB\ROOT_HUB30
    | Service: USBHUB3
    | Driver: USBHUB3.SYS, 9/18/2021 06:08:31, 648016 bytes
    +-+ Intel(R) Wireless Bluetooth(R)
    | | Vendor/Product ID: 0x8087, 0x0A2B
    | | Matching Device ID: USB\VID_8087&PID_0A2B&REV_0010
    | | Lower Filters: ibtusb
    | | Service: BTHUSB
    | | Driver: ibtusb.sys, 2/2/2022 08:33:00, 1081936 bytes
    | | Driver: BTHUSB.SYS, 12/15/2021 23:13:51, 110592 bytes
    | | Driver: bthport.sys, 12/15/2021 23:13:51, 1559552 bytes
    | +-+ Microsoft Bluetooth LE Enumerator
    | | | Matching Device ID: BTH\MS_BTHLE
    | | | Service: BthLEEnum
    | | | Driver: Microsoft.Bluetooth.Legacy.LEEnumerator.sys, 9/11/2020 07:54:10, 106496 bytes
    | | +-+ Bluetooth LE Device
    | | | | Matching Device ID: BTHLE\GenericDevice
    | | | | Service: BthLEEnum
    | | | +-+ Bluetooth Low Energy GATT compliant HID device
    | | | | | Vendor/Product ID: 0x0020, 0x0B01
    | | | | | Matching Device ID: BTHLEDevice\{00001812-0000-1000-8000-00805f9b34fb}
    | | | | | Lower Filters: WUDFRd
    | | | | | Service: mshidumdf
    | | | | | Driver: Microsoft.Bluetooth.Profiles.HidOverGatt.dll, 1/13/2021 13:55:07, 194560 bytes
    | | | | +-+ HID Keyboard Device
    | | | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
    | | | | | | Service: kbdhid
    | | | | | | Driver: kbdhid.sys, 12/7/2019 18:37:56, 46592 bytes
    | | | | | | Driver: kbdclass.sys, 12/7/2019 18:37:56, 71480 bytes
    | | | | +-+ HID-compliant mouse
    | | | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
    | | | | | | Service: mouhid
    | | | | | | Driver: mouhid.sys, 12/7/2019 18:37:56, 35328 bytes
    | | | | | | Driver: mouclass.sys, 12/7/2019 18:37:56, 67600 bytes
    Gameport Devices
    PS/2 Devices
    + Standard PS/2 Keyboard
    | Matching Device ID: *PNP0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 12/7/2019 18:37:56, 118272 bytes
    + Synaptics SMBus TouchPad
    | Matching Device ID: ACPI\SYN323D
    | Upper Filters: SynTP
    | Service: i8042prt
    | Driver: SynTP.sys, 8/21/2019 04:57:26, 768856 bytes
    | Driver: SynTPEnh.exe, 8/21/2019 04:57:26, 4312408 bytes
    | Driver: SynTPRes.dll, 8/21/2019 04:57:24, 19840344 bytes
    | Driver: SynTPAPI.dll, 8/21/2019 04:57:24, 275288 bytes
    | Driver: SynCOM.dll, 8/21/2019 04:57:20, 808792 bytes
    | Driver: SynTPEnhService.exe, 8/21/2019 04:57:24, 381784 bytes
    Disk & DVD/CD-ROM Drives
          Drive: 😄
     Free Space: 14.9 GB
    Total Space: 232.2 GB
    File System: NTFS
          Model: SAMSUNG MZVLW256HEHP-000H1
          Drive: 😧
     Free Space: 1.1 GB
    Total Space: 10.7 GB
    File System: NTFS
    System Devices
         Name: Intel(R) Dual Band Wireless-AC 8265
    Device ID: PCI\VEN_8086&DEV_24FD&SUBSYS_10108086&REV_78\4&3AE18EC&0&00E0
       Driver: C:\WINDOWS\system32\DRIVERS\Netwtw06.sys, 20.70.0030.0001 (English), 3/12/2022 08:00:30, 8899176 bytes
       Driver: C:\WINDOWS\system32\DRIVERS\Netwfw06.dat, 3/12/2022 08:00:30, 2633112 bytes
       Driver: C:\WINDOWS\system32\IntelIHVRouter06.dll, 22.12120.0000.0001 (English), 3/12/2022 08:00:30, 1626216 bytes
         Name: Intel(R) HD Graphics 620
    Device ID: PCI\VEN_8086&DEV_5916&SUBSYS_827E103C&REV_02\3&11583659&1&10
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdkmd64.sys, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 11073480 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10iumd64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 24935616 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10idpp64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 433840 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd11dxva64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 48295584 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd12umd64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 3486648 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdumdim64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 94384376 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdail64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 327656 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxcmrt64.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 197040 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfx11cmrt64.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 194472 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxcmjit64.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 2324456 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdde64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 224744 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdusc64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 6628600 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iga64.dll, 10/2/2017 06:34:58, 1581424 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igc64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 18618272 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdmd64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 3225200 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10iumd32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 19119776 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd10idpp32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 411856 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd11dxva32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 47419360 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igd12umd32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 3388696 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdumdim32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:01, 93119520 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdail32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 308200 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdde32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 183856 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxcmrt32.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 170672 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfx11cmrt32.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 170760 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxcmjit32.dll, 6.00.0000.1189 (English), 10/2/2017 06:35:02, 1711592 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdusc32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 5090128 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iga32.dll, 10/2/2017 06:34:58, 1374896 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igc32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 15933856 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdmd32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 2510320 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxs64.vp, 10/2/2017 06:35:02, 12742 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxo64.vp, 10/2/2017 06:35:02, 40343 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxc64.vp, 10/2/2017 06:35:02, 40316 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxg64.vp, 10/2/2017 06:35:02, 39658 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxo64_dev.vp, 10/2/2017 06:35:02, 40931 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxc64_dev.vp, 10/2/2017 06:35:02, 41296 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxg64_dev.vp, 10/2/2017 06:35:02, 39798 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxa64.vp, 10/2/2017 06:35:02, 1125 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhxa64.cpa, 10/2/2017 06:35:02, 2813952 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhcp64.dll, 9.00.0030.7777 (English), 10/2/2017 06:35:02, 238864 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhsip64.dll, 9.00.0030.9000 (English), 10/2/2017 06:35:02, 1816680 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\IntelCpHDCPSvc.exe, 1.00.0000.0001 (English), 10/2/2017 06:35:02, 462848 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhcp32.dll, 9.00.0030.7777 (English), 10/2/2017 06:35:02, 203272 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\iglhsip32.dll, 9.00.0030.9000 (English), 10/2/2017 06:35:02, 1814032 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\IntelCpHeciSvc.exe, 9.00.0002.0117 (English), 10/2/2017 06:35:02, 285696 bytes
       Driver: C:\WINDOWS\system32\cp_resources.bin, 10/2/2017 06:34:57, 560260 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\difx64.exe, 1.04.0003.0000 (English), 10/2/2017 06:34:57, 157696 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDH.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 925160 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDHLib.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 115688 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDHLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 123872 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDI.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 399848 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDILib.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 29672 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDILibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 29664 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxLHM.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 1992680 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxLHMLib.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 22504 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxLHMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 22504 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxSDK.exe, 10/2/2017 06:35:02, 982016 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxSDKLib.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 97768 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxSDKLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 107496 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxEM.exe, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 505856 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxEMLib.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 27616 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxEMLibv2_0.dll, 1.00.0000.0000 (Invariant Language), 10/2/2017 06:35:02, 27624 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\GfxUIEx.exe, 6.15.0010.4664 (English), 10/2/2017 06:34:57, 441344 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\Gfxv4_0.exe, 8.15.0010.4664 (English), 10/2/2017 06:34:57, 901632 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\Gfxv4_0.exe.config, 10/2/2017 06:34:57, 935 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\Gfxv2_0.exe, 8.15.0010.4664 (English), 10/2/2017 06:34:57, 895488 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\Gfxv2_0.exe.config, 10/2/2017 06:34:57, 895 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\GfxResources.dll, 8.15.0010.4664 (English), 10/2/2017 06:34:57, 5056488 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\MetroIntelGenericUIFramework.dll, 1.00.0000.0000 (English), 10/2/2017 06:35:03, 641000 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxCUIServicePS.dll, 10/2/2017 06:35:02, 102880 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxCUIService.exe, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 324608 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxCPL.cpl, 10/2/2017 06:35:02, 271328 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxDTCM.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 208360 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxext.exe, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 285184 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxexps.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 55216 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\ColorImageEnhancement.wmv, 10/2/2017 06:34:56, 375173 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\ImageStabilization.wmv, 10/2/2017 06:35:02, 403671 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\FilmModeDetection.wmv, 10/2/2017 06:34:57, 641530 bytes
       Driver: C:\WINDOWS\system32\igfxCPL.cpl, 10/2/2017 06:35:02, 271328 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igfxexps32.dll, 6.15.0010.4664 (English), 10/2/2017 06:35:02, 52712 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\ig9icd64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:58, 13902304 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\ig9icd32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:57, 10616296 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igvk64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 5578552 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igvk64.json, 10/2/2017 06:35:02, 137 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\VulkanRT-EULA.rtf, 10/2/2017 06:35:04, 1469 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\VulkanRT-Installer.exe, 1.00.0033.0000 (English), 10/2/2017 06:35:04, 679968 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igvk32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 4451000 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igvk32.json, 10/2/2017 06:35:02, 137 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\llvm_release_license.txt, 10/2/2017 06:35:04, 1981 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\readme.txt, 10/2/2017 06:35:04, 9788 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\version.ini, 10/2/2017 06:35:04, 30 bytes
       Driver: C:\WINDOWS\SysWow64\Intel_OpenCL_ICD32.dll, 2.01.0000.0000 (English), 10/2/2017 06:35:02, 104416 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\task_executor32.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:04, 378336 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\OclCpuBackend32.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:04, 8679400 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\intelocl32.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:03, 1471464 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\cpu_device32.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:03, 525280 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8.rtl, 10/2/2017 06:35:03, 1304100 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.o, 10/2/2017 06:35:03, 321224 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfnn8_img_cbk.rtl, 10/2/2017 06:35:03, 392476 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9.rtl, 10/2/2017 06:35:03, 1242036 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.o, 10/2/2017 06:35:03, 312484 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfng9_img_cbk.rtl, 10/2/2017 06:35:03, 392356 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9.rtl, 10/2/2017 06:35:03, 897152 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.o, 10/2/2017 06:35:03, 263856 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clbltfns9_img_cbk.rtl, 10/2/2017 06:35:03, 350160 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\clang_compiler32.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:03, 1435616 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_n8.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5022696 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_g9.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5360104 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\__ocl_svml_s9.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5238240 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 10/2/2017 06:35:04, 274048 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb.dll, 4.03.2015.0528 (English), 10/2/2017 06:35:04, 436360 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x86\tbb\tbb_preview.dll, 4.02.2013.1002 (), 10/2/2017 06:35:04, 355968 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\common\clbltfnshared.rtl, 10/2/2017 06:35:03, 1069972 bytes
       Driver: C:\WINDOWS\system32\Intel_OpenCL_ICD64.dll, 2.01.0000.0000 (English), 10/2/2017 06:35:02, 113640 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\task_executor64.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:04, 434664 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\OclCpuBackend64.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:04, 11611104 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\intelocl64.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:04, 1711592 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\cpu_device64.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:03, 671208 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8.rtl, 10/2/2017 06:35:03, 1251848 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.o, 10/2/2017 06:35:03, 344208 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnh8_img_cbk.rtl, 10/2/2017 06:35:03, 407884 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9.rtl, 10/2/2017 06:35:03, 1189792 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.o, 10/2/2017 06:35:03, 331136 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfne9_img_cbk.rtl, 10/2/2017 06:35:03, 407764 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9.rtl, 10/2/2017 06:35:03, 829680 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.o, 10/2/2017 06:35:03, 283240 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clbltfnl9_img_cbk.rtl, 10/2/2017 06:35:03, 365936 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\clang_compiler64.dll, 6.08.0000.0002 (English), 10/2/2017 06:35:03, 1883624 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_h8.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5234152 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_e9.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5744608 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\__ocl_svml_l9.dll, 3.04.0000.0000 (English), 10/2/2017 06:35:04, 5627360 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbbmalloc.dll, 4.03.2015.0528 (English), 10/2/2017 06:35:04, 323712 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb.dll, 4.03.2015.0528 (English), 10/2/2017 06:35:04, 521856 bytes
       Driver: C:\Program Files (x86)\Common Files\Intel\OpenCL\bin\x64\tbb\tbb_preview.dll, 4.02.2013.1002 (), 10/2/2017 06:35:04, 433792 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\IntelOpenCL32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 325608 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdbcl32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 412128 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdrcl32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 6389736 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\common_clang32.dll, 4.03.0000.0000 (English), 10/2/2017 06:34:57, 24668136 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdmcl32.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 4840424 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdfcl32.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 239072 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\IntelOpenCL64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:02, 427496 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdbcl64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 460776 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdrcl64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 7093736 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\common_clang64.dll, 4.03.0000.0000 (English), 10/2/2017 06:34:57, 36625896 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdmcl64.dll, 21.20.0016.4664 (English), 10/2/2017 06:35:00, 6886888 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdfcl64.dll, 21.20.0016.4664 (English), 10/2/2017 06:34:59, 279016 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igdclbif.bin, 10/2/2017 06:34:59, 8096666 bytes
       Driver: C:\WINDOWS\SysWow64\libEGL.dll, 10/2/2017 06:35:02, 141288 bytes
       Driver: C:\WINDOWS\SysWow64\libGLESv1_CM.dll, 10/2/2017 06:35:02, 101344 bytes
       Driver: C:\WINDOWS\SysWow64\libGLESv2.dll, 10/2/2017 06:35:02, 112104 bytes
       Driver: C:\Program Files\Intel\Media SDK\libmfxhw32.dll, 7.17.0003.0015 (English), 10/2/2017 06:35:03, 8649360 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfxplugin32_hw.dll, 1.17.0003.0015 (English), 10/2/2017 06:35:03, 4716760 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_32.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2612240 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_32.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2455232 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_32.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2465984 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_32.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2624304 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_32.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2445488 bytes
       Driver: C:\Program Files\Intel\Media SDK\c_32.cpa, 10/2/2017 06:34:57, 1361159 bytes
       Driver: C:\Program Files\Intel\Media SDK\cpa_32.vp, 10/2/2017 06:34:57, 1125 bytes
       Driver: C:\Program Files\Intel\Media SDK\dev_32.vp, 10/2/2017 06:34:57, 57143 bytes
       Driver: C:\Program Files\Intel\Media SDK\he_32.vp, 10/2/2017 06:34:57, 77505 bytes
       Driver: C:\Program Files\Intel\Media SDK\mj_32.vp, 10/2/2017 06:35:03, 71333 bytes
       Driver: C:\Program Files\Intel\Media SDK\h265e_32.vp, 10/2/2017 06:34:57, 78901 bytes
       Driver: C:\Program Files\Intel\Media SDK\libmfxhw64.dll, 7.17.0003.0015 (English), 10/2/2017 06:35:03, 9357712 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfxplugin64_hw.dll, 1.17.0003.0015 (English), 10/2/2017 06:35:03, 4886232 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h264ve_64.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 3154648 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_mjpgvd_64.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2961608 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_vp8vd_64.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2974408 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_h265ve_64.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 3178776 bytes
       Driver: C:\Program Files\Intel\Media SDK\mfx_mft_encrypt_64.dll, 7.17.0002.0021 (English), 10/2/2017 06:35:03, 2939128 bytes
       Driver: C:\Program Files\Intel\Media SDK\c_64.cpa, 10/2/2017 06:34:57, 1376256 bytes
       Driver: C:\Program Files\Intel\Media SDK\cpa_64.vp, 10/2/2017 06:34:57, 1125 bytes
       Driver: C:\Program Files\Intel\Media SDK\dev_64.vp, 10/2/2017 06:34:57, 56359 bytes
       Driver: C:\Program Files\Intel\Media SDK\he_64.vp, 10/2/2017 06:34:57, 13319 bytes
       Driver: C:\Program Files\Intel\Media SDK\mj_64.vp, 10/2/2017 06:35:03, 12803 bytes
       Driver: C:\Program Files\Intel\Media SDK\h265e_64.vp, 10/2/2017 06:34:57, 13875 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\igxpco64.dll, 1.03.0024.0000 (English), 10/2/2017 06:35:02, 220136 bytes
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\ki122204.inf_amd64_acc72d96b528231a\DisplayAudiox64.cab, 10/2/2017 06:34:57, 935294 bytes
         Name: Mobile 6th/7th Generation Intel(R) Processor Family I/O Thermal subsystem - 9D31
    Device ID: PCI\VEN_8086&DEV_9D31&SUBSYS_827E103C&REV_21\3&11583659&1&A2
       Driver: n/a
         Name: Standard NVM Express Controller
    Device ID: PCI\VEN_144D&DEV_A804&SUBSYS_A801144D&REV_00\4&24F4B84E&0&00E8
       Driver: C:\WINDOWS\system32\DRIVERS\stornvme.sys, 10.00.19041.1566 (English), 3/11/2022 05:37:02, 162128 bytes
         Name: Intel(R) Dynamic Platform and Thermal Framework Processor Participant
    Device ID: PCI\VEN_8086&DEV_1903&SUBSYS_827E103C&REV_02\3&11583659&1&20
       Driver: C:\WINDOWS\system32\DRIVERS\dptf_cpu.sys, 8.02.11000.2996 (English), 9/26/2016 16:55:07, 66624 bytes
       Driver: C:\WINDOWS\system32\WdfCoInstaller01011.dll, 1.11.9200.16384 (English), 9/26/2016 16:55:07, 1804688 bytes
         Name: Synaptics SMBus Driver
    Device ID: PCI\VEN_8086&DEV_9D23&SUBSYS_827E103C&REV_21\3&11583659&1&FC
       Driver: C:\WINDOWS\system32\DRIVERS\Smb_driver_Intel.sys, 19.05.0035.0047 (English), 8/21/2019 04:57:20, 48984 bytes
         Name: Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
    Device ID: PCI\VEN_8086&DEV_9D2F&SUBSYS_827E103C&REV_21\3&11583659&1&A0
       Driver: C:\WINDOWS\system32\DRIVERS\USBXHCI.SYS, 10.00.19041.1566 (English), 3/11/2022 05:37:02, 624976 bytes
       Driver: C:\WINDOWS\system32\DRIVERS\UMDF\UsbXhciCompanion.dll, 10.00.19041.1566 (English), 3/11/2022 05:37:02, 138976 bytes
         Name: Mobile 6th/7th Generation Intel(R) Processor Family I/O PCI Express Root Port #2 - 9D11
    Device ID: PCI\VEN_8086&DEV_9D11&SUBSYS_827E103C&REV_F1\3&11583659&1&E0
       Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.19041.1387 (English), 12/15/2021 23:13:51, 469840 bytes
         Name: Intel(R) Smart Sound Technology (Intel(R) SST) Audio Controller
    Device ID: PCI\VEN_8086&DEV_9D71&SUBSYS_827E103C&REV_21\3&11583659&1&FB
       Driver: C:\WINDOWS\system32\DRIVERS\IntcAudioBus.sys, 9.21.0000.2277 (English), 6/1/2018 13:59:45, 238176 bytes
       Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.19041.0746 (English), 1/13/2021 13:55:07, 97792 bytes
       Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.19041.0746 (English), 1/13/2021 13:55:07, 388608 bytes
         Name: Mobile 6th/7th Generation Intel(R) Processor Family I/O PCI Express Root Port #5 - 9D14
    Device ID: PCI\VEN_8086&DEV_9D14&SUBSYS_827E103C&REV_F1\3&11583659&1&E4
         Name: Intel(R) Serial IO I2C Host Controller - 9D60
    Device ID: PCI\VEN_8086&DEV_9D60&SUBSYS_827E103C&REV_21\3&11583659&1&A8
       Driver: C:\WINDOWS\system32\DRIVERS\iaLPSS2i_I2C.sys, 30.100.1816.0003 (English), 12/7/2019 18:37:47, 171520 bytes
         Name: Mobile 6th/7th Generation Intel(R) Processor Family I/O PMC - 9D21
    Device ID: PCI\VEN_8086&DEV_9D21&SUBSYS_827E103C&REV_21\3&11583659&1&FA
       Driver: n/a
         Name: Intel(R) Integrated Sensor Solution
    Device ID: PCI\VEN_8086&DEV_9D35&SUBSYS_827E103C&REV_21\3&11583659&1&98
       Driver: C:\WINDOWS\system32\DRIVERS\ISH.sys, 3.01.0000.3363 (English), 9/20/2016 03:17:28, 143984 bytes
         Name: Intel(R) Xeon(R) E3 - 1200 v6/7th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 5904
    Device ID: PCI\VEN_8086&DEV_5904&SUBSYS_827E103C&REV_02\3&11583659&1&00
       Driver: n/a
         Name: Mobile 7th Generation Intel(R) Processor Family I/O LPC Controller (U Premium) - 9D58
    Device ID: PCI\VEN_8086&DEV_9D58&SUBSYS_827E103C&REV_21\3&11583659&1&F8
       Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.19041.1202 (English), 9/18/2021 06:08:31, 20280 bytes
         Name: Mobile 6th/7th Generation Intel(R) Processor Family I/O PCI Express Root Port #9 - 9D18
    Device ID: PCI\VEN_8086&DEV_9D18&SUBSYS_827E103C&REV_F1\3&11583659&1&E8
         Name: Intel(R) Management Engine Interface
    Device ID: PCI\VEN_8086&DEV_9D3A&SUBSYS_827E103C&REV_21\3&11583659&1&B0
       Driver: C:\WINDOWS\System32\DriverStore\FileRepository\heci.inf_amd64_d01e7c2e2b4c1b72\x64\TeeDriverW10x64.sys, 1952.14.0000.1470 (English), 1/12/2020 01:19:30, 298480 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.19041.1288
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.19041.1288
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.19041.0001
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.19041.0001
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.19041.0450
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.19041.0001
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.19041.1110
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.19041.1165
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.19041.1165
    DV Muxer,0x00400000,0,0,qdv.dll,10.00.19041.0001
    Color Space Converter,0x00400001,1,1,quartz.dll,10.00.19041.0746
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.19041.0001
    AVI Splitter,0x00600000,1,1,quartz.dll,10.00.19041.0746
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.19041.0746
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.19041.0001
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.19041.1620
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
    StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.19041.0001
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.19041.0746
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
    VSDC Video Decoder,0x0080a000,1,1,mslvddsfilter4.ax,4.00.0001.0189
    VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.19041.0746
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.19041.0329
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.19041.0001
    SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.19041.0001
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.19041.0746
    DV Splitter,0x00600000,1,2,qdv.dll,10.00.19041.0001
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.19041.0746
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.19041.0001
    ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.19041.0746
    Video Renderer,0x00800001,1,0,quartz.dll,10.00.19041.0746
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.19041.0001
    Line 21 Decoder,0x00600000,1,1,,
    Video Port Manager,0x00600000,2,1,quartz.dll,10.00.19041.0746
    Video Renderer,0x00400000,1,0,quartz.dll,10.00.19041.0746
    VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.19041.0001
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.19041.0001
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
    File writer,0x00200000,1,0,qcap.dll,10.00.19041.0001
    DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.19041.0746
    Overlay Mixer2,0x00200000,1,1,,
    AVI Draw,0x00600064,9,1,quartz.dll,10.00.19041.0746
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.19041.0001
    WST Pager,0x00200000,1,1,WSTPager.ax,10.00.19041.0001
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.19041.0329
    DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.19041.0001
    SampleGrabber,0x00200000,1,1,qedit.dll,10.00.19041.0746
    Null Renderer,0x00200000,1,0,qedit.dll,10.00.19041.0746
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.19041.0001
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.19041.0001
    StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.19041.0001
    Smart Tee,0x00200000,1,2,qcap.dll,10.00.19041.0001
    Overlay Mixer,0x00200000,0,0,,
    AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.19041.0746
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.19041.0746
    Wave Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
    MIDI Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
    Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.19041.0746
    File stream renderer,0x00400000,1,1,quartz.dll,10.00.19041.0746
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.19041.0001
    StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.19041.0001
    AVI Mux,0x00200000,1,0,qcap.dll,10.00.19041.0001
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.19041.0746
    File Source (Async.),0x00400000,0,1,quartz.dll,10.00.19041.0746
    File Source (URL),0x00400000,0,1,quartz.dll,10.00.19041.0746
    Video Out,0x00200000,0,1,mslvvdsfilter4.ax,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.19041.0001
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.19041.0546
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.19041.0001
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.19041.0746
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.19041.0867
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.19041.0001
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.19041.0001
    DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.19041.0001
    MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.19041.0746
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.19041.0508
    WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.19041.0508
    IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.19041.0746
    GSM 6.10,0x00200000,1,1,quartz.dll,10.00.19041.0746
    CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
    CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.19041.0746
    MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.19041.0746
    Audio Capture Sources:
    Microphone Array (Realtek High Definition Audio(SST)),0x00200000,0,0,qcap.dll,10.00.19041.0001
    PBDA CP Filters:
    PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.19041.1566
    PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1566
    PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.19041.1566
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
    Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.19041.0746
    WDM Streaming Capture Devices:
    Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
    Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
    HP TrueVision FHD RGB-IR,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
    WDM Streaming Rendering Devices:
    Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.19041.0746
    ,0x00200000,1,1,,
    BDA Network Providers:
    Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
    Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
    Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
    Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.19041.0001
    Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.19041.0001
    Video Capture Sources:
    Multi-Instance Capable VBI Codecs:
    BDA Transport Information Renderers:
    BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.19041.0001
    MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.19041.0001
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,1,msvidctl.dll,6.05.19041.0746
    Encrypt/Tag,0x00200000,0,0,,
    PTFilter,0x00200000,0,0,,
    XDS Codec,0x00200000,0,0,,
    WDM Streaming Communication Transforms:
    Audio Renderers:
    Speakers (Realtek High Definition Audio(SST)),0x00200000,1,0,quartz.dll,10.00.19041.0746
    Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.19041.0746
    Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.19041.0746
    DirectSound: Speakers (Realtek High Definition Audio(SST)),0x00200000,1,0,quartz.dll,10.00.19041.0746
    Preferred DirectShow Filters
    [HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
    <media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
    MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
    MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
    MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
    {78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    {64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    {58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    {5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    {44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
    MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
    MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
    MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
    MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
    MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
    MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
    MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
    MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
    MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
    MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
    MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
    WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
    MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
    MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
    WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
    MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
    MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
    {6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
    {64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
    {64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
    MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
    {20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
    MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
    WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
    WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
    Media Foundation File Versions
      mfcore.dll, 10.00.19041.1645
      mfreadwrite.dll, 10.00.19041.0746
      mfcaptureengine.dll, 10.00.19041.0906
      mfsensorgroup.dll, 10.00.19041.1503
      windows.media.dll, 10.00.19041.1566
      frameserver.dll, 10.00.19041.1503
      frameserverclient.dll, 10.00.19041.1503
    Media Foundation Transforms
    [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
    <category>:
      <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
    Video Decoders:
      Intel® Hardware M-JPEG Decoder MFT, {00C69F81-0524-48C0-A353-4DD9D54F9A6E}, 0x6, 7, mfx_mft_mjpgvd_64.dll, 7.17.0002.0021
      Intel® Hardware VP8 Decoder MFT, {6D856398-834E-4A89-8EE5-071BB3F58BE4}, 0x6, mfx_mft_vp8vd_64.dll, 7.17.0002.0021
      Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.19041.1620
      DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.19041.0001
      Intel® Hardware VP8 Sync Decoder MFT, {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}, 0x1, mfx_mft_vp8vd_64.dll, 7.17.0002.0021
      Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.19041.0450
      Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.19041.1620
      WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.19041.0001
      WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.19041.1110
      MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.19041.1348
      Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.19041.1165
      Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.19041.1165
      VP9VideoExtensionDecoder
      HEVCVideoExtension
      WebpImageExtension
      HEIFImageExtension
    Video Encoders:
      Intel® Quick Sync Video H.264 Encoder MFT, {4BE8D3C0-0515-4A37-AD55-E4BAE19AF471}, 0x4, 7, mfx_mft_h264ve_64.dll, 7.17.0002.0021
      Intel® Hardware H265 Encoder MFT, {BC10864D-2B34-408F-912A-102B1B867B6C}, 0x4, 7, mfx_mft_h265ve_64.dll, 7.17.0002.0021
      H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.19041.1566
      WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.19041.0867
      H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.19041.0001
      WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.19041.0001
      Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.19041.0001
      VP9VideoExtensionEncoder
      HEVCVideoExtensionEncoder
      HEIFImageExtension
    Video Effects:
      Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
      Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.19041.0867
      VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.19041.0746
      Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.19041.0746
      Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.19041.1110
    Video Processor:
      Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.19041.1566
    Audio Decoders:
      Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.19041.1645
      MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.19041.0001
      WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.19041.1288
      Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
      A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.19041.1645
      GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.19041.1645
      WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.19041.1288
      Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.19041.0746
      Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.19041.1566
      Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.19041.1165
      WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.19041.0001
      G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.19041.1645
      IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.19041.1645
      MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.19041.0001
      Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.19041.0746
      ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.19041.1645
      Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
      DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
    Audio Encoders:
      LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.19041.0746
      MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.19041.1645
      Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.19041.0746
      WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.19041.0508
      MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.19041.0001
      Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.19041.0001
      WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.19041.0508
      Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.19041.0001
      Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.19041.0746
      Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.19041.0001
    Audio Effects:
      AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.19041.0001
      Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.19041.0001
    Multiplexers:
      Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.19041.1566
    Others:
      Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.19041.1620
    Media Foundation Enabled Hardware Categories
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
    EnableEncoders = 1
    EnableDecoders = 1
    Media Foundation Byte Stream Handlers
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
    [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
    <file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
    .3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    .ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
    .adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    .adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    .am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
    .amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
    .asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    .avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
    .dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
    .dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
    .ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
    .flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
    .m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    .mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    .mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    .mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    .mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    .mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    .mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
    .sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
    .smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
    .tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    .vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    .wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
    .weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
    .webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
    .wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    .wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    .wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    .wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
    audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
    audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
    audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
    audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
    audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
    audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
    audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
    audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
    audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
    audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
    video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
    video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
    video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
    video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
    video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
    video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
    video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
    video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
    Media Foundation Scheme Handlers
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
    <URL type>, <handler CLSID>, <brief description>[, Preferred]
    file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
    http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
    http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
    http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
    https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
    httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
    httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
    mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
    ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
    ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
    ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
    rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
    Preferred Media Foundation Transforms
    [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
    <media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
    {EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
    {E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
    MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
    MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
    {A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
    {A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
    {7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    {73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
    MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
    MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
    MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
    {63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
    MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    {53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
    MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    {3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
    MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
    MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
    MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    {33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
    MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
    MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
    MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
    MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
    MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
    MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
    MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
    MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
    MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
    {0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
    {00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
    {0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
    {00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
    {00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
    {00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
    MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
    MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
    MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
    MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
    MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
    MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
    MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
    MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
    MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
    {00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
    {00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
    KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
    {00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
    KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
    MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
    Disabled Media Foundation Transforms
    [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
    <transform CLSID>
    Disabled Media Sources
    [HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
    <media source CLSID>
    EVR Power Information
    Current Setting: {651288E5-A7ED-4076-A96B-6CC62D848FE1} (Balanced)
      Quality Flags: 2576
        Enabled:
        Force throttling
        Allow half deinterlace
        Allow scaling
        Decode Power Usage: 100
      Balanced Flags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force half deinterlace
        Force scaling
        Decode Power Usage: 50
      PowerFlags: 1424
        Enabled:
        Force throttling
        Allow batching
        Force scaling
        Decode Power Usage: 0
    Diagnostics
    Windows Error Reporting:
    +++ WER0 +++:
    Fault bucket 1194472774629272955, type 5
    Event Name: RADAR_PRE_LEAK_64
    Response: Not available
    Cab Id: 0
    Problem signature:
    P1: Ultimaker-Cura.exe
    P2: 0.0.0.0
    P3: 10.0.19043.2.0.0
    P4:
    P5:
    P6:
    P7:
    P8:
    P9:
    P10:
    +++ WER1 +++:
    Fault bucket 1425289978414885183, type 5
    Event Name: MoAppHang
    Cab Id: 0
    Problem signature:
    P1: Microsoft.MicrosoftEdge.Stable_100.0.1185.44_neutral__8wekyb3d8bbwe
    P2: praid:App
    P3: 100.0.1185.50
    P4: 626070e7
    P5: ce80
    P6: 2097152
    P7:
    P8:
    P9:
    P10:
    +++ WER2 +++:
    Fault bucket 1676797237887462000, type 5
    Cab Id: 0
    Problem signature:
    P1: explorer.exe
    P2: 10.0.19041.1645
    P4:
    P5:
    P6:
    P7:
    P8:
    P9:
    P10:
    +++ WER3 +++:
    Fault bucket 1370256329219382708, type 5
    Cab Id: 0
    Problem signature:
    P1: Microsoft.MicrosoftEdge.Stable_100.0.1185.39_neutral__8wekyb3d8bbwe
    P2: praid:App
    P3: 100.0.1185.44
    P4: 6259413d
    P5: ce80
    P6: 2097152
    P7:
    P8:
    P9:
    P10:
    +++ WER4 +++:
    Fault bucket 1291891459228618989, type 4
    Event Name: APPCRASH
    Cab Id: 0
    Problem signature:
    P1: AUDIODG.EXE
    P2: 10.0.19041.1503
    P3: c40fe88f
    P4: CAF64APO2.dll
    P5: 2.34.0.0
    P6: 579b1842
    P7: c0000005
    P8: 0000000000038d1e
    P9:
    P10:
    +++ WER5 +++:
    Fault bucket , type 0
    Cab Id: 0
    Problem signature:
    P1: AUDIODG.EXE
    P2: 10.0.19041.1503
    P3: c40fe88f
    P4: CAF64APO2.dll
    P5: 2.34.0.0
    P6: 579b1842
    P7: c0000005
    P9:
    P10:
    +++ WER6 +++:
    Event Name: LiveKernelEvent
    Cab Id: 0
    Problem signature:
    P1: 144
    P2: 3003
    P3: ffffa28deddd85b0
    P4: 40010000
    P5: 0
    P6: 10_0_19043
    P7: 0_0
    P8: 768_1
    P9:
    P10:
    +++ WER7 +++:
    Cab Id: 0
    Problem signature:
    P1: 144
    P2: 3003
    P4: 40010000
    P5: 0
    P6: 10_0_19043
    P7: 0_0
    P8: 768_1
    P9:
    P10:
    +++ WER8 +++:
    Fault bucket 2017969574484644857, type 5
    Event Name: AppHangB1
    Cab Id: 0
    Problem signature:
    P1: Cura.exe
    P2: 4.13.1.0
    P3: 600d5330
    P4: 2ba9
    P5: 134217728
    P6:
    P7:
    P8:
    P9:
    P10:
    +++ WER9 +++:
    Fault bucket 1752339515317750388, type 5
    Cab Id: 0
    Problem signature:
    P1: TiWorker.exe
    P2: 10.0.19041.1613
    P4:
    P5:
    P6:
    P7:
    P8:
    P9:
    P10:
    Posted · first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
    i had a bit of trouble with the Cura GUI log filei managed to find my way there but i couldn't find the log file. i looked through each of these folders (see pic) but couldn't find anything that looked like a log file
    unless this is it...
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources._copyLatestDirsIfPresent [502]: Found config: ['C:\\Users\\Ben360\\AppData\\Roaming\\cura', 'C:\\Users\\Ben360\\AppData\\Local\\cura'] and data: ['C:\\Users\\Ben360\\AppData\\Roaming\\cura', 'C:\\Users\\Ben360\\AppData\\Local\\cura']
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Resources._copyLatestDirsIfPresent [506]: Latest config path: None and latest data path: None
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.Qt.QtApplication.initialize [145]: Preferences file not found, ignore and use default language 'en_US'
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-22 08:52:50,485 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager._loadManagementData [199]: User package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json doesn't exist, do nothing
    2022-04-22 08:52:50,485 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-22 08:52:50,485 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-22 08:52:50,500 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-22 08:52:50,563 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-22 08:52:50,610 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-22 08:52:50,641 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-22 08:52:50,672 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-22 08:52:50,704 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-22 08:52:50,750 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-22 08:52:50,782 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-22 08:52:50,827 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-22 08:52:50,858 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-22 08:52:50,890 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-22 08:52:50,921 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-22 08:52:50,952 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-22 08:52:50,983 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-22 08:52:51,015 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-22 08:52:51,061 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-22 08:52:51,093 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-22 08:52:51,124 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-22 08:52:51,140 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-22 08:52:51,186 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-22 08:52:51,249 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-22 08:52:51,296 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-22 08:52:51,327 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-22 08:52:51,358 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-22 08:52:51,492 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-22 08:52:51,523 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-22 08:52:51,570 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-22 08:52:51,617 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-22 08:52:51,648 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-22 08:52:51,679 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-22 08:52:51,726 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-22 08:52:51,757 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-22 08:52:51,789 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-22 08:52:51,820 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-22 08:52:51,867 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-22 08:52:52,351 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-22 08:52:52,417 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-22 08:52:52,417 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-22 08:52:52,636 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-22 08:52:52,714 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-22 08:52:52,714 - INFO - [MainThread] UpdateChecker.UpdateChecker._handleLatestUpdate [166]: Found a new version of the software. Spawning message
    2022-04-22 08:52:52,761 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-22 08:52:52,792 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-22 08:52:52,824 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-22 08:52:52,855 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-22 08:52:52,886 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-22 08:52:52,917 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-22 08:52:52,933 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-22 08:52:52,980 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-22 08:52:52,996 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-22 08:52:53,027 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-22 08:52:53,058 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-22 08:52:53,089 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-22 08:52:53,120 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-22 08:52:53,152 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-22 08:52:53,183 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-22 08:52:53,230 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-22 08:52:53,261 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-22 08:52:53,308 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-22 08:52:53,339 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-22 08:52:53,386 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-22 08:52:53,421 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-22 08:52:53,452 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-22 08:52:53,546 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-22 08:52:53,687 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-22 08:52:53,749 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-22 08:52:53,765 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 6.011648416519165 seconds
    2022-04-22 08:52:53,796 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-22 08:52:53,858 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.062482357025146484
    2022-04-22 08:52:53,890 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [238]: The preferences file cannot be opened or it is corrupted, so we will use default values
    2022-04-22 08:52:53,890 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [245]: The preferences file 'None' cannot be found, will use default values
    2022-04-22 08:52:53,905 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-22 08:52:53,956 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-22 08:53:32,328 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 38.305904388427734 seconds
    2022-04-22 08:53:32,352 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-22 08:53:32,355 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-22 08:53:32,363 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-22 08:53:32,368 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-22 08:53:32,689 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-22 08:53:32,707 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-22 08:53:32,716 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-22 08:53:32,870 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-22 08:53:32,936 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-22 08:53:33,987 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-22 08:53:35,795 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-22 08:53:35,827 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-22 08:53:35,840 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-22 08:53:35,853 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-22 08:53:35,865 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-22 08:53:35,877 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-22 08:53:35,889 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-22 08:53:35,896 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-22 08:53:35,911 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-22 08:53:35,921 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-22 08:53:35,929 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-22 08:53:35,946 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-22 08:53:35,961 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-22 08:53:35,971 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-22 08:53:35,974 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-22 08:53:36,195 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-22 08:53:36,427 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-22 08:53:36,736 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-22 08:53:37,279 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-22 08:53:37,450 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:53:37,455 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:284: TypeError: Cannot read property 'hasRemoteConnection' of null
    2022-04-22 08:53:37,611 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:233: TypeError: Cannot read property 'isEnabled' of null
    2022-04-22 08:53:37,728 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-22 08:53:37,766 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-22 08:53:37,790 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-22 08:53:37,792 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-22 08:53:37,916 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-22 08:53:37,923 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [145]: No auth data to retrieve the access_token from
    2022-04-22 08:53:37,934 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=PostProcessingPlugin:2.2.1&installed_packages=GenericGFFPA:1.4.0&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=MirrorTool:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=SentryLogger:1.0.0&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=PreviewStage:1.0.1&installed_packages=ConsoleLogger:1.0.1&installed_packages=PolyFlexPLA:1.0.1&installed_packages=OBJWriter:1.0.1&installed_packages=UltimakerPC:1.4.0&installed_packages=UltimakerCPE:1.4.0&installed_packages=UltimakerTPU:1.4.0&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=FABtotumTPU:1.4.0&installed_packages=GenericPLA:1.4.0&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=UltimakerBAM:1.4.0&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=VertexDeltaABS:1.4.0&installed_packages=UpdateChecker:1.0.1&installed_packages=SolidView:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=SimpleView:1.0.1&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=UltimakerPLA:1.4.0&installed_packages=TranslateTool:1.0.1&installed_packages=DigitalLibrary:1.1.0&installed_packages=Toolbox:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=UFPWriter:1.0.1&installed_packages=SimulationView:1.0.1&installed_packages=ImageReader:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=GenericPETG:1.4.0&installed_packages=UltimakerABS:1.4.0&installed_packages=SelectionTool:1.0.1&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=UltimakerTPLA:1.4.0&installed_packages=FileLogger:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=STLWriter:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=GCodeReader:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=GCodeProfileReader:1.0.1&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=AMFReader:1.0.0&installed_packages=OBJReader:1.0.1&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=GenericPC:1.4.0&installed_packages=STLReader:1.0.1&installed_packages=3MFReader:1.0.1&installed_packages=TrimeshReader:1.0.0&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=UFPReader:1.0.0&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=CameraTool:1.0.1&installed_packages=UltimakerPP:1.4.0&installed_packages=SupportEraser:1.0.1&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=UltimakerNylon:1.4.0&installed_packages=GCodeGzReader:1.0.1&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=FABtotumNylon:1.4.0&installed_packages=ModelChecker:1.0.1&installed_packages=VertexDeltaPET:1.4.0&installed_packages=LegacyProfileReader:1.0.1&installed_packages=MonitorStage:1.0.1&installed_packages=GenericCPEPlus:1.4.0&installed_packages=GenericABS:1.4.0&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=3MFWriter:1.0.1&installed_packages=UltimakerPVA:1.4.0&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=GenericNylon:1.4.0&installed_packages=CuraEngineBackend:1.0.1&installed_packages=GenericGFFCPE:1.4.0&installed_packages=GenericPP:1.4.0&installed_packages=GenericToughPLA:1.4.0&installed_packages=GenericPVA:1.4.0&installed_packages=RotateTool:1.0.1&installed_packages=ScaleTool:1.0.1&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=FABtotumABS:1.4.0&installed_packages=CuraProfileWriter:1.0.1&installed_packages=PolyWoodPLA:1.0.1&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=FirmwareUpdater:1.0.1&installed_packages=GenericCFFCPE:1.4.0&installed_packages=GCodeWriter:1.0.1&installed_packages=GenericHIPS:1.4.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=LocalContainerProvider:1.0.1&installed_packages=FABtotumPLA:1.4.0&installed_packages=PolyPlusPLA:1.0.1&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1
    2022-04-22 08:53:37,958 - DEBUG - [JobQueueWorker [0]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-22 08:53:37,958 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 52.113537549972534 seconds
    2022-04-22 08:53:37,965 - DEBUG - [JobQueueWorker [0]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-22 08:53:37,977 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-22 08:53:37,985 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [70]: No active GlobalStack, set quality profile model as empty.
    2022-04-22 08:53:37,992 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-22 08:53:37,998 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [38]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
    2022-04-22 08:53:38,352 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-22 08:53:38,385 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-22 08:53:38,391 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-22 08:53:38,396 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-22 08:53:38,403 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-22 08:53:38,407 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-22 08:53:38,413 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-22 08:53:38,454 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-22 08:53:38,471 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-22 08:53:38,487 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-22 08:53:38,499 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-22 08:53:38,527 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-22 08:53:38,551 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-22 08:53:38,576 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-22 08:53:38,594 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-22 08:53:38,612 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-22 08:53:38,628 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-22 08:53:38,659 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-22 08:53:38,716 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-22 08:53:48,595 - INFO - [MainThread] cura.CuraApplication.writeToLog [605]: User accepted the User-Agreement.
    2022-04-22 08:53:52,655 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.startAuthorizationFlow [189]: Starting new OAuth2 flow...
    2022-04-22 08:53:52,660 - DEBUG - [MainThread] cura.OAuth2.LocalAuthorizationServer.start [64]: Starting local web server to handle authorization callback on port 32118
    2022-04-22 08:53:52,675 - DEBUG - [Thread-6] cura.OAuth2.LocalAuthorizationServer._serve_forever [101]: Local web server for authorization has started
    2022-04-22 08:53:58,697 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.025931358337402344 seconds
    2022-04-22 08:55:00,400 - DEBUG - [Thread-7] cura.OAuth2.AuthorizationService._onAuthStateChanged [252]: Got callback from Authorization state. Something went wrong: [None]
    2022-04-22 08:55:00,406 - DEBUG - [Thread-7] cura.OAuth2.LocalAuthorizationServer.stop [81]: Stopping local oauth2 web server...
    2022-04-22 08:55:00,662 - DEBUG - [Thread-7] cura.OAuth2.LocalAuthorizationServer.stop [89]: Local oauth2 web server was shut down
    2022-04-22 08:55:10,880 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.startAuthorizationFlow [189]: Starting new OAuth2 flow...
    2022-04-22 08:55:10,887 - DEBUG - [MainThread] cura.OAuth2.LocalAuthorizationServer.start [64]: Starting local web server to handle authorization callback on port 32118
    2022-04-22 08:55:10,896 - DEBUG - [Thread-8] cura.OAuth2.LocalAuthorizationServer._serve_forever [101]: Local web server for authorization has started
    2022-04-22 08:55:16,895 - DEBUG - [Thread-9] cura.OAuth2.AuthorizationService._onAuthStateChanged [248]: Got callback from Authorization state. The user should now be logged in!
    2022-04-22 08:55:16,898 - DEBUG - [Thread-9] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-22 08:55:16,907 - DEBUG - [Thread-9] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-22 08:55:16,911 - DEBUG - [Thread-9] cura.OAuth2.LocalAuthorizationServer.stop [81]: Stopping local oauth2 web server...
    2022-04-22 08:55:16,947 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Account/UserOperations.qml:48: TypeError: Cannot call method 'charAt' of undefined
    2022-04-22 08:55:16,950 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Account/UserOperations.qml:69:17: Unable to assign [undefined] to QString
    2022-04-22 08:55:16,962 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting packages metadata from server.
    2022-04-22 08:55:16,967 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting authors metadata from server.
    2022-04-22 08:55:16,977 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-22 08:55:16,981 - DEBUG - [MainThread] UM.Logger.debug [131]: Starting a new sync while previous sync was not completed
    2022-04-22 08:55:16,994 - DEBUG - [Thread-9] cura.OAuth2.LocalAuthorizationServer.stop [89]: Local oauth2 web server was shut down
    2022-04-22 08:55:17,982 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-22 08:55:26,954 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.018239259719848633 seconds
    2022-04-22 08:56:18,466 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-22 08:56:21,733 - INFO - [MainThread] cura.Settings.MachineManager.addMachine [397]: Trying to add a machine with the definition id [creality_ender3pro]
    2022-04-22 08:56:22,070 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition creality_ender3pro failed to pickle.
    2022-04-22 08:56:25,009 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 2.9286234378814697 seconds.
    2022-04-22 08:56:25,417 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-22 08:56:25,863 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition creality_base failed to pickle.
    2022-04-22 08:56:25,914 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-22 08:56:25,930 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [197]: Extruder [creality_base_extruder_0 #2] has already been added to this stack [Creality Ender-3 Pro]
    2022-04-22 08:56:25,937 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-22 08:56:26,005 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:56:26,158 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:233: TypeError: Cannot read property 'isEnabled' of null
    2022-04-22 08:56:26,174 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:56:26,182 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:56:26,243 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0029926300048828125 seconds
    2022-04-22 08:56:26,265 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014957904815673828 seconds. 8 input vertices. 8 output vertices.
    2022-04-22 08:56:26,525 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-22 08:56:26,735 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-22 08:56:26,747 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-22 08:56:26,803 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x00000210020154C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-22 08:56:26,891 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsAction.qml:81:27: QML MachineSettingsExtruderTab: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
    2022-04-22 08:56:27,020 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-22 08:56:27,038 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-22 08:56:27,143 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-22 08:56:27,160 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-22 08:56:27,381 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-22 08:56:27,388 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-22 08:56:27,460 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-22 08:56:27,530 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ActionButton.qml:183:5: QML ToolTip: cannot find any window to open popup in.
    2022-04-22 08:56:27,661 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-22 08:56:27,668 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-22 08:56:27,684 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-22 08:56:27,854 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-22 08:56:28,596 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.7s
    2022-04-22 08:56:37,218 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0560908317565918 seconds
    2022-04-22 08:57:06,423 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsAction.qml:81:27: QML MachineSettingsExtruderTab: Detected anchors on an item that is managed by a layout. This is undefined behavior; use Layout.alignment instead.
    2022-04-22 08:57:18,954 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-22 08:57:31,778 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2022-04-22 08:57:31,784 - INFO - [MainThread] cura.CuraApplication.closeApplication [612]: Close application
    2022-04-22 08:57:31,788 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-22 08:57:31,797 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsAction.qml:97: TypeError: Cannot read property 'name' of null
    2022-04-22 08:57:31,804 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsPrinterTab.qml:28: TypeError: Cannot read property 'id' of null
    2022-04-22 08:57:31,808 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/MachineSettings/PrintHeadMinMaxTextField.qml:30: TypeError: Cannot read property 'id' of null
    2022-04-22 08:57:31,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/MachineSettings/PrintHeadMinMaxTextField.qml:30: TypeError: Cannot read property 'id' of null
    2022-04-22 08:57:31,817 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/MachineSettings/PrintHeadMinMaxTextField.qml:30: TypeError: Cannot read property 'id' of null
    2022-04-22 08:57:31,824 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsPrinterTab.qml:316: TypeError: Cannot read property 'maxExtruderCount' of null
    2022-04-22 08:57:31,830 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-22 08:57:31,836 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/plugins/MachineSettingsAction/MachineSettingsExtruderTab.qml:71: TypeError: Cannot read property 'hasVariants' of null
    2022-04-22 08:57:31,848 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:57:31,856 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:57:31,874 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-22 08:57:31,885 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:57:31,893 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-22 08:57:32,223 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [488]: Shutting down cura
    2022-04-22 08:57:32,262 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-22 08:57:32,263 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [360]: Killing engine process
    2022-04-22 08:57:32,406 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [363]: Engine process is killed. Received return code 1
    2022-04-22 08:57:32,432 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/qml/UM/Preferences/PreferencesDialog.qml:113: TypeError: Cannot read property 'resetEnabled' of null
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-23 08:48:08,949 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager._loadManagementData [197]: Loaded user packages management file from C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [119]: Loading plugin configuration file 'C:\Users\Ben360\AppData\Roaming\cura\4.13\plugins.json'
    2022-04-23 08:48:08,949 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-23 08:48:08,949 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-23 08:48:09,011 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-23 08:48:09,042 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-23 08:48:09,074 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-23 08:48:09,105 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-23 08:48:09,136 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-23 08:48:09,199 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-23 08:48:09,230 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-23 08:48:09,277 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-23 08:48:09,308 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-23 08:48:09,339 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-23 08:48:09,386 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-23 08:48:09,417 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-23 08:48:09,449 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-23 08:48:09,480 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-23 08:48:09,527 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-23 08:48:09,558 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-23 08:48:09,589 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-23 08:48:09,620 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-23 08:48:09,667 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-23 08:48:09,745 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-23 08:48:09,777 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-23 08:48:09,808 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-23 08:48:09,862 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-23 08:48:10,017 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-23 08:48:10,048 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-23 08:48:10,080 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-23 08:48:10,142 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-23 08:48:10,189 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-23 08:48:10,220 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-23 08:48:10,283 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-23 08:48:10,329 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-23 08:48:10,392 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-23 08:48:10,423 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-23 08:48:10,470 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-23 08:48:11,079 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-23 08:48:11,142 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-23 08:48:11,142 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-23 08:48:11,360 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-23 08:48:11,423 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-23 08:48:11,454 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-23 08:48:11,501 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-23 08:48:11,532 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-23 08:48:11,564 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-23 08:48:11,595 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-23 08:48:11,626 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-23 08:48:11,657 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-23 08:48:11,689 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-23 08:48:11,720 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-23 08:48:11,751 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-23 08:48:11,782 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-23 08:48:11,829 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-23 08:48:11,860 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-23 08:48:11,892 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-23 08:48:11,923 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-23 08:48:11,954 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-23 08:48:11,985 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-23 08:48:12,017 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-23 08:48:12,048 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-23 08:48:12,079 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-23 08:48:12,110 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-23 08:48:12,142 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-23 08:48:12,173 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-23 08:48:12,235 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-23 08:48:12,267 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-23 08:48:12,267 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 6.0526533126831055 seconds
    2022-04-23 08:48:12,282 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-23 08:48:12,376 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.09369277954101562
    2022-04-23 08:48:12,392 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-23 08:48:12,407 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-23 08:48:21,050 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 8.62756085395813 seconds
    2022-04-23 08:48:21,066 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-23 08:48:21,066 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-23 08:48:21,500 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-23 08:48:21,815 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-23 08:48:21,815 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-23 08:48:23,254 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 1.4391562938690186 seconds.
    2022-04-23 08:48:23,280 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-23 08:48:23,296 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-23 08:48:23,296 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-23 08:48:23,312 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-23 08:48:23,312 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-23 08:48:23,327 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-23 08:48:23,343 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-23 08:48:23,343 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-23 08:48:23,359 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-23 08:48:23,359 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-23 08:48:23,374 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-23 08:48:23,390 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-23 08:48:23,390 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-23 08:48:23,390 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-23 08:48:23,593 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-23 08:48:23,638 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-23 08:48:23,654 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-23 08:48:23,685 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-23 08:48:23,716 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 08:48:23,716 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-23 08:48:23,763 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.015622138977050781 seconds
    2022-04-23 08:48:23,779 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.015622138977050781 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:48:23,810 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 08:48:23,826 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 08:48:23,951 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-23 08:48:24,951 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-23 08:48:24,951 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[f6df1067][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "838b7f22-1ca9-4c76-8cc4-63856da4d7a8", "code": "tokenExpired", "http_status": "403", "title": "The given token has expired.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 08:48:24,966 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 08:48:26,827 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-23 08:48:27,031 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-23 08:48:27,246 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-23 08:48:27,539 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-23 08:48:27,930 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 08:48:28,154 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 08:48:28,352 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 08:48:28,683 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 08:48:28,711 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-23 08:48:28,743 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-23 08:48:28,756 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-23 08:48:28,989 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-23 08:48:29,015 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 08:48:29,032 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=ModelChecker:1.0.1&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=3MFReader:1.0.1&installed_packages=FABtotumABS:1.4.0&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=GenericCPEPlus:1.4.0&installed_packages=GenericGFFPA:1.4.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=ImageReader:1.0.1&installed_packages=PreviewStage:1.0.1&installed_packages=GenericNylon:1.4.0&installed_packages=GenericPP:1.4.0&installed_packages=STLWriter:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=LocalContainerProvider:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=UltimakerPVA:1.4.0&installed_packages=UltimakerTPLA:1.4.0&installed_packages=GenericPVA:1.4.0&installed_packages=FABtotumTPU:1.4.0&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=OBJWriter:1.0.1&installed_packages=Filo3DPLA:1.0.1&installed_packages=Toolbox:1.0.1&installed_packages=UltimakerCPE:1.4.0&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=GCodeReader:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=SelectionTool:1.0.1&installed_packages=LegacyProfileReader:1.0.1&installed_packages=UltimakerPP:1.4.0&installed_packages=MonitorStage:1.0.1&installed_packages=UltimakerPLA:1.4.0&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=UFPWriter:1.0.1&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=UFPReader:1.0.0&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=UltimakerABS:1.4.0&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=SupportEraser:1.0.1&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=PolyPlusPLA:1.0.1&installed_packages=VertexDeltaPET:1.4.0&installed_packages=CuraDrive:1.2.0&installed_packages=UltimakerPC:1.4.0&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=PolyWoodPLA:1.0.1&installed_packages=TrimeshReader:1.0.0&installed_packages=3MFWriter:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=STLReader:1.0.1&installed_packages=CameraTool:1.0.1&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=UltimakerNylon:1.4.0&installed_packages=CuraProfileWriter:1.0.1&installed_packages=GenericPLA:1.4.0&installed_packages=GenericToughPLA:1.4.0&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=GenericGFFCPE:1.4.0&installed_packages=GCodeProfileReader:1.0.1&installed_packages=SentryLogger:1.0.0&installed_packages=GenericABS:1.4.0&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=UltimakerBAM:1.4.0&installed_packages=SimulationView:1.0.1&installed_packages=SolidView:1.0.1&installed_packages=AMFReader:1.0.0&installed_packages=FABtotumNylon:1.4.0&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=CuraEngineBackend:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=GenericPC:1.4.0&installed_packages=PolyFlexPLA:1.0.1&installed_packages=FirmwareUpdater:1.0.1&installed_packages=DigitalLibrary:1.1.0&installed_packages=UpdateChecker:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=GCodeGzReader:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=GCodeWriter:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=ConsoleLogger:1.0.1&installed_packages=GenericHIPS:1.4.0&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=ScaleTool:1.0.1&installed_packages=GenericCFFCPE:1.4.0&installed_packages=SimpleView:1.0.1&installed_packages=FileLogger:1.0.1&installed_packages=TranslateTool:1.0.1&installed_packages=MirrorTool:1.0.1&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=VertexDeltaABS:1.4.0&installed_packages=RotateTool:1.0.1&installed_packages=FABtotumPLA:1.4.0&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=GenericPETG:1.4.0
    2022-04-23 08:48:29,062 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 23.91489267349243 seconds
    2022-04-23 08:48:29,063 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-23 08:48:29,156 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x000001D136B754C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-23 08:48:29,170 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 08:48:29,186 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 08:48:29,616 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-23 08:48:29,777 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 08:48:29,788 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 08:48:30,099 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-23 08:48:30,136 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-23 08:48:30,141 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-23 08:48:30,145 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-23 08:48:30,149 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-23 08:48:30,154 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-23 08:48:30,160 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 08:48:30,193 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-23 08:48:30,208 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-23 08:48:30,223 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 08:48:30,234 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-23 08:48:30,262 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 08:48:30,286 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 08:48:30,308 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 08:48:30,327 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 08:48:30,344 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 08:48:30,360 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-23 08:48:30,385 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 08:48:30,396 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-23 08:48:30,414 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-23 08:48:30,503 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 08:48:30,809 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[57dc36f6][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "7494aea2-ad16-4f43-8c45-e11eb960b008"}'
    2022-04-23 08:48:30,855 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 08:48:30,859 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 08:48:30,864 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 08:48:30,868 - WARNING - [MainThread] UM.Logger.warning [143]: Failed to get a new access token from the server.
    2022-04-23 08:48:31,398 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Account/UserOperations.qml:48: TypeError: Cannot call method 'charAt' of undefined
    2022-04-23 08:48:31,402 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Account/UserOperations.qml:69:17: Unable to assign [undefined] to QString
    2022-04-23 08:48:31,409 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting packages metadata from server.
    2022-04-23 08:48:31,413 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting authors metadata from server.
    2022-04-23 08:48:31,421 - DEBUG - [MainThread] UM.Logger.debug [131]: Starting a new sync while previous sync was not completed
    2022-04-23 08:48:31,426 - DEBUG - [MainThread] UM.Logger.debug [131]: Auth data was successfully loaded
    2022-04-23 08:48:31,501 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 7.7s
    2022-04-23 08:48:31,851 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:48:40,924 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.031243085861206055 seconds
    2022-04-23 08:48:48,995 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/xyzCalibration_cube (2).stl
    2022-04-23 08:48:48,995 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 08:48:49,011 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 08:48:49,011 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 408 vertices
    2022-04-23 08:48:49,026 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.0 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:48:49,026 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 08:48:49,042 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.015618085861206055 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:48:49,099 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D1520A4160>, took 1ms
    2022-04-23 08:48:49,141 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 08:48:49,377 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 08:48:49,719 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:48:49,724 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:48:49,728 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:48:59,208 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.026576995849609375 seconds
    2022-04-23 08:49:06,616 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 08:49:07,955 - INFO - [MainThread] UM.Controller.deleteAllNodesWithMeshData [468]: Clearing scene
    2022-04-23 08:49:07,970 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14291BEE0>, took 4ms
    2022-04-23 08:49:07,974 - INFO - [MainThread] cura.CuraApplication._removeNodesWithLayerData [2042]: Clearing scene
    2022-04-23 08:49:08,557 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 08:49:08,561 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 08:49:08,564 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 08:49:08,568 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 08:49:08,859 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 08:49:10,133 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:10,138 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:10,142 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:32,562 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:49:44,338 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/xyzCalibration_cube (2).stl
    2022-04-23 08:49:44,368 - INFO - [JobQueueWorker [3]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 08:49:44,380 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.000997304916381836 seconds
    2022-04-23 08:49:44,382 - DEBUG - [JobQueueWorker [3]] STLReader.STLReader._read [105]: Loaded a mesh with 408 vertices
    2022-04-23 08:49:44,392 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.002991199493408203 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:49:44,404 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 08:49:44,407 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.003265380859375 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:49:44,446 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14A3604F0>, took 1ms
    2022-04-23 08:49:44,497 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.000,0.000,21.500>), took 1ms
    2022-04-23 08:49:45,089 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:45,095 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:45,099 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:49:46,578 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.024357318878173828 seconds
    2022-04-23 08:49:46,988 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.222,-0.000,-0.025>), took 8ms
    2022-04-23 08:49:47,036 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-1.107,0.000,-0.125>), took 2ms
    2022-04-23 08:49:47,067 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-5.210,0.000,3.476>), took 2ms
    2022-04-23 08:49:47,100 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-4.242,0.000,3.509>), took 2ms
    2022-04-23 08:49:47,135 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-3.682,0.000,2.719>), took 2ms
    2022-04-23 08:49:47,167 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-3.626,0.000,2.685>), took 3ms
    2022-04-23 08:49:47,203 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-5.907,0.000,2.375>), took 4ms
    2022-04-23 08:49:47,241 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-4.605,0.000,3.968>), took 2ms
    2022-04-23 08:49:47,279 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-6.962,0.000,1.410>), took 2ms
    2022-04-23 08:49:47,314 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-4.597,0.000,0.206>), took 2ms
    2022-04-23 08:49:47,352 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-3.950,0.000,0.996>), took 3ms
    2022-04-23 08:49:47,387 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-2.672,0.000,1.868>), took 1ms
    2022-04-23 08:49:47,420 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-4.001,0.000,5.188>), took 1ms
    2022-04-23 08:49:47,454 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-5.843,0.000,6.169>), took 2ms
    2022-04-23 08:49:47,490 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-5.215,0.000,6.655>), took 1ms
    2022-04-23 08:49:47,522 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-7.492,0.000,11.653>), took 2ms
    2022-04-23 08:49:47,558 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-3.773,0.000,8.417>), took 3ms
    2022-04-23 08:49:47,595 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-5.472,0.000,10.536>), took 3ms
    2022-04-23 08:49:47,654 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-3.911,0.000,11.535>), took 3ms
    2022-04-23 08:49:47,695 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-1.741,-0.000,7.663>), took 3ms
    2022-04-23 08:49:47,735 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.191,0.000,2.361>), took 4ms
    2022-04-23 08:49:47,777 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.019,0.000,1.409>), took 4ms
    2022-04-23 08:49:47,833 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.883,0.000,6.775>), took 19ms
    2022-04-23 08:49:47,873 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.108,-0.000,3.120>), took 2ms
    2022-04-23 08:49:47,929 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.323,0.000,0.041>), took 3ms
    2022-04-23 08:49:47,967 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<1.295,-0.000,0.146>), took 3ms
    2022-04-23 08:49:48,009 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<1.935,0.000,-1.098>), took 4ms
    2022-04-23 08:49:48,048 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<2.493,-0.000,-0.608>), took 3ms
    2022-04-23 08:49:48,088 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<2.244,0.000,-1.534>), took 4ms
    2022-04-23 08:49:48,131 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<1.281,-0.000,-1.674>), took 6ms
    2022-04-23 08:49:48,170 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.116,0.000,-0.439>), took 3ms
    2022-04-23 08:49:48,206 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.184,0.000,-1.362>), took 3ms
    2022-04-23 08:49:48,247 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.187,0.000,-1.369>), took 3ms
    2022-04-23 08:49:48,286 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.028,0.000,-1.880>), took 3ms
    2022-04-23 08:49:48,319 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.021,0.000,-1.416>), took 2ms
    2022-04-23 08:49:48,353 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.049,0.000,-0.482>), took 3ms
    2022-04-23 08:49:48,397 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.239,-0.000,-0.928>), took 5ms
    2022-04-23 08:49:48,435 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.027,0.000,-1.936>), took 3ms
    2022-04-23 08:49:48,473 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.067,-0.000,-4.417>), took 3ms
    2022-04-23 08:49:48,506 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.028,0.000,-2.008>), took 1ms
    2022-04-23 08:49:48,537 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.096,0.000,-2.539>), took 2ms
    2022-04-23 08:49:48,567 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.051,0.000,-0.514>), took 2ms
    2022-04-23 08:49:48,613 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.051,0.000,-0.516>), took 3ms
    2022-04-23 08:49:48,645 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.250,0.000,-1.010>), took 2ms
    2022-04-23 08:49:48,675 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.078,0.000,-2.621>), took 2ms
    2022-04-23 08:49:48,705 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.227,0.000,-3.172>), took 2ms
    2022-04-23 08:49:48,735 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.054,0.000,-4.346>), took 1ms
    2022-04-23 08:49:48,767 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.027,-0.000,-2.222>), took 2ms
    2022-04-23 08:49:48,796 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.105,0.000,-1.125>), took 2ms
    2022-04-23 08:49:49,161 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.183,0.000,0.021>), took 5ms
    2022-04-23 08:49:49,209 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.052,-0.000,0.562>), took 3ms
    2022-04-23 08:49:51,559 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.114,-0.000,-1.016>), took 5ms
    2022-04-23 08:49:51,591 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.062,0.000,-2.527>), took 2ms
    2022-04-23 08:49:51,621 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.236,0.000,-2.549>), took 1ms
    2022-04-23 08:49:51,651 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.365,0.000,-4.690>), took 1ms
    2022-04-23 08:49:51,682 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.852,0.000,-3.676>), took 3ms
    2022-04-23 08:49:51,712 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.209,0.000,-4.956>), took 2ms
    2022-04-23 08:49:51,741 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.273,0.000,-4.516>), took 1ms
    2022-04-23 08:49:51,774 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.106,0.000,-2.916>), took 2ms
    2022-04-23 08:49:51,782 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.316,0.000,-0.541>), took 1ms
    2022-04-23 08:49:51,812 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.142,-0.000,-2.351>), took 1ms
    2022-04-23 08:49:51,840 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.046,0.000,-2.402>), took 2ms
    2022-04-23 08:49:51,871 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.145,0.000,-2.409>), took 2ms
    2022-04-23 08:49:51,901 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.117,0.000,-1.239>), took 2ms
    2022-04-23 08:49:51,930 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.060,0.000,-0.621>), took 2ms
    2022-04-23 08:49:52,108 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.118,0.000,1.242>), took 5ms
    2022-04-23 08:49:52,138 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.145,-0.000,2.417>), took 2ms
    2022-04-23 08:49:52,168 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.491,0.000,8.222>), took 1ms
    2022-04-23 08:49:52,198 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.038,0.000,3.998>), took 2ms
    2022-04-23 08:49:52,228 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.594,0.000,9.809>), took 1ms
    2022-04-23 08:49:52,257 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.147,-0.000,6.780>), took 2ms
    2022-04-23 08:49:52,287 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.124,0.000,2.022>), took 2ms
    2022-04-23 08:49:52,318 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.160,0.000,3.030>), took 1ms
    2022-04-23 08:49:52,348 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.122,0.000,1.961>), took 3ms
    2022-04-23 08:49:52,378 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.121,-0.000,1.938>), took 2ms
    2022-04-23 08:49:52,409 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.343,-0.000,1.414>), took 2ms
    2022-04-23 08:49:52,439 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.051,0.000,1.917>), took 2ms
    2022-04-23 08:49:52,469 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<-0.285,0.000,1.860>), took 1ms
    2022-04-23 08:49:52,499 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.054,0.000,0.472>), took 1ms
    2022-04-23 08:50:03,769 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/xyzCalibration_cube (2).stl
    2022-04-23 08:50:03,769 - INFO - [JobQueueWorker [0]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 08:50:03,791 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0012094974517822266 seconds
    2022-04-23 08:50:03,793 - DEBUG - [JobQueueWorker [0]] STLReader.STLReader._read [105]: Loaded a mesh with 408 vertices
    2022-04-23 08:50:03,799 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.0019915103912353516 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:50:03,804 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 08:50:03,811 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.001994609832763672 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 08:50:03,846 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D13CC41EB0>, took 2ms
    2022-04-23 08:50:03,877 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 08:50:04,499 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:50:04,506 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:50:04,510 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 08:50:10,279 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-0.186,0.000,-2.497>), took 9ms
    2022-04-23 08:50:10,310 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-0.776,0.000,-3.427>), took 2ms
    2022-04-23 08:50:10,342 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-4.767,0.000,-18.079>), took 2ms
    2022-04-23 08:50:10,374 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.148,0.000,-9.898>), took 1ms
    2022-04-23 08:50:10,403 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.880,0.000,-4.050>), took 1ms
    2022-04-23 08:50:10,433 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.200,0.000,-0.135>), took 2ms
    2022-04-23 08:50:10,465 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.860,0.000,-1.178>), took 2ms
    2022-04-23 08:50:10,500 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-2.966,0.000,-3.269>), took 1ms
    2022-04-23 08:50:10,530 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-2.614,0.000,-1.279>), took 1ms
    2022-04-23 08:50:10,562 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-2.623,0.000,-1.298>), took 3ms
    2022-04-23 08:50:10,593 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.214,0.000,-0.137>), took 2ms
    2022-04-23 08:50:10,624 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.589,0.000,-0.637>), took 1ms
    2022-04-23 08:50:10,653 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-4.858,0.000,-0.548>), took 1ms
    2022-04-23 08:50:10,686 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-3.887,0.000,-0.445>), took 3ms
    2022-04-23 08:50:10,718 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-2.919,0.000,0.653>), took 2ms
    2022-04-23 08:50:10,748 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.783,0.000,3.254>), took 2ms
    2022-04-23 08:50:10,781 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.947,0.000,2.208>), took 2ms
    2022-04-23 08:50:10,812 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.128,0.000,3.221>), took 3ms
    2022-04-23 08:50:10,841 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-5.365,0.000,1.258>), took 1ms
    2022-04-23 08:50:10,872 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.414,0.000,-0.160>), took 2ms
    2022-04-23 08:50:10,916 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-4.139,0.000,1.387>), took 5ms
    2022-04-23 08:50:10,946 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-3.055,0.000,-0.345>), took 3ms
    2022-04-23 08:50:10,976 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-1.410,0.000,-0.159>), took 3ms
    2022-04-23 08:50:11,007 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-0.875,0.000,0.820>), took 1ms
    2022-04-23 08:50:11,036 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<-0.937,0.000,-0.106>), took 1ms
    2022-04-23 08:50:11,357 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<0.234,0.000,0.026>), took 2ms
    2022-04-23 08:50:11,387 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<0.469,0.000,0.053>), took 1ms
    2022-04-23 08:50:11,417 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<0.830,0.000,1.945>), took 1ms
    2022-04-23 08:50:11,448 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'xyzCalibration_cube (2).stl(2)'>,trans.=<0.701,0.000,0.079>), took 1ms
    2022-04-23 08:50:33,162 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:50:33,270 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 08:50:33,279 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 08:50:33,290 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 08:50:33,316 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 08:50:33,337 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 08:50:33,534 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 08:50:33,535 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 08:50:33,870 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.33545756340026855 seconds
    2022-04-23 08:50:33,988 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="08:50:33" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="False" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 08:50:33,988 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 08:50:34,003 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 08:50:34,003 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 08:50:34,019 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 08:50:34,019 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 08:50:34,019 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 08:50:34,019 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 08:50:34,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 08:50:34,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 08:50:34,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 08:50:34,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="20" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 08:50:34,050 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 08:50:34,050 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 08:50:34,050 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 08:50:34,050 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 08:50:34,050 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 08:50:34,066 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 08:50:34,066 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 08:50:34,066 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 08:50:34,066 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 08:50:34,066 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="25.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="25.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="20" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="50.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="25.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="25.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="25.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="50.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0" -e0 -l "1" -s extruder_nr="0"
    2022-04-23 08:50:35,356 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.8216221332550049 seconds
    2022-04-23 08:50:35,357 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 2}
    2022-04-23 08:50:35,357 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 08:50:35,362 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 08:50:35,375 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 08:50:35,380 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 08:50:35,381 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 08:50:38,348 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 08:50:38,404 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 08:50:38,406 - INFO - [MainThread] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 08:50:38,423 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 08:50:38,424 - DEBUG - [MainThread] STLReader.STLReader._read [105]: Loaded a mesh with 12612 vertices
    2022-04-23 08:50:38,429 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\simulationview_composite.shader]...
    2022-04-23 08:50:38,498 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 08:50:38,660 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.16256499290466309 seconds
    2022-04-23 08:50:38,809 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 08:50:38,828 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d.shader]...
    2022-04-23 08:50:38,911 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d_shadow.shader]...
    2022-04-23 08:50:38,964 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 08:50:38,975 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 08:50:38,984 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 08:50:39,045 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 08:51:12,478 - DEBUG - [MainThread] RemovableDriveOutputDevice.RemovableDriveOutputDevice.requestWrite [85]: Writing to E:/CE3PRO_xyzCalibration_cube (2).gcode
    2022-04-23 08:51:12,552 - INFO - [JobQueueWorker [3]] GCodeWriter.GCodeWriter._serialiseSettings [200]: No custom settings found, not writing settings to g-code.
    2022-04-23 08:51:12,556 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.048840999603271484 seconds
    2022-04-23 08:51:14,076 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 08:51:17,352 - INFO - [MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [44]: Attempting to eject the device
    2022-04-23 08:51:17,353 - INFO - [MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [51]: Successfully ejected the device
    2022-04-23 08:51:34,032 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:51:47,616 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/MODELS/3D printer tests/CE3PRO_xyzCalibration_cube (2).gcode]...
    2022-04-23 08:51:47,624 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/MODELS/3D printer tests/CE3PRO_xyzCalibration_cube (2).gcode in text mode
    2022-04-23 08:51:47,659 - INFO - [JobQueueWorker [0]] GCodeWriter.GCodeWriter._serialiseSettings [200]: No custom settings found, not writing settings to g-code.
    2022-04-23 08:51:47,669 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.02293848991394043 seconds
    2022-04-23 08:51:48,378 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 08:51:57,666 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.01538228988647461 seconds
    2022-04-23 08:52:34,933 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:53:35,278 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:54:36,696 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:55:37,263 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:56:37,630 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:57:38,561 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 08:57:38,566 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 08:57:39,094 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:57:39,168 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 08:57:49,185 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.020299196243286133 seconds
    2022-04-23 08:58:40,273 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 08:59:41,210 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:00:41,745 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:01:44,784 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:02:45,175 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:03:45,564 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:04:46,171 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:05:46,669 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:06:46,840 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:06:46,845 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:06:47,190 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:06:47,517 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:06:57,555 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.018490314483642578 seconds
    2022-04-23 09:07:48,971 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:08:49,878 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:09:50,211 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:10:50,748 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:11:51,126 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:12:52,896 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:13:53,641 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:14:54,532 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:15:55,110 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:15:55,119 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:15:55,568 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:15:55,777 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:16:05,801 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.021143198013305664 seconds
    2022-04-23 09:16:56,208 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:17:56,561 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:18:57,002 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:19:57,925 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:20:58,337 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:21:58,724 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:22:59,296 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:23:59,767 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:24:59,902 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:24:59,908 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:25:00,248 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:25:00,491 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:25:10,540 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.020954370498657227 seconds
    2022-04-23 09:26:00,985 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:27:02,944 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:28:03,653 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:29:06,649 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:30:07,143 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:31:07,505 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:32:08,094 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:33:08,454 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:34:08,538 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:34:08,553 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:34:08,916 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:34:09,193 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:34:19,217 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.017544269561767578 seconds
    2022-04-23 09:35:09,306 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:36:09,718 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:37:10,734 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:38:11,428 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:39:11,787 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:40:12,388 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:41:12,736 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:42:13,622 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:43:13,649 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:43:13,666 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:43:14,035 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:43:14,320 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:43:24,345 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.017643213272094727 seconds
    2022-04-23 09:44:14,385 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:45:17,272 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:46:20,062 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:47:20,546 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:48:20,916 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:49:22,855 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:50:23,578 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:51:23,978 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:52:25,561 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 09:52:25,570 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 09:52:25,906 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:52:26,931 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 09:52:36,959 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.01795172691345215 seconds
    2022-04-23 09:53:26,696 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:54:27,563 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:55:33,452 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:56:33,913 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:57:36,417 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:58:36,988 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 09:59:37,358 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:00:39,170 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:01:39,471 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:01:39,485 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:01:39,874 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:01:40,125 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:01:50,177 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03275418281555176 seconds
    2022-04-23 10:02:41,768 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:03:43,620 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:04:44,011 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:05:44,493 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:06:47,400 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:07:47,851 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:08:48,422 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:09:49,123 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:10:54,298 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:10:54,309 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:10:54,935 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:10:54,948 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:11:04,951 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.01814579963684082 seconds
    2022-04-23 10:11:55,679 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:12:58,911 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:14:02,238 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:15:02,615 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:16:03,146 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:17:03,934 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:18:04,494 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:19:07,203 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:20:09,046 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:20:09,046 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:20:09,914 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:20:11,684 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:20:21,706 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.015622377395629883 seconds
    2022-04-23 10:21:10,393 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:22:11,195 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:23:12,542 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:24:13,130 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:25:13,801 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:26:14,175 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:27:14,647 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:28:15,758 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:29:15,752 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:29:15,768 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:29:16,134 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:29:16,408 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:29:26,435 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.015302419662475586 seconds
    2022-04-23 10:30:16,499 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:31:16,876 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:32:18,012 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:33:18,542 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:34:19,796 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:35:20,151 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:36:20,954 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:37:21,415 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:38:21,806 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:38:21,824 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:38:22,273 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:38:22,484 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:38:32,523 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.02071547508239746 seconds
    2022-04-23 10:39:24,176 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:40:27,217 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:41:27,985 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:42:28,561 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:43:30,401 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:44:30,861 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:45:15,752 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D1520BB3A0> <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14A360400>, took 7ms
    2022-04-23 10:45:15,944 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 10:45:15,948 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 10:45:15,952 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 10:45:15,955 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 10:45:15,959 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 10:45:15,964 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 10:45:15,967 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 10:45:15,970 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 10:45:16,660 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 10:45:20,106 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 10:45:20,122 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 10:45:20,181 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 10:45:20,407 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 10:45:31,614 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:46:32,558 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:46:57,470 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.014216899871826172 seconds
    2022-04-23 10:47:34,045 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:47:34,045 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:47:34,462 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:47:34,809 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:47:44,837 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0 seconds
    2022-04-23 10:48:35,135 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:49:36,136 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:50:38,415 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:51:38,873 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:52:39,340 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:53:39,803 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:54:40,765 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:55:41,344 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:56:41,564 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 10:56:41,569 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 10:56:41,936 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:56:42,345 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 10:56:52,385 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0193479061126709 seconds
    2022-04-23 10:57:42,395 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:58:42,753 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 10:59:43,088 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:00:43,427 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:01:44,218 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:02:39,858 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/firstlayer (1).gcode
    2022-04-23 11:02:39,858 - INFO - [MainThread] UM.Controller.deleteAllNodesWithMeshData [468]: Clearing scene
    2022-04-23 11:02:39,858 - INFO - [MainThread] cura.CuraApplication._removeNodesWithLayerData [2042]: Clearing scene
    2022-04-23 11:02:39,882 - DEBUG - [JobQueueWorker [1]] GCodeReader.FlavorParser.processGCodeStream [315]: Preparing to load g-code
    2022-04-23 11:02:39,890 - DEBUG - [JobQueueWorker [1]] GCodeReader.FlavorParser.processGCodeStream [355]: Parsing g-code...
    2022-04-23 11:02:39,965 - DEBUG - [JobQueueWorker [1]] GCodeReader.FlavorParser.processGCodeStream [485]: Finished parsing g-code.
    2022-04-23 11:02:39,968 - DEBUG - [JobQueueWorker [1]] GCodeReader.FlavorParser.processGCodeStream [496]: G-code loading finished.
    2022-04-23 11:02:39,976 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 11:02:40,041 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14AB72970>, took 1ms
    2022-04-23 11:02:40,064 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=0), took 0ms
    2022-04-23 11:02:40,097 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 11:02:40,167 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 11:02:40,190 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 11:02:40,296 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 11:02:40,317 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 11:02:40,324 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 11:02:40,799 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.7s
    2022-04-23 11:02:44,667 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:02:50,346 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.003526926040649414 seconds
    2022-04-23 11:03:09,423 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 11:03:09,423 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 11:03:09,469 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 11:03:09,676 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 11:03:15,045 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/PTFE_CLIP.STL
    2022-04-23 11:03:15,057 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 11:03:15,069 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.000997781753540039 seconds
    2022-04-23 11:03:15,071 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 9900 vertices
    2022-04-23 11:03:15,122 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.03997516632080078 seconds. 422 input vertices. 422 output vertices.
    2022-04-23 11:03:15,147 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 11:03:15,198 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.035454750061035156 seconds. 422 input vertices. 422 output vertices.
    2022-04-23 11:03:15,232 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14AA50190>, took 27ms
    2022-04-23 11:03:15,257 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 11:03:15,878 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:03:15,885 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:03:15,890 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:03:25,302 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.027648448944091797 seconds
    2022-04-23 11:03:32,018 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 11:03:32,021 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 11:03:32,030 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.284>), took 2ms
    2022-04-23 11:03:32,042 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 11:03:32,056 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 11:03:32,061 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 11:03:32,073 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.318>), took 2ms
    2022-04-23 11:03:32,089 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.353>), took 2ms
    2022-04-23 11:03:32,108 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.283>), took 3ms
    2022-04-23 11:03:32,130 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.246>), took 4ms
    2022-04-23 11:03:32,148 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.353>), took 3ms
    2022-04-23 11:03:32,166 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.033>), took 2ms
    2022-04-23 11:03:32,192 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.282>), took 4ms
    2022-04-23 11:03:32,213 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.214>), took 4ms
    2022-04-23 11:03:32,235 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.571>), took 4ms
    2022-04-23 11:03:32,261 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.040>), took 8ms
    2022-04-23 11:03:32,284 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.109>), took 4ms
    2022-04-23 11:03:32,295 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 11:03:32,302 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 11:03:32,307 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 11:03:32,311 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 11:03:32,318 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 11:03:32,320 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.867>), took 17ms
    2022-04-23 11:03:32,324 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 11:03:32,325 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 11:03:32,339 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 11:03:32,342 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 11:03:32,351 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 11:03:32,351 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 11:03:32,354 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 11:03:32,360 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 11:03:32,364 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 11:03:32,369 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 11:03:32,375 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 11:03:32,377 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.544>), took 16ms
    2022-04-23 11:03:32,381 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 11:03:32,384 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 11:03:32,399 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.714>), took 2ms
    2022-04-23 11:03:32,443 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.294>), took 4ms
    2022-04-23 11:03:32,482 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.298>), took 5ms
    2022-04-23 11:03:32,498 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.296>), took 2ms
    2022-04-23 11:03:32,524 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.556>), took 5ms
    2022-04-23 11:03:32,541 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.595>), took 2ms
    2022-04-23 11:03:32,569 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.900>), took 3ms
    2022-04-23 11:03:32,588 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.301>), took 4ms
    2022-04-23 11:03:32,605 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.908>), took 4ms
    2022-04-23 11:03:32,620 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.601>), took 1ms
    2022-04-23 11:03:32,980 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.342>), took 3ms
    2022-04-23 11:03:32,995 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.302>), took 2ms
    2022-04-23 11:03:33,020 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.957>), took 2ms
    2022-04-23 11:03:33,038 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.811>), took 3ms
    2022-04-23 11:03:33,054 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,4.213>), took 2ms
    2022-04-23 11:03:33,072 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.884>), took 2ms
    2022-04-23 11:03:33,088 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,3.548>), took 2ms
    2022-04-23 11:03:33,105 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.157>), took 1ms
    2022-04-23 11:03:33,121 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,7.242>), took 3ms
    2022-04-23 11:03:33,138 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.426>), took 3ms
    2022-04-23 11:03:33,155 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,7.475>), took 4ms
    2022-04-23 11:03:33,172 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.703>), took 2ms
    2022-04-23 11:03:33,188 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.478>), took 1ms
    2022-04-23 11:03:33,204 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,3.618>), took 1ms
    2022-04-23 11:03:33,221 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,5.792>), took 3ms
    2022-04-23 11:03:33,237 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.441>), took 1ms
    2022-04-23 11:03:33,255 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,4.331>), took 2ms
    2022-04-23 11:03:33,287 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,3.134>), took 3ms
    2022-04-23 11:03:33,304 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.628>), took 3ms
    2022-04-23 11:03:33,321 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.628>), took 1ms
    2022-04-23 11:03:33,338 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.407>), took 3ms
    2022-04-23 11:03:33,530 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.214>), took 6ms
    2022-04-23 11:03:33,550 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.623>), took 2ms
    2022-04-23 11:03:33,570 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-2.095>), took 2ms
    2022-04-23 11:03:33,588 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-2.085>), took 3ms
    2022-04-23 11:03:33,607 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-3.256>), took 4ms
    2022-04-23 11:03:33,622 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.111>), took 1ms
    2022-04-23 11:03:33,638 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-4.735>), took 3ms
    2022-04-23 11:03:33,655 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-2.820>), took 1ms
    2022-04-23 11:03:33,672 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-3.095>), took 3ms
    2022-04-23 11:03:33,688 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-4.234>), took 1ms
    2022-04-23 11:03:33,704 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-7.796>), took 1ms
    2022-04-23 11:03:33,721 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.359>), took 3ms
    2022-04-23 11:03:33,738 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.827>), took 3ms
    2022-04-23 11:03:33,755 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-4.160>), took 3ms
    2022-04-23 11:03:33,957 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.299>), took 9ms
    2022-04-23 11:03:33,976 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.299>), took 2ms
    2022-04-23 11:03:34,156 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.598>), took 7ms
    2022-04-23 11:03:34,187 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.594>), took 3ms
    2022-04-23 11:03:34,220 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.300>), took 2ms
    2022-04-23 11:03:34,238 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.868>), took 3ms
    2022-04-23 11:03:34,255 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.571>), took 1ms
    2022-04-23 11:03:34,270 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.569>), took 1ms
    2022-04-23 11:03:34,315 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.273>), took 1ms
    2022-04-23 11:03:34,372 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.268>), took 2ms
    2022-04-23 11:03:34,417 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.270>), took 3ms
    2022-04-23 11:03:34,472 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.583>), took 2ms
    2022-04-23 11:03:34,504 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.820>), took 3ms
    2022-04-23 11:03:34,521 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.174>), took 3ms
    2022-04-23 11:03:34,538 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-1.149>), took 2ms
    2022-04-23 11:03:34,554 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.877>), took 3ms
    2022-04-23 11:03:34,571 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.917>), took 3ms
    2022-04-23 11:03:34,588 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.891>), took 1ms
    2022-04-23 11:03:34,605 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.574>), took 1ms
    2022-04-23 11:03:34,621 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.606>), took 3ms
    2022-04-23 11:03:34,638 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,-0.614>), took 2ms
    2022-04-23 11:03:34,711 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.287>), took 3ms
    2022-04-23 11:03:34,737 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.287>), took 3ms
    2022-04-23 11:03:34,754 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.291>), took 3ms
    2022-04-23 11:03:34,788 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.571>), took 4ms
    2022-04-23 11:03:34,822 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.285>), took 1ms
    2022-04-23 11:03:34,853 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.285>), took 3ms
    2022-04-23 11:03:34,872 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.287>), took 4ms
    2022-04-23 11:03:34,888 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.566>), took 1ms
    2022-04-23 11:03:35,124 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.281>), took 1ms
    2022-04-23 11:03:35,169 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.282>), took 1ms
    2022-04-23 11:03:35,191 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.842>), took 3ms
    2022-04-23 11:03:35,207 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.561>), took 2ms
    2022-04-23 11:03:35,236 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.768>), took 2ms
    2022-04-23 11:03:35,254 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,4.231>), took 2ms
    2022-04-23 11:03:35,272 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,3.906>), took 4ms
    2022-04-23 11:03:35,287 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.259>), took 2ms
    2022-04-23 11:03:35,304 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.834>), took 3ms
    2022-04-23 11:03:35,337 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.515>), took 3ms
    2022-04-23 11:03:35,354 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.832>), took 3ms
    2022-04-23 11:03:35,372 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.789>), took 2ms
    2022-04-23 11:03:35,388 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.564>), took 2ms
    2022-04-23 11:03:35,404 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.251>), took 2ms
    2022-04-23 11:03:35,438 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.279>), took 1ms
    2022-04-23 11:03:35,470 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.533>), took 3ms
    2022-04-23 11:03:35,487 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.528>), took 2ms
    2022-04-23 11:03:35,504 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.802>), took 3ms
    2022-04-23 11:03:35,512 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.318>), took 2ms
    2022-04-23 11:03:35,526 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,9.140>), took 2ms
    2022-04-23 11:03:35,552 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.446>), took 3ms
    2022-04-23 11:03:35,571 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.982>), took 3ms
    2022-04-23 11:03:35,587 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.700>), took 1ms
    2022-04-23 11:03:35,620 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.237>), took 2ms
    2022-04-23 11:03:35,638 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.538>), took 3ms
    2022-04-23 11:03:35,654 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,2.022>), took 2ms
    2022-04-23 11:03:35,671 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,3.116>), took 2ms
    2022-04-23 11:03:35,688 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,1.540>), took 2ms
    2022-04-23 11:03:35,703 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.218>), took 1ms
    2022-04-23 11:03:35,737 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.398>), took 3ms
    2022-04-23 11:03:35,753 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.197>), took 1ms
    2022-04-23 11:03:35,771 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.196>), took 4ms
    2022-04-23 11:03:35,788 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.828>), took 3ms
    2022-04-23 11:03:35,804 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.195>), took 1ms
    2022-04-23 11:03:35,902 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.219>), took 3ms
    2022-04-23 11:03:35,939 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.214>), took 2ms
    2022-04-23 11:03:35,957 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,trans.=<0.000,0.000,0.218>), took 2ms
    2022-04-23 11:03:45,093 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:04:45,443 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:05:45,440 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:05:45,456 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:05:45,967 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:05:46,795 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:05:56,806 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.021692514419555664 seconds
    2022-04-23 11:06:46,328 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:07:49,798 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:08:50,537 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:09:50,938 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:10:52,529 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:11:54,806 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:12:55,460 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:13:56,435 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:14:56,462 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:14:56,473 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:14:56,820 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:14:56,976 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:15:07,005 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0 seconds
    2022-04-23 11:15:57,411 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:16:59,178 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:17:00,059 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 11:17:07,219 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 14ms
    2022-04-23 11:17:07,583 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:08,456 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 6ms
    2022-04-23 11:17:08,567 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.25881904510252074,0.0,0.0,w=0.9659258262890683>), took 5ms
    2022-04-23 11:17:08,667 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:13,653 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<-0.13052619222005157,-0.0,-0.0,w=0.9914448613738104>), took 6ms
    2022-04-23 11:17:14,500 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<-0.13052619222005157,-0.0,-0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 11:17:15,068 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<-0.13052619222005157,-0.0,-0.0,w=0.9914448613738104>), took 11ms
    2022-04-23 11:17:17,226 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: PlatformPhysicsOp.(trans.=<0.000,-0.252,0.000>), took 1ms
    2022-04-23 11:17:25,538 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: LayFlatOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>), took 0ms
    2022-04-23 11:17:28,515 - INFO - [MainThread] UM.Controller.deleteAllNodesWithMeshData [468]: Clearing scene
    2022-04-23 11:17:28,540 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14AA51D60>, took 12ms
    2022-04-23 11:17:28,545 - INFO - [MainThread] cura.CuraApplication._removeNodesWithLayerData [2042]: Clearing scene
    2022-04-23 11:17:29,086 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 11:17:29,090 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 11:17:29,093 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 11:17:29,097 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 11:17:29,382 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 11:17:30,831 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:17:30,836 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:17:30,840 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 11:17:45,871 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 11:17:46,112 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:46,578 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:47,215 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 11:17:48,196 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 3ms
    2022-04-23 11:17:49,729 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:49,844 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 11:17:49,961 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<0.3826834323650898,0.0,0.0,w=0.9238795325112867>), took 5ms
    2022-04-23 11:17:50,379 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<-0.13052619222005157,-0.0,-0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 11:17:50,495 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'PTFE_CLIP.STL'>,rot.=Q<-0.3826834323650898,-0.0,-0.0,w=0.9238795325112867>), took 5ms
    2022-04-23 11:17:51,628 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: PlatformPhysicsOp.(trans.=<0.000,-3.193,0.000>), took 1ms
    2022-04-23 11:18:00,024 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:18:12,300 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 11:18:12,308 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 11:18:12,314 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 11:18:12,333 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 11:18:12,345 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 11:18:12,623 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 11:18:12,624 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 11:18:12,794 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.17062902450561523 seconds
    2022-04-23 11:18:12,882 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="11:18:12" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="False" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 11:18:12,882 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 11:18:12,882 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 11:18:12,898 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 11:18:12,898 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 11:18:12,898 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 11:18:12,913 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 11:18:12,913 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 11:18:12,913 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 11:18:12,913 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 11:18:12,929 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 11:18:12,929 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="20" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 11:18:12,929 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 11:18:12,929 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 11:18:12,929 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 11:18:12,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 11:18:12,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 11:18:12,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 11:18:12,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 11:18:12,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 11:18:12,960 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 11:18:12,960 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="25.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="25.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="20" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="50.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="25.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="25.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="25.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="50.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 11:18:13,444 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 0.8199093341827393 seconds
    2022-04-23 11:18:13,444 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 11:18:13,444 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 11:18:13,455 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 11:18:13,460 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 11:18:13,463 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 11:18:13,464 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 11:18:18,252 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 11:18:18,285 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 11:18:18,329 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 11:18:18,514 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.1833817958831787 seconds
    2022-04-23 11:18:18,609 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 11:19:00,659 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:19:10,947 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.024723052978515625 seconds
    2022-04-23 11:19:24,256 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_PTFE_CLIP.gcode]...
    2022-04-23 11:19:24,271 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_PTFE_CLIP.gcode in text mode
    2022-04-23 11:19:24,345 - INFO - [JobQueueWorker [2]] GCodeWriter.GCodeWriter._serialiseSettings [200]: No custom settings found, not writing settings to g-code.
    2022-04-23 11:19:24,350 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.04830765724182129 seconds
    2022-04-23 11:19:25,799 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 11:19:34,335 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.014965057373046875 seconds
    2022-04-23 11:20:01,468 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:21:02,434 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:22:03,123 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:23:04,486 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:24:05,241 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:24:05,241 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:24:05,714 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:24:05,719 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:24:15,731 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.016928672790527344 seconds
    2022-04-23 11:25:06,211 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:26:06,860 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:27:07,937 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:28:08,255 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:29:08,915 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:30:12,361 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:31:12,765 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:32:13,676 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:33:15,147 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:33:15,163 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:33:15,672 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:33:15,717 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:33:25,702 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0 seconds
    2022-04-23 11:34:16,713 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:35:17,228 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:36:17,727 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:37:18,225 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:38:18,971 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:39:19,484 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:40:19,877 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:41:20,463 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:42:23,544 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:42:23,559 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:42:23,921 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:42:24,108 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:42:34,130 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.019532203674316406 seconds
    2022-04-23 11:43:26,851 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:44:27,336 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:45:28,005 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:46:28,549 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:47:29,029 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:48:30,880 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:49:32,625 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:50:33,145 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:51:34,887 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 11:51:34,904 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 11:51:35,301 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:51:35,420 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 11:51:45,452 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.028566360473632812 seconds
    2022-04-23 11:52:36,847 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:53:37,980 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:54:38,495 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:55:39,704 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:56:40,045 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:57:40,484 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:58:40,888 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 11:59:41,406 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:00:43,043 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:00:43,058 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:00:43,691 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:00:43,704 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:00:53,720 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.018949270248413086 seconds
    2022-04-23 12:01:44,277 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:02:45,753 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:03:47,331 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:04:47,737 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:05:48,812 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:06:49,469 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:08:27,136 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[1614ef64][get][PyQt5.QtCore.QUrl('https://api.ultimaker.com/cura-packages/v1/user/packages')][timeout=10][no-data] got an QNetworkReplyError Temporary network failure.. The server returned: b''
    2022-04-23 12:08:27,319 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[a81e20a8][get][PyQt5.QtCore.QUrl('https://api.ultimaker.com/connect/v1/clusters?status=active')][timeout=10][no-data] got an QNetworkReplyError Temporary network failure.. The server returned: b''
    2022-04-23 12:08:27,323 - WARNING - [MainThread] Toolbox.src.CloudSync.CloudPackageChecker._onUserPackagesRequestFinished [74]: Requesting user packages failed, response code None while trying to connect to PyQt5.QtCore.QUrl('https://api.ultimaker.com/cura-packages/v1/user/packages')
    2022-04-23 12:09:27,760 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:10:29,454 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:10:29,506 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:10:29,888 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:10:30,205 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:10:40,281 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04069161415100098 seconds
    2022-04-23 12:11:30,370 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:12:30,802 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:13:32,688 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:14:33,121 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:15:34,470 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:16:35,227 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:17:35,786 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:18:36,156 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:19:36,352 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:19:36,361 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:19:36,704 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:19:37,123 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:19:47,147 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.026381492614746094 seconds
    2022-04-23 12:20:40,262 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:21:40,683 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:22:41,201 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:23:42,560 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:24:42,931 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:25:43,697 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:26:44,091 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:27:44,509 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:28:44,555 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:28:44,586 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:28:44,964 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:28:45,329 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:28:55,384 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.029274463653564453 seconds
    2022-04-23 12:29:46,906 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:30:47,293 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:31:47,710 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:32:48,135 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:33:50,795 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:34:51,210 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:35:52,510 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:36:52,994 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:37:53,027 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:37:53,043 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:37:53,416 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:37:53,754 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:38:03,803 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.025375843048095703 seconds
    2022-04-23 12:38:54,559 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:39:55,515 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:40:56,194 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:41:59,126 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:43:00,995 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:44:02,471 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:45:03,388 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:46:05,927 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:47:11,257 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:47:11,267 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:47:11,652 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:47:13,566 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:47:23,618 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03618884086608887 seconds
    2022-04-23 12:48:12,274 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:49:12,731 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:50:13,077 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:51:15,920 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:52:16,347 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:53:16,684 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:54:17,167 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:55:17,676 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:56:17,697 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 12:56:17,723 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 12:56:18,129 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:56:18,599 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 12:56:28,676 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03628110885620117 seconds
    2022-04-23 12:57:18,604 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:58:19,031 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 12:59:19,472 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:00:22,453 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:01:23,132 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:02:23,862 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:03:24,248 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:04:24,719 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:05:24,748 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 13:05:24,773 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:05:25,134 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:05:25,527 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 13:05:35,572 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03270411491394043 seconds
    2022-04-23 13:06:25,802 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:07:26,161 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:08:26,681 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:09:31,706 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:10:32,438 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:11:33,238 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:12:10,884 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 13:12:10,891 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 13:12:11,075 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 13:12:11,459 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 13:12:12,388 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 13:12:19,233 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/guess who support 3.0.stl
    2022-04-23 13:12:19,245 - INFO - [JobQueueWorker [3]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 13:12:19,264 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0013110637664794922 seconds
    2022-04-23 13:12:19,268 - DEBUG - [JobQueueWorker [3]] STLReader.STLReader._read [105]: Loaded a mesh with 1800 vertices
    2022-04-23 13:12:19,288 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.01055145263671875 seconds. 46 input vertices. 46 output vertices.
    2022-04-23 13:12:19,304 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 13:12:19,309 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.0037467479705810547 seconds. 46 input vertices. 46 output vertices.
    2022-04-23 13:12:19,367 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14A361CA0>, took 2ms
    2022-04-23 13:12:19,412 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'guess who support 3.0.stl'>,rot.=Q<0.0,4.0,0.0,w=-2.4492935982947064e-16>) TranslateOp.(node=<CuraSceneNode object: 'guess who support 3.0.stl'>,trans.=<2.907,0.000,25.700>), took 2ms
    2022-04-23 13:12:20,040 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:12:20,050 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:12:20,059 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:12:29,513 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.05990171432495117 seconds
    2022-04-23 13:12:30,069 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14A381A60>, took 18ms
    2022-04-23 13:12:34,068 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:12:43,446 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 13:12:43,453 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 13:12:43,461 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 13:12:43,488 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 13:12:43,512 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 13:12:43,731 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 13:12:43,731 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 13:12:43,738 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 13:12:43,899 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 13:12:44,090 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 13:12:44,096 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 13:12:44,164 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.43329644203186035 seconds
    2022-04-23 13:12:44,344 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:12:44,352 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 13:12:44,361 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 13:12:44,365 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 13:12:44,367 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 13:12:44,378 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:12:44,386 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 13:12:44,386 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 13:12:44,394 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 13:12:44,402 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 13:12:44,411 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:12:44,411 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 13:12:44,419 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 13:12:44,427 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 13:12:44,427 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 13:12:44,436 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:12:44,437 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 13:12:44,444 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 13:12:44,461 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="13:12:43" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="False" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 13:12:44,472 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 13:12:44,477 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 13:12:44,486 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 13:12:44,494 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 13:12:44,502 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 13:12:44,511 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 13:12:44,520 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 13:12:44,528 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 13:12:44,536 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 13:12:44,544 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 13:12:44,553 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="20" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 13:12:44,563 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:12:44,571 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 13:12:44,579 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:12:44,579 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 13:12:44,587 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 13:12:44,594 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 13:12:44,602 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 13:12:44,611 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:12:44,619 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:12:44,627 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="25.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="18.75" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="25.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="25.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.0" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="20" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="50.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="25.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="25.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="25.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="25.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="50.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 13:12:45,295 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.5627458095550537 seconds
    2022-04-23 13:12:45,297 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 13:12:45,298 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 13:12:45,308 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 13:12:45,317 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 13:12:45,324 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 13:12:45,333 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 13:12:54,605 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:01,116 - INFO - [MainThread] cura.Settings.IntentManager.selectIntent [155]: Attempting to set intent_category to [default] and quality type to [standard]
    2022-04-23 13:13:01,126 - DEBUG - [MainThread] cura.Settings.MachineManager._updateIntentWithQuality [1284]: Updating intent due to quality change
    2022-04-23 13:13:01,245 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 13:13:01,272 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 13:13:14,988 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:18,132 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:18,171 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:18,364 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:13:18,397 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:18,410 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:13:18,418 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-23 13:13:18,614 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:13:18,640 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.0s
    2022-04-23 13:13:25,440 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:13:25,539 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.1s
    2022-04-23 13:13:35,238 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.05736279487609863 seconds
    2022-04-23 13:13:35,707 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:13:37,047 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:13:37,058 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.0s
    2022-04-23 13:13:46,998 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04134202003479004 seconds
    2022-04-23 13:13:56,643 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:13:56,686 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.1s
    2022-04-23 13:14:16,199 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04761505126953125 seconds
    2022-04-23 13:14:36,030 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 13:14:36,047 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:14:36,457 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03609943389892578 seconds
    2022-04-23 13:14:36,474 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:14:38,413 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 13:14:46,646 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:48,461 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.032076120376586914 seconds
    2022-04-23 13:14:52,302 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,316 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,487 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:14:52,534 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,542 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,645 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.2s
    2022-04-23 13:14:52,673 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:14:52,722 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,728 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:14:52,860 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-23 13:14:53,002 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 13:14:53,637 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.6s
    2022-04-23 13:15:23,951 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 13:15:23,956 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 13:15:23,961 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 13:15:23,980 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 13:15:23,998 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 13:15:24,246 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 13:15:24,247 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 13:15:24,252 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 13:15:24,379 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 13:15:24,455 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 13:15:24,489 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 13:15:24,631 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.38502931594848633 seconds
    2022-04-23 13:15:24,664 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:15:24,671 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 13:15:24,676 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 13:15:24,681 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 13:15:24,682 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 13:15:24,689 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:15:24,690 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 13:15:24,690 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 13:15:24,701 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 13:15:24,705 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 13:15:24,709 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:15:24,711 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 13:15:24,711 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 13:15:24,720 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 13:15:24,723 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 13:15:24,736 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 13:15:24,736 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 13:15:24,772 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="13:15:24" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="True" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 13:15:24,782 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 13:15:24,792 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 13:15:24,800 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 13:15:24,822 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 13:15:24,831 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 13:15:24,840 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:15:24,857 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 13:15:24,866 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 13:15:24,874 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 13:15:24,882 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 13:15:24,890 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:15:24,890 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 13:15:24,899 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="15.0" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 13:15:24,916 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:15:24,923 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 13:15:24,939 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:15:24,940 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 13:15:24,948 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 13:15:24,955 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 13:15:24,964 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 13:15:24,973 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:15:24,981 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:15:24,991 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="20.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="20.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="20.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="20.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="15.0" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="40.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="10" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="10" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="20.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="10" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="13.333333333333334" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="20.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="40.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 13:15:26,456 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 2.2079784870147705 seconds
    2022-04-23 13:15:26,458 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 13:15:26,459 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 13:15:26,468 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 13:15:26,477 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 13:15:26,484 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 13:15:26,496 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 13:15:29,226 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 13:15:29,236 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 13:15:29,268 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 13:15:29,423 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 13:15:30,392 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.9675412178039551 seconds
    2022-04-23 13:15:30,467 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.01894974708557129 seconds
    2022-04-23 13:15:30,579 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 13:15:36,942 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:15:40,605 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.036366939544677734 seconds
    2022-04-23 13:16:37,384 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:17:37,763 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:18:38,194 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:19:42,464 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:19:46,867 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 13:19:46,875 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 13:19:46,883 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:19:46,939 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 13:19:47,376 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 13:19:49,882 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14A381190>, took 10ms
    2022-04-23 13:19:50,079 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 13:19:50,090 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 13:19:50,098 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 13:19:50,108 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 13:19:50,791 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 13:19:55,184 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/guess who support 3.0 (1).stl
    2022-04-23 13:19:55,196 - INFO - [JobQueueWorker [3]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 13:19:55,209 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0010623931884765625 seconds
    2022-04-23 13:19:55,211 - DEBUG - [JobQueueWorker [3]] STLReader.STLReader._read [105]: Loaded a mesh with 1872 vertices
    2022-04-23 13:19:55,227 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.005045890808105469 seconds. 36 input vertices. 36 output vertices.
    2022-04-23 13:19:55,238 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 13:19:55,246 - DEBUG - [JobQueueWorker [3]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.004737377166748047 seconds. 36 input vertices. 36 output vertices.
    2022-04-23 13:19:55,271 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14A5A6040>, took 1ms
    2022-04-23 13:19:55,311 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'guess who support 3.0 (1).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'guess who support 3.0 (1).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 13:19:55,559 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:19:55,568 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:19:55,578 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 13:19:59,591 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 13:19:59,595 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 13:19:59,601 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 13:19:59,630 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 13:19:59,650 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 13:19:59,887 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 13:19:59,888 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 13:19:59,895 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 13:20:00,033 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 13:20:00,139 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 13:20:00,145 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 13:20:00,210 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.32241177558898926 seconds
    2022-04-23 13:20:00,390 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:20:00,403 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 13:20:00,405 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 13:20:00,410 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 13:20:00,422 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 13:20:00,423 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:20:00,434 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 13:20:00,437 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 13:20:00,445 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 13:20:00,445 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 13:20:00,453 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 13:20:00,461 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 13:20:00,469 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 13:20:00,469 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 13:20:00,477 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 13:20:00,487 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 13:20:00,487 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 13:20:00,495 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING] Mesh has overlapping faces!
    2022-04-23 13:20:00,495 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="13:20:00" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="True" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 13:20:00,503 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 13:20:00,503 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 13:20:00,511 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 13:20:00,511 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 13:20:00,521 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 13:20:00,529 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 13:20:00,529 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 13:20:00,536 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 13:20:00,537 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 13:20:00,545 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 13:20:00,545 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="15.0" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 13:20:00,554 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:20:00,554 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 13:20:00,562 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:20:00,562 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 13:20:00,570 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 13:20:00,570 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 13:20:00,578 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 13:20:00,578 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 13:20:00,588 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 13:20:00,597 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="20.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="20.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="20.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="20.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="15.0" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="40.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="10" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="10" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="20.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="10" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="13.333333333333334" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="20.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="40.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 13:20:01,584 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.696091651916504 seconds
    2022-04-23 13:20:01,586 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 13:20:01,587 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 13:20:01,597 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 13:20:01,606 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 13:20:01,614 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 13:20:01,624 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 13:20:05,404 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.06063246726989746 seconds
    2022-04-23 13:20:06,386 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 13:20:06,393 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:20:06,420 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 13:20:06,470 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 13:20:06,627 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.15598726272583008 seconds
    2022-04-23 13:20:06,787 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 13:20:16,763 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.016318321228027344 seconds
    2022-04-23 13:20:43,392 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:21:45,079 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:22:04,958 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03076338768005371 seconds
    2022-04-23 13:22:46,916 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:23:41,908 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.028965473175048828 seconds
    2022-04-23 13:23:48,983 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 13:23:48,992 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:23:49,494 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:23:49,646 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 13:24:02,938 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03392481803894043 seconds
    2022-04-23 13:24:53,295 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:25:53,930 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:26:54,573 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:27:54,944 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:28:55,815 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:29:56,516 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:30:56,914 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:31:57,332 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:32:55,504 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 13:32:55,513 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:32:55,924 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:32:56,029 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 13:33:06,063 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.02772974967956543 seconds
    2022-04-23 13:33:56,553 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:34:57,437 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:35:57,811 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:36:59,845 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:38:00,981 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:39:02,118 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:40:03,147 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:41:03,506 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:42:03,617 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 13:42:03,632 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:42:04,009 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:42:04,163 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[84d33efd][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "f9a99e1a-6720-4045-a929-2d10d9b611cd"}'
    2022-04-23 13:42:04,183 - WARNING - [MainThread] UM.Logger.warning [143]: Failed to get a new access token from the server.
    2022-04-23 13:42:04,246 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:42:04,256 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura/v1/feature_budgets
    2022-04-23 13:42:04,265 - DEBUG - [MainThread] UM.Logger.debug [131]: Synced cloud printers with account.
    2022-04-23 13:42:04,274 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting packages metadata from server.
    2022-04-23 13:42:04,292 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:42:04,301 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages
    2022-04-23 13:42:04,308 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting authors metadata from server.
    2022-04-23 13:42:04,312 - DEBUG - [MainThread] UM.Logger.debug [131]: Was already busy refreshing token. Do not start a new request.
    2022-04-23 13:42:04,321 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/authors
    2022-04-23 13:42:05,310 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[3f92a53b][get][PyQt5.QtCore.QUrl('https://api.ultimaker.com/cura/v1/feature_budgets')][timeout=10][no-data] got an QNetworkReplyError Host requires authentication. The server returned: b'{"errors": [{"id": "7c8575c6-110e-4da9-a3f4-4811f125d7e4", "code": "noBearerToken", "http_status": "401", "title": "No bearer token has been given to authenticate the request.", "meta": {"error_type": "AuthError", "url": "https://api.ultimaker.com/feature_budgets"}}]}'
    2022-04-23 13:42:05,322 - WARNING - [MainThread] UM.Logger.warning [143]: Digital Factory: Response is not a feature budget, likely an error: <PyQt5.QtNetwork.QNetworkReply object at 0x000001D151D11310>
    2022-04-23 13:43:40,570 - DEBUG - [MainThread] RemovableDriveOutputDevice.RemovableDriveOutputDevice.requestWrite [85]: Writing to E:/CE3PRO_guess who support 3.0 (1).gcode
    2022-04-23 13:43:40,665 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.06722092628479004 seconds
    2022-04-23 13:43:41,864 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 13:43:43,481 - INFO - [MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [44]: Attempting to eject the device
    2022-04-23 13:43:43,481 - INFO - [MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [51]: Successfully ejected the device
    2022-04-23 13:49:02,823 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_guess who support 3.0 (1).gcode]...
    2022-04-23 13:49:02,838 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_guess who support 3.0 (1).gcode in text mode
    2022-04-23 13:49:02,962 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.0792536735534668 seconds
    2022-04-23 13:49:03,910 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 13:49:08,775 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 13:49:08,777 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 13:49:08,787 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 13:49:08,840 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 13:49:09,111 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 13:49:19,310 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.039740562438964844 seconds
    2022-04-23 14:00:17,286 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:00:24,258 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 14:00:24,288 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:00:27,329 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03078293800354004 seconds
    2022-04-23 14:21:36,974 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 14:21:36,974 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 14:21:37,030 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:21:37,363 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:21:41,828 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D13CC1A400>, took 10ms
    2022-04-23 14:21:42,428 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 14:21:42,442 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 14:21:42,453 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 14:21:42,465 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 14:21:42,713 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 14:21:50,672 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/GW support 3.1.stl
    2022-04-23 14:21:50,682 - INFO - [JobQueueWorker [0]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 14:21:50,709 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0010437965393066406 seconds
    2022-04-23 14:21:50,710 - DEBUG - [JobQueueWorker [0]] STLReader.STLReader._read [105]: Loaded a mesh with 1908 vertices
    2022-04-23 14:21:50,726 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.006129264831542969 seconds. 39 input vertices. 39 output vertices.
    2022-04-23 14:21:50,733 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 14:21:50,749 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.005985736846923828 seconds. 39 input vertices. 39 output vertices.
    2022-04-23 14:21:50,775 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D14AA3E1F0>, took 2ms
    2022-04-23 14:21:50,814 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'GW support 3.1.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1.stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 14:21:51,414 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 14:21:51,421 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 14:21:51,428 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 14:22:00,904 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.06747746467590332 seconds
    2022-04-23 14:22:01,173 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 14:22:01,178 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 14:22:01,184 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 14:22:01,206 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 14:22:01,224 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:22:01,458 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 14:22:01,459 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 14:22:01,466 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 14:22:01,637 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 14:22:01,677 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 14:22:01,683 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 14:22:01,741 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.2827620506286621 seconds
    2022-04-23 14:22:01,936 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:01,949 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 14:22:01,954 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 14:22:01,958 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 14:22:01,969 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 14:22:01,970 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:01,978 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 14:22:01,987 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 14:22:01,995 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 14:22:01,995 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 14:22:02,007 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:02,015 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 14:22:02,020 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 14:22:02,020 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 14:22:02,029 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 14:22:02,037 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 14:22:02,037 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 14:22:02,047 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="14:22:01" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="True" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 14:22:02,048 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 14:22:02,053 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 14:22:02,061 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 14:22:02,061 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 14:22:02,071 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 14:22:02,075 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:02,087 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 14:22:02,087 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 14:22:02,095 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 14:22:02,105 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 14:22:02,106 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:02,114 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 14:22:02,120 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="15.0" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 14:22:02,128 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 14:22:02,136 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 14:22:02,136 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 14:22:02,144 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 14:22:02,152 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 14:22:02,154 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 14:22:02,161 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 14:22:02,162 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 14:22:02,173 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 14:22:02,182 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="20.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="20.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="2.6666666666666665" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="20.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="2.6666666666666665" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="20.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="8" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="15.0" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="40.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="10" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="10" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="20.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="10" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="13.333333333333334" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="20.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="40.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 14:22:03,433 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.9739000797271729 seconds
    2022-04-23 14:22:03,436 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 14:22:03,437 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 14:22:03,447 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 14:22:03,457 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 14:22:03,464 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 14:22:03,473 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 14:22:12,435 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 14:22:12,463 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:22:12,519 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 14:22:12,742 - DEBUG - [JobQueueWorker [2]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.22313952445983887 seconds
    2022-04-23 14:22:12,825 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 14:22:34,674 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 14:22:36,145 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:36,269 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:36,395 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:22:36,456 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:36,465 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:36,490 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.1s
    2022-04-23 14:22:36,579 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:22:37,174 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.6s
    2022-04-23 14:22:37,351 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:37,359 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:22:37,482 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:22:37,535 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.043024301528930664 seconds
    2022-04-23 14:22:37,571 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.1s
    2022-04-23 14:22:42,667 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 14:22:42,673 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 14:22:42,681 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 14:22:42,700 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 14:22:42,715 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:22:42,907 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 14:22:42,907 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 14:22:42,913 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 14:22:43,056 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 14:22:43,072 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 14:22:43,089 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 14:22:43,157 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.24973773956298828 seconds
    2022-04-23 14:22:43,314 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:43,321 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 14:22:43,326 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 14:22:43,334 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 14:22:43,338 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 14:22:43,348 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:43,351 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 14:22:43,359 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 14:22:43,367 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 14:22:43,367 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 14:22:43,383 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:43,383 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 14:22:43,391 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 14:22:43,391 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 14:22:43,399 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 14:22:43,407 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 14:22:43,415 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 14:22:43,415 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="14:22:42" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="4.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="True" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 14:22:43,423 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 14:22:43,423 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 14:22:43,431 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 14:22:43,431 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 14:22:43,439 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 14:22:43,451 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 14:22:43,451 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 14:22:43,465 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 14:22:43,465 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 14:22:43,473 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:22:43,481 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 14:22:43,491 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="10" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="5" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 14:22:43,499 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 14:22:43,499 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 14:22:43,507 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 14:22:43,515 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 14:22:43,523 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 14:22:43,530 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 14:22:43,531 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 14:22:43,540 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 14:22:43,548 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 14:22:43,557 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="20.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="4.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="20.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="4.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="20.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="4.0" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="20.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="5" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="10" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="40.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="10" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="10" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="20.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="10" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="13.333333333333334" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="20.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="40.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 14:22:44,860 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.9520504474639893 seconds
    2022-04-23 14:22:44,861 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 14:22:44,865 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 14:22:44,869 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 14:22:44,974 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 14:22:44,983 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 14:22:44,991 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 14:22:45,004 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 14:22:45,087 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.21659445762634277 seconds
    2022-04-23 14:22:45,120 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 14:30:23,907 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 14:30:23,907 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 14:30:23,907 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-23 14:30:23,908 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-23 14:30:23,908 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-23 14:30:23,908 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-23 14:30:23,908 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-23 14:30:23,909 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-23 14:30:23,910 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-23 14:30:23,910 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 14:30:23,910 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 14:30:23,910 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-23 14:30:23,910 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 14:30:23,911 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 14:30:23,911 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-23 14:30:23,912 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-23 14:30:23,912 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-23 14:30:23,912 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-23 14:30:23,912 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-23 14:30:23,912 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 14:30:23,913 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 14:30:23,913 - INFO - [MainThread] UM.PackageManager._loadManagementData [197]: Loaded user packages management file from C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json
    2022-04-23 14:30:23,913 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-23 14:30:23,913 - INFO - [MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [119]: Loading plugin configuration file 'C:\Users\Ben360\AppData\Roaming\cura\4.13\plugins.json'
    2022-04-23 14:30:23,913 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-23 14:30:23,925 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-23 14:30:23,983 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-23 14:30:24,013 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:30:24,022 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 14:30:24,028 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 14:30:24,033 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:30:24,041 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 14:30:24,049 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 14:30:24,053 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-23 14:30:24,061 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 14:30:24,065 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 14:30:24,072 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 14:30:24,076 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 14:30:24,083 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:30:24,092 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 14:30:24,097 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 14:30:24,104 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 14:30:24,112 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 14:30:24,125 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 14:30:24,132 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 14:30:24,140 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 14:30:24,157 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-23 14:30:24,188 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-23 14:30:24,215 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-23 14:30:24,267 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-23 14:30:24,298 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-23 14:30:24,328 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-23 14:30:24,365 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-23 14:30:24,412 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-23 14:30:24,469 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-23 14:30:24,500 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-23 14:30:24,530 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-23 14:30:24,564 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-23 14:30:24,602 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-23 14:30:24,633 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-23 14:30:24,659 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-23 14:30:24,687 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-23 14:30:24,738 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-23 14:30:24,799 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-23 14:30:24,830 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-23 14:30:24,865 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-23 14:30:24,893 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-23 14:30:25,002 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-23 14:30:25,032 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-23 14:30:25,073 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-23 14:30:25,115 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-23 14:30:25,155 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-23 14:30:25,183 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-23 14:30:25,221 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-23 14:30:25,245 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-23 14:30:25,305 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-23 14:30:25,337 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-23 14:30:25,371 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-23 14:30:25,688 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-23 14:30:25,720 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-23 14:30:25,724 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-23 14:30:25,842 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-23 14:30:25,887 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-23 14:30:25,909 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-23 14:30:25,941 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-23 14:30:25,965 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-23 14:30:25,990 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-23 14:30:26,009 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-23 14:30:26,031 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-23 14:30:26,048 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-23 14:30:26,072 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-23 14:30:26,096 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-23 14:30:26,121 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-23 14:30:26,144 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-23 14:30:26,171 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-23 14:30:26,192 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-23 14:30:26,212 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-23 14:30:26,238 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-23 14:30:26,260 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-23 14:30:26,294 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-23 14:30:26,320 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-23 14:30:26,347 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-23 14:30:26,372 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-23 14:30:26,402 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-23 14:30:26,422 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-23 14:30:26,466 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-23 14:30:26,522 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-23 14:30:26,563 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-23 14:30:26,572 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 5.1669275760650635 seconds
    2022-04-23 14:30:26,631 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-23 14:30:26,755 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.12253284454345703
    2022-04-23 14:30:26,806 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-23 14:30:26,841 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-23 14:30:32,704 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 5.841134786605835 seconds
    2022-04-23 14:30:32,738 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-23 14:30:32,741 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-23 14:30:32,778 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager._loadManagementData [197]: Loaded user packages management file from C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-23 14:30:32,778 - INFO - [MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [119]: Loading plugin configuration file 'C:\Users\Ben360\AppData\Roaming\cura\4.13\plugins.json'
    2022-04-23 14:30:32,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-23 14:30:32,788 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-23 14:30:32,812 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-23 14:30:32,836 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-23 14:30:32,849 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-23 14:30:32,864 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-23 14:30:32,879 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-23 14:30:32,908 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-23 14:30:32,921 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-23 14:30:32,926 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-23 14:30:32,946 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-23 14:30:32,970 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-23 14:30:32,987 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-23 14:30:33,005 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-23 14:30:33,021 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-23 14:30:33,032 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-23 14:30:33,054 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-23 14:30:33,060 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-23 14:30:33,060 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-23 14:30:33,073 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-23 14:30:33,089 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-23 14:30:33,105 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-23 14:30:33,120 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-23 14:30:33,142 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-23 14:30:33,193 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-23 14:30:33,222 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-23 14:30:33,246 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-23 14:30:33,272 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-23 14:30:33,354 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-23 14:30:33,371 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-23 14:30:33,397 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-23 14:30:33,429 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-23 14:30:33,454 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-23 14:30:33,476 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-23 14:30:33,506 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-23 14:30:33,528 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-23 14:30:33,562 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-23 14:30:33,587 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-23 14:30:33,606 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-23 14:30:33,836 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-23 14:30:33,863 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-23 14:30:33,871 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-23 14:30:33,986 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-23 14:30:34,020 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-23 14:30:34,043 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-23 14:30:34,071 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-23 14:30:34,088 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-23 14:30:34,107 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-23 14:30:34,126 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-23 14:30:34,154 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-23 14:30:34,171 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-23 14:30:34,189 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-23 14:30:34,209 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-23 14:30:34,225 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-23 14:30:34,245 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-23 14:30:34,263 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-23 14:30:34,288 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-23 14:30:34,305 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-23 14:30:34,325 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-23 14:30:34,344 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-23 14:30:34,371 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-23 14:30:34,390 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-23 14:30:34,421 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-23 14:30:34,438 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-23 14:30:34,455 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-23 14:30:34,477 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-23 14:30:34,506 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-23 14:30:34,539 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-23 14:30:34,558 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-23 14:30:34,572 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 10.117183923721313 seconds
    2022-04-23 14:30:34,591 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-23 14:30:34,678 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.07989645004272461
    2022-04-23 14:30:34,703 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-23 14:30:34,722 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-23 14:30:35,279 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 2.1996378898620605 seconds.
    2022-04-23 14:30:35,295 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-23 14:30:35,304 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-23 14:30:35,304 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-23 14:30:35,304 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-23 14:30:35,304 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-23 14:30:35,313 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-23 14:30:35,319 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-23 14:30:35,321 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-23 14:30:35,321 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-23 14:30:35,321 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-23 14:30:35,336 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-23 14:30:35,338 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-23 14:30:35,341 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-23 14:30:35,341 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-23 14:30:35,584 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-23 14:30:35,645 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-23 14:30:35,655 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-23 14:30:35,686 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-23 14:30:35,705 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0010342597961425781 seconds
    2022-04-23 14:30:35,721 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.013172149658203125 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 14:30:35,745 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 14:30:35,754 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-23 14:30:35,790 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 14:30:35,853 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-23 14:30:36,181 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-23 14:30:36,187 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:30:36,195 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[073345cd][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "8acbb62b-85dc-4d46-a677-f65dff9c4072", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 14:30:36,204 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 14:30:36,955 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-23 14:30:37,053 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-23 14:30:37,120 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 2.3734304904937744 seconds
    2022-04-23 14:30:37,137 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-23 14:30:37,145 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-23 14:30:37,236 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-23 14:30:37,314 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-23 14:30:37,437 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-23 14:30:37,486 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-23 14:30:37,487 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-23 14:30:37,639 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:30:37,875 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 14:30:38,011 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:30:38,302 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 14:30:38,306 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-23 14:30:38,314 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-23 14:30:38,320 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-23 14:30:38,394 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-23 14:30:38,404 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 14:30:38,412 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=STLReader:1.0.1&installed_packages=GCodeGzReader:1.0.1&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=ModelChecker:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=CameraTool:1.0.1&installed_packages=SelectionTool:1.0.1&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=STLWriter:1.0.1&installed_packages=FirmwareUpdater:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=UltimakerPP:1.4.0&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=FABtotumABS:1.4.0&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=UltimakerBAM:1.4.0&installed_packages=GenericPVA:1.4.0&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=GenericGFFPA:1.4.0&installed_packages=GCodeWriter:1.0.1&installed_packages=CuraProfileWriter:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=GenericCPE:1.4.0&installed_packages=UltimakerPLA:1.4.0&installed_packages=Toolbox:1.0.1&installed_packages=RotateTool:1.0.1&installed_packages=ConsoleLogger:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=PolyWoodPLA:1.0.1&installed_packages=TranslateTool:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=GenericABS:1.4.0&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=UFPReader:1.0.0&installed_packages=UltimakerNylon:1.4.0&installed_packages=3MFWriter:1.0.1&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=UltimakerPVA:1.4.0&installed_packages=VertexDeltaPET:1.4.0&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=GCodeProfileReader:1.0.1&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericCPEPlus:1.4.0&installed_packages=UpdateChecker:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=SolidView:1.0.1&installed_packages=MonitorStage:1.0.1&installed_packages=PolyPlusPLA:1.0.1&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=DigitalLibrary:1.1.0&installed_packages=GCodeReader:1.0.1&installed_packages=GenericPLA:1.4.0&installed_packages=PolyMaxPLA:1.0.1&installed_packages=FABtotumPLA:1.4.0&installed_packages=X3DReader:1.0.1&installed_packages=UltimakerCPE:1.4.0&installed_packages=PreviewStage:1.0.1&installed_packages=UltimakerABS:1.4.0&installed_packages=CuraEngineBackend:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=SimpleView:1.0.1&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=GenericGFFCPE:1.4.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=ScaleTool:1.0.1&installed_packages=GenericPC:1.4.0&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=VertexDeltaABS:1.4.0&installed_packages=LegacyProfileReader:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=GenericNylon:1.4.0&installed_packages=PolyFlexPLA:1.0.1&installed_packages=FABtotumTPU:1.4.0&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=LocalContainerProvider:1.0.1&installed_packages=UltimakerTPLA:1.4.0&installed_packages=SentryLogger:1.0.0&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=UltimakerPC:1.4.0&installed_packages=UFPWriter:1.0.1&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=OBJWriter:1.0.1&installed_packages=FABtotumNylon:1.4.0&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=AMFReader:1.0.0&installed_packages=MirrorTool:1.0.1&installed_packages=SimulationView:1.0.1&installed_packages=3MFReader:1.0.1&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=CuraProfileReader:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=GenericCFFCPE:1.4.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=GenericPP:1.4.0&installed_packages=FileLogger:1.0.1&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=ImageReader:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=GenericPETG:1.4.0&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=SupportEraser:1.0.1&installed_packages=GenericHIPS:1.4.0&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=TrimeshReader:1.0.0&installed_packages=VersionUpgrade35to40:1.0.0
    2022-04-23 14:30:38,435 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 18.214357376098633 seconds
    2022-04-23 14:30:38,435 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-23 14:30:38,480 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x0000025852B564C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-23 14:30:38,494 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:38,507 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:38,759 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:38,768 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:38,955 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-23 14:30:39,657 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-23 14:30:39,676 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-23 14:30:39,684 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-23 14:30:39,692 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-23 14:30:39,700 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-23 14:30:39,706 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-23 14:30:39,714 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:39,735 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-23 14:30:39,751 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-23 14:30:39,768 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:39,786 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-23 14:30:39,818 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 14:30:39,847 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:39,876 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 14:30:39,895 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:39,923 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:30:39,939 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-23 14:30:39,955 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 2.4587135314941406 seconds.
    2022-04-23 14:30:39,966 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:39,972 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-23 14:30:39,976 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-23 14:30:39,978 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-23 14:30:39,980 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-23 14:30:39,981 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-23 14:30:39,983 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-23 14:30:39,986 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-23 14:30:39,989 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-23 14:30:39,994 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-23 14:30:39,995 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-23 14:30:39,997 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-23 14:30:39,999 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-23 14:30:40,007 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-23 14:30:40,010 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-23 14:30:40,014 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-23 14:30:40,016 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-23 14:30:40,089 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:30:40,363 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-23 14:30:40,424 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-23 14:30:40,429 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-23 14:30:40,459 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-23 14:30:40,489 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 14:30:40,499 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0009474754333496094 seconds
    2022-04-23 14:30:40,505 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-23 14:30:40,522 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.011538982391357422 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 14:30:40,552 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 14:30:40,590 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-23 14:30:40,776 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/old gcode files/test tube holder for aquaponics (1.g
    2022-04-23 14:30:40,781 - INFO - [MainThread] UM.Controller.deleteAllNodesWithMeshData [468]: Clearing scene
    2022-04-23 14:30:40,787 - INFO - [MainThread] cura.CuraApplication._removeNodesWithLayerData [2042]: Clearing scene
    2022-04-23 14:30:40,843 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-23 14:30:40,838 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[9b8badd0][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "53261570-4168-4f44-9847-8f04d6d6ecda"}'
    2022-04-23 14:30:40,851 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:30:40,872 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[f98460d0][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "cdbe56a3-6aae-49a0-9d31-8305ffe65fbf"}'
    2022-04-23 14:30:40,880 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [315]: Preparing to load g-code
    2022-04-23 14:30:41,058 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [355]: Parsing g-code...
    2022-04-23 14:30:41,614 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-23 14:30:41,718 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-23 14:30:41,761 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 14:30:41,797 - WARNING - [MainThread] UM.Logger.warning [143]: Failed to get a new access token from the server.
    2022-04-23 14:30:41,900 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-23 14:30:42,091 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-23 14:30:42,267 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:30:42,453 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 14:30:42,541 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:30:42,739 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 14:30:42,747 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-23 14:30:42,762 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-23 14:30:42,763 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-23 14:30:42,856 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-23 14:30:42,872 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 14:30:42,877 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=GenericGFFPA:1.4.0&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=UltimakerCPE:1.4.0&installed_packages=GCodeProfileReader:1.0.1&installed_packages=MirrorTool:1.0.1&installed_packages=AMFReader:1.0.0&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=FileLogger:1.0.1&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=GenericCPEPlus:1.4.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=UFPReader:1.0.0&installed_packages=FABtotumNylon:1.4.0&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=MonitorStage:1.0.1&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=UltimakerBAM:1.4.0&installed_packages=UltimakerNylon:1.4.0&installed_packages=GCodeGzReader:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=GenericPETG:1.4.0&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=3MFWriter:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=GenericPLA:1.4.0&installed_packages=UltimakerABS:1.4.0&installed_packages=GenericPP:1.4.0&installed_packages=ModelChecker:1.0.1&installed_packages=TranslateTool:1.0.1&installed_packages=SimpleView:1.0.1&installed_packages=SolidView:1.0.1&installed_packages=SupportEraser:1.0.1&installed_packages=SentryLogger:1.0.0&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericCFFCPE:1.4.0&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=GCodeWriter:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=STLReader:1.0.1&installed_packages=ScaleTool:1.0.1&installed_packages=PolyPlusPLA:1.0.1&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=GenericPC:1.4.0&installed_packages=UltimakerPP:1.4.0&installed_packages=UpdateChecker:1.0.1&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=GCodeReader:1.0.1&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=LegacyProfileReader:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=UltimakerPC:1.4.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=CuraEngineBackend:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=GenericABS:1.4.0&installed_packages=UltimakerPLA:1.4.0&installed_packages=VertexDeltaPET:1.4.0&installed_packages=MachineSettingsAction:1.0.1&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=TrimeshReader:1.0.0&installed_packages=CameraTool:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=3MFReader:1.0.1&installed_packages=UFPWriter:1.0.1&installed_packages=FirmwareUpdater:1.0.1&installed_packages=ConsoleLogger:1.0.1&installed_packages=UltimakerPVA:1.4.0&installed_packages=PolyWoodPLA:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=SimulationView:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=FABtotumABS:1.4.0&installed_packages=STLWriter:1.0.1&installed_packages=LocalContainerProvider:1.0.1&installed_packages=Toolbox:1.0.1&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=GenericPVA:1.4.0&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=FABtotumTPU:1.4.0&installed_packages=GCodeGzWriter:1.0.1&installed_packages=SelectionTool:1.0.1&installed_packages=ImageReader:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=GenericGFFCPE:1.4.0&installed_packages=GenericHIPS:1.4.0&installed_packages=GenericNylon:1.4.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=FABtotumPLA:1.4.0&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=UltimakerTPLA:1.4.0&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=VertexDeltaABS:1.4.0&installed_packages=PreviewStage:1.0.1&installed_packages=DigitalLibrary:1.1.0&installed_packages=OBJWriter:1.0.1&installed_packages=RotateTool:1.0.1&installed_packages=PolyFlexPLA:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=CuraProfileWriter:1.0.1
    2022-04-23 14:30:42,892 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-23 14:30:42,892 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 19.442295789718628 seconds
    2022-04-23 14:30:42,926 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x000001DB0C5864C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-23 14:30:42,935 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:42,950 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:43,164 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[099739c9][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "23252668-9dbc-4a75-9fcf-e8ec7eb07122", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 14:30:43,172 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 14:30:43,196 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:43,206 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:43,414 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-23 14:30:43,831 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-23 14:30:43,844 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-23 14:30:43,849 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-23 14:30:43,854 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-23 14:30:43,858 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-23 14:30:43,863 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-23 14:30:43,867 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:43,881 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-23 14:30:43,892 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-23 14:30:43,905 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:43,917 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-23 14:30:43,940 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 14:30:43,958 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:43,978 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 14:30:43,991 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:44,012 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:30:44,023 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-23 14:30:44,045 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 14:30:44,057 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-23 14:30:44,071 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-23 14:30:44,149 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:30:44,716 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/old gcode files/test tube holder for aquaponics (1.g
    2022-04-23 14:30:44,721 - INFO - [MainThread] UM.Controller.deleteAllNodesWithMeshData [468]: Clearing scene
    2022-04-23 14:30:44,725 - INFO - [MainThread] cura.CuraApplication._removeNodesWithLayerData [2042]: Clearing scene
    2022-04-23 14:30:44,784 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[50785fbc][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "faca9e44-0e3c-4587-9cfa-5612618c8bc4"}'
    2022-04-23 14:30:44,801 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[1bde0cf6][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "5b43d812-c33c-4c3d-9a75-a7020ea31758"}'
    2022-04-23 14:30:44,807 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [315]: Preparing to load g-code
    2022-04-23 14:30:44,893 - WARNING - [MainThread] UM.Logger.warning [143]: Failed to get a new access token from the server.
    2022-04-23 14:30:44,899 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [355]: Parsing g-code...
    2022-04-23 14:30:44,899 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 14:30:47,561 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [485]: Finished parsing g-code.
    2022-04-23 14:30:47,576 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [496]: G-code loading finished.
    2022-04-23 14:30:47,584 - WARNING - [JobQueueWorker [2]] UM.Logger.warning [143]: Loaded file C:/Users/Ben360/3D Objects/old gcode files/test tube holder for aquaponics (1.g has no associated MIME type.
    2022-04-23 14:30:47,602 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 6.7 seconds
    2022-04-23 14:30:47,794 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-23 14:30:47,945 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension test tube holder for aquaponics (1.g
    2022-04-23 14:30:47,955 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000002586BBDAE50>, took 0ms
    2022-04-23 14:30:47,980 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=0), took 0ms
    2022-04-23 14:30:47,987 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:47,997 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:48,136 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 14:30:48,140 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 14:30:48,184 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:30:48,195 - INFO - [MainThread] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 14:30:48,202 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0009975433349609375 seconds
    2022-04-23 14:30:48,203 - DEBUG - [MainThread] STLReader.STLReader._read [105]: Loaded a mesh with 12612 vertices
    2022-04-23 14:30:48,211 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\simulationview_composite.shader]...
    2022-04-23 14:30:48,386 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:30:48,422 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:30:48,440 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 14:30:48,453 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d.shader]...
    2022-04-23 14:30:48,551 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d_shadow.shader]...
    2022-04-23 14:30:48,606 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 14:30:48,624 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 14:30:48,639 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:48,778 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[9328d86a][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "edcc8ace-58f3-4eea-ad91-fc193a080020", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 14:30:48,797 - WARNING - [MainThread] UM.Logger.warning [143]: The user profile could not be loaded. The user must log in again!
    2022-04-23 14:30:48,804 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 14:30:48,810 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [300]: Clearing the user profile
    2022-04-23 14:30:48,817 - WARNING - [MainThread] UM.Logger.warning [143]: Unable to get user profile using auth data from preferences.
    2022-04-23 14:30:49,224 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension test tube holder for aquaponics (1.g
    2022-04-23 14:30:49,230 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:30:50,331 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 1.9s
    2022-04-23 14:30:50,647 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [485]: Finished parsing g-code.
    2022-04-23 14:30:50,661 - DEBUG - [JobQueueWorker [2]] GCodeReader.FlavorParser.processGCodeStream [496]: G-code loading finished.
    2022-04-23 14:30:50,671 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 5.9 seconds
    2022-04-23 14:30:50,949 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._checkStack [158]: Need to check for errors again. Discard the current progress and reschedule a check.
    2022-04-23 14:30:51,076 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001DB27072D90>, took 0ms
    2022-04-23 14:30:51,112 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=0), took 0ms
    2022-04-23 14:30:51,123 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 14:30:51,135 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 14:30:51,205 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 14:30:51,210 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:30:51,261 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:30:51,277 - INFO - [MainThread] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 14:30:51,283 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0009417533874511719 seconds
    2022-04-23 14:30:51,285 - DEBUG - [MainThread] STLReader.STLReader._read [105]: Loaded a mesh with 12612 vertices
    2022-04-23 14:30:51,294 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\simulationview_composite.shader]...
    2022-04-23 14:30:51,481 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:30:51,514 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 14:30:51,540 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 14:30:51,553 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d.shader]...
    2022-04-23 14:30:51,641 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d_shadow.shader]...
    2022-04-23 14:30:51,698 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 14:30:51,713 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 14:30:51,728 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 14:30:51,857 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[1c797f77][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "2517d1ce-616b-4063-b7f9-2070595ac97e", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 14:30:51,888 - WARNING - [MainThread] UM.Logger.warning [143]: The user profile could not be loaded. The user must log in again!
    2022-04-23 14:30:51,895 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 14:30:51,903 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [300]: Clearing the user profile
    2022-04-23 14:30:51,913 - WARNING - [MainThread] UM.Logger.warning [143]: Unable to get user profile using auth data from preferences.
    2022-04-23 14:30:52,337 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 14:30:54,075 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 2.6s
    2022-04-23 14:30:59,337 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.05292177200317383 seconds
    2022-04-23 14:31:02,437 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.05528569221496582 seconds
    2022-04-23 14:32:21,958 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2022-04-23 14:32:21,958 - INFO - [MainThread] cura.CuraApplication.closeApplication [612]: Close application
    2022-04-23 14:32:21,969 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-23 14:32:21,991 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:22,045 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:22,624 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [488]: Shutting down cura
    2022-04-23 14:32:22,686 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 14:32:22,691 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [360]: Killing engine process
    2022-04-23 14:32:22,766 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [363]: Engine process is killed. Received return code 1
    2022-04-23 14:32:22,810 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/qml/UM/Preferences/PreferencesDialog.qml:113: TypeError: Cannot read property 'resetEnabled' of null
    2022-04-23 14:32:31,488 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 14:32:31,488 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 14:32:31,545 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:32,014 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 14:32:32,040 - WARNING - [MainThread] UM.View.RenderBatch.addItem [165]: Tried to add an item to batch without mesh
    2022-04-23 14:32:32,050 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:32:36,390 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 14:32:36,418 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 14:32:36,939 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension test tube holder for aquaponics (1.g
    2022-04-23 14:32:41,622 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 14:32:41,622 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 14:32:41,684 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:41,997 - WARNING - [MainThread] UM.View.RenderBatch.addItem [165]: Tried to add an item to batch without mesh
    2022-04-23 14:32:42,007 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 14:32:43,520 - WARNING - [MainThread] UM.View.RenderBatch.addItem [165]: Tried to add an item to batch without mesh
    2022-04-23 14:32:44,072 - WARNING - [MainThread] UM.View.RenderBatch.addItem [165]: Tried to add an item to batch without mesh
    2022-04-23 14:32:48,493 - WARNING - [MainThread] UM.View.RenderBatch.addItem [165]: Tried to add an item to batch without mesh
    2022-04-23 14:32:57,050 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2022-04-23 14:32:57,051 - INFO - [MainThread] cura.CuraApplication.closeApplication [612]: Close application
    2022-04-23 14:32:57,059 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-23 14:32:57,099 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 14:32:57,124 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:57,135 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:57,259 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 14:32:57,273 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:57,281 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 14:32:57,669 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [488]: Shutting down cura
    2022-04-23 14:32:57,726 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 14:32:57,728 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [360]: Killing engine process
    2022-04-23 14:32:57,747 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [363]: Engine process is killed. Received return code 1
    2022-04-23 14:32:57,804 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/qml/UM/Preferences/PreferencesDialog.qml:113: TypeError: Cannot read property 'resetEnabled' of null
    2022-04-23 14:45:36,970 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_GW support 3.1.gcode]...
    2022-04-23 14:45:36,990 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_GW support 3.1.gcode in text mode
    2022-04-23 14:45:37,178 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.13683700561523438 seconds
    2022-04-23 14:45:38,080 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 15:43:58,282 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 15:43:58,289 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 15:43:58,453 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:43:58,882 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 15:43:59,472 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 15:44:09,746 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0570683479309082 seconds
    2022-04-23 15:44:21,822 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000001D14F4866D0>, took 9ms
    2022-04-23 15:44:22,392 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 15:44:22,405 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 15:44:22,412 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 15:44:22,416 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 15:44:22,719 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 15:44:24,270 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.022284507751464844 seconds
    2022-04-23 15:44:30,072 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:44:40,094 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.01838994026184082 seconds
    2022-04-23 15:44:40,353 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/GW support 3.1 (1).stl
    2022-04-23 15:44:40,365 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 15:44:40,380 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0005967617034912109 seconds
    2022-04-23 15:44:40,381 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 1842 vertices
    2022-04-23 15:44:40,411 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.014960765838623047 seconds. 32 input vertices. 32 output vertices.
    2022-04-23 15:44:40,427 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 15:44:40,445 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.0039899349212646484 seconds. 32 input vertices. 32 output vertices.
    2022-04-23 15:44:40,482 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000001D152A882E0>, took 1ms
    2022-04-23 15:44:40,528 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 3ms
    2022-04-23 15:44:41,119 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 15:44:41,136 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 15:44:41,144 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 15:44:50,627 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.045166015625 seconds
    2022-04-23 15:45:02,363 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:03,634 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.030234813690185547 seconds
    2022-04-23 15:45:03,987 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,043 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,048 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,082 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,143 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,149 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,259 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 15:45:04,292 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.0s
    2022-04-23 15:45:04,937 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:04,942 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 15:45:05,076 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 15:45:05,127 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.0s
    2022-04-23 15:45:08,346 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 15:45:08,359 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 15:45:08,366 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 15:45:08,388 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 15:45:08,403 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 15:45:08,732 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 15:45:08,733 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 15:45:08,739 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 15:45:08,786 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 15:45:08,815 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 15:45:08,823 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 15:45:09,092 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,104 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 15:45:09,108 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 15:45:09,117 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 15:45:09,125 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 15:45:09,133 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,141 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 15:45:09,150 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 15:45:09,158 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 15:45:09,166 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 15:45:09,174 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,183 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 15:45:09,192 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 15:45:09,203 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 15:45:09,211 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 15:45:09,224 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,240 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 15:45:09,255 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 15:45:09,426 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.6940746307373047 seconds
    2022-04-23 15:45:09,617 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="15:45:09" -s print_bed_temperature="60" -s material_name="empty" -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="210" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s support_type="everywhere" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s jerk_travel="8" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s wireframe_fall_down="0.5" -s flow_rate_max_extrusion_offset="0" -s speed_wall_x="25.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s machine_heated_build_volume="False" -s wireframe_top_jump="0.6" -s magic_fuzzy_skin_thickness="0.3" -s machine_max_feedrate_x="500" -s machine_max_feedrate_z="10" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s machine_height="250" -s support_roof_line_width="0.4" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s machine_extruders_share_nozzle="False" -s material_break_speed="25" -s acceleration_ironing="500" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s infill_wall_line_count="0" -s support_angle="45" -s wireframe_printspeed_down="5" -s wireframe_roof_fall_down="2" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s machine_max_feedrate_e="50" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s support_initial_layer_line_distance="8.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s draft_shield_enabled="False" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s adaptive_layer_height_enabled="False" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s mold_width="5" -s small_hole_max_size="0" -s infill_extruder_nr="-1" -s material_initial_print_temperature="210" -s support_tree_angle="40" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_enable="True" -s support_tower_roof_angle="65" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_join_distance="2.0" -s cool_lift_head="False" -s retraction_hop_after_extruder_switch_height="0.2" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s material_anti_ooze_retraction_speed="5" -s default_material_bed_temperature="60" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s jerk_wall_x="8" -s raft_interface_jerk="8" -s raft_base_thickness="0.24" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 15:45:09,621 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 15:45:09,625 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 15:45:09,630 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 15:45:09,634 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 15:45:09,638 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 15:45:09,643 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,646 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 15:45:09,650 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 15:45:09,654 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 15:45:09,658 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 15:45:09,662 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 15:45:09,666 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 15:45:09,671 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s zig_zaggify_support="False" -s support_xy_overrides_z="xy_overrides_z" -s speed_equalize_flow_enabled="False" -s support_conical_enabled="False" -s switch_extruder_prime_speed="20" -s cool_fan_speed_min="100.0" -s travel_avoid_other_parts="True" -s acceleration_support_interface="500" -s jerk_skirt_brim="8" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_3="12.5" -s support_roof_height="0.8" -s cooling="0" -s speed_infill="50.0" -s infill_overlap_mm="0.12" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s cool_min_layer_time_fan_speed_max="10" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s support_offset="0" -s retraction_combing="noskin" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s skirt_line_count="3" -s conical_overhang_enabled="False" -s support_bottom_angles="[ ]" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s ironing_enabled="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s infill_support_angle="40" -s machine_firmware_retract="False" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_thickness="0.2" -s wipe_retraction_amount="6.5" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s wireframe_printspeed_up="5" -s wall_0_extruder_nr="-1" -s acceleration_infill="500" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s infill_line_distance="6.0" -s support_infill_rate="5" -s machine_max_jerk_e="5" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s outer_inset_first="False" -s raft_smoothing="5" -s wireframe_printspeed_flat="5" -s skin_no_small_gaps_heuristic="False" -s magic_fuzzy_skin_outside_only="False" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="25.0" -s filter_out_tiny_gaps="False" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s gradual_infill_steps="0" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_y="500" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s machine_name="Creality Ender-3 Pro" -s wireframe_top_delay="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s skin_angles="[ ]" -s wireframe_drag_along="0.6" -s layer_height="0.2" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_extruders_share_heater="False" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s z_seam_x="110.0" -s draft_shield_height_limitation="full" -s prime_tower_enable="False" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s draft_shield_height="10" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s machine_heated_bed="True" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s machine_steps_per_mm_x="50" -s material_bed_temp_prepend="True" -s bridge_skin_support_threshold="50" -s skin_edge_support_layers="0" -s support="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s machine_always_write_active_tool="False" -s speed_print="50.0" -s brim_replaces_support="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s jerk_topbottom="8" -s support_bottom_offset="0.0" -s machine_depth="220" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s machine_show_variants="False" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s material_bed_temperature="60" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s small_feature_speed_factor="50" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s material_standby_temperature="150" -s support_roof_density="33.333" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 15:45:09,675 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 15:45:09,679 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 15:45:09,683 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 15:45:09,687 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 15:45:09,691 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 15:45:09,695 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 15:45:09,699 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 15:45:09,705 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 15:45:09,708 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 15:45:09,714 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s wall_thickness="0.8" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s infill_mesh_order="0" -s support_meshes_present="False" -s prime_tower_position_x="208.6" -s z_seam_y="220" -s adaptive_layer_height_variation_step="0.04" -s prime_tower_flow="100" -s jerk_wall_0="8" -s support_interface_height="0.8" -s support_tree_branch_distance="1" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s roofing_material_flow="100" -s wireframe_nozzle_clearance="1" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s infill_support_enabled="False" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s top_bottom_thickness="0.8" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s raft_base_line_width="0.8" -s retraction_extra_prime_amount="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s prime_tower_position_y="186.6" -s resolution="0" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s wireframe_bottom_delay="0" -s remove_empty_first_layers="True" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s speed_support_infill="20.0" -s meshfix="0" -s speed_wall_0="25.0" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s wipe_retraction_retract_speed="25" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s z_seam_relative="False" -s retraction_hop="0.2" -s dual="0" -s machine_extruder_count="1" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="10" -s wall_min_flow_retract="False" -s jerk_infill="8" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s ironing_flow="10.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_roof_extruder_nr="0" -s bridge_enable_more_layers="True" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s skirt_brim_speed="20.0" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s wipe_move_distance="20" -s material_shrinkage_percentage="100.0" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s jerk_layer_0="8" -s ooze_shield_angle="60" -s draft_shield_dist="10" -s machine_steps_per_mm_z="50" -s machine_minimum_feedrate="0.0" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s material="0" -s expand_skins_expand_distance="0.8" -s support_brim_line_count="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s sub_div_rad_add="0.4" -s machine_max_jerk_xy="10" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s raft_margin="15" -s infill_mesh="False" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s material_diameter="1.75" -s wireframe_enabled="False" -s machine_buildplate_type="glass" -s infill_pattern="cubic" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s prime_tower_size="20" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s speed_slowdown_layers="2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s support_extruder_nr="0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[]" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s jerk_enabled="False" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s speed_topbottom="25.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s retract_at_layer_change="False" -s gantry_height="25" -s support_interface_skip_height="0.2" -s jerk_wall="8" -s infill_offset_x="0" -s machine_max_acceleration_x="500" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s lightning_infill_support_angle="40" -s minimum_polygon_circumference="1.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s speed_ironing="16.666666666666668" -s raft_surface_jerk="8" -s speed_z_hop="5" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s retraction_min_travel="1.5" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s skin_overlap_mm="0.04" -s date="23-04-2022" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="210" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s material_flow="100" -s retraction_extrusion_window="10" -s smooth_spiralized_contours="True" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s material_print_temperature="210" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s wireframe_printspeed_bottom="5" -s support_roof_material_flow="100" -s speed_roofing="25.0" -e0 -s experimental="0" -s line_width="0.4" -s top_layers="4" -s skin_monotonic="False" -s material_break_preparation_retracted_position="-16" -s skirt_brim_minimal_length="250" -s gradual_support_infill_steps="0" -s infill_line_width="0.4" -s raft_base_speed="15.0" -s minimum_roof_area="10" -s material_final_print_temperature="200" -s center_object="False" -s lightning_infill_prune_angle="40" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s machine_nozzle_head_distance="3" -s travel_compensate_overlapping_walls_enabled="True" -s retraction_combing_max_distance="30" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_bottom_line_distance="2.4000240002400024" -s prime_tower_min_volume="6" -s alternate_extra_perimeter="False" -s gradual_support_infill_step_height="1" -s raft_interface_fan_speed="0" -s prime_tower_line_width="0.4" -s infill_offset_y="0" -s support_conical_angle="30" -s machine_settings="0" -s small_feature_max_length="0.0" -s speed_wall_x="20.0" -s material_flow_layer_0="100" -s support_roof_enable="True" -s magic_fuzzy_skin_thickness="0.3" -s raft_interface_acceleration="500" -s fill_outline_gaps="False" -s raft_surface_speed="20.0" -s jerk_support_bottom="8" -s material_no_load_move_factor="0.940860215" -s material_surface_energy="100" -s infill_support_angle="40" -s extruder_prime_pos_abs="False" -s coasting_speed="90" -s acceleration_wall_0="500" -s support_roof_line_width="0.4" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s material_break_speed="25" -s acceleration_ironing="500" -s bridge_wall_material_flow="50" -s small_feature_speed_factor_0="50" -s retraction_retract_speed="25" -s support_xy_distance_overhang="0.4" -s acceleration_support_infill="500" -s bridge_fan_speed_2="0" -s infill_wall_line_count="0" -s support_angle="45" -s wall_min_flow="0" -s hole_xy_offset="0" -s mold_angle="40" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_interface_thickness="0.30000000000000004" -s support_skip_zag_per_mm="20" -s infill_material_flow="100" -s support_tree_collision_resolution="0.2" -s support_initial_layer_line_distance="8.0" -s minimum_support_area="2" -s ironing_pattern="zigzag" -s travel="0" -s max_extrusion_before_wipe="10" -s wall_line_width_x="0.4" -s skirt_brim_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s wall_line_count="2" -s switch_extruder_extra_prime_amount="0" -s support_bottom_height="0.8" -s wipe_hop_amount="0.2" -s jerk_travel_layer_0="8" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s machine_extruder_start_pos_y="0" -s mold_width="5" -s small_hole_max_size="0" -s material_initial_print_temperature="200" -s support_tree_angle="40" -s acceleration_travel_layer_0="500" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s infill_pattern="cubic" -s meshfix_maximum_resolution="0.25" -s support_brim_line_count="10" -s skirt_brim_line_width="0.4" -s speed_support_bottom="20.0" -s top_bottom_thickness="0.8" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s bottom_layers="4" -s speed_support_infill="20.0" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s skirt_brim_speed="20.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s material_flush_purge_speed="0.5" -s top_skin_preshrink="0.8" -s retraction_hop_only_when_collides="False" -s top_bottom="0" -s ironing_monotonic="False" -s bottom_thickness="0.8" -s speed_wall="20.0" -s lightning_infill_support_angle="40" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s material_break_temperature="50" -s machine_endstop_positive_direction_z="True" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s gradual_infill_steps="0" -s filter_out_tiny_gaps="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s mold_enabled="False" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s conical_overhang_enabled="False" -s support_wall_count="1" -s support_line_width="0.4" -s machine_extruders_shared_nozzle_initial_retraction="0" -s wipe_pause="0" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s jerk_support="8" -s initial_layer_line_width_factor="100.0" -s material="0" -s expand_skins_expand_distance="0.8" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_enable="True" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s clean_between_layers="False" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s acceleration_wall_x="500" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s platform_adhesion="0" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s skin_edge_support_layers="0" -s support="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s machine_nozzle_size="0.4" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s cool_fan_speed_0="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s cool_lift_head="False" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s speed_print="40.0" -s brim_replaces_support="False" -s acceleration_print="500" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s sub_div_rad_add="0.4" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s machine_steps_per_mm_x="50" -s switch_extruder_prime_speed="20" -s small_feature_speed_factor="50" -s skin_material_flow="100" -s retraction_count_max="100" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s connect_infill_polygons="False" -s resolution="0" -s infill_line_distance="6.0" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s infill_support_enabled="False" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s wall_thickness="0.8" -s machine_extruder_start_code="" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s extruder_nr="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s jerk_ironing="8" -s raft_margin="15" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s prime_tower_flow="100" -s wipe_retraction_amount="6.5" -s jerk_wall_0="8" -s support_interface_height="0.8" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s support_conical_enabled="False" -s z_seam_x="110.0" -s magic_fuzzy_skin_enabled="False" -s material_break_preparation_speed="2" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s wall_line_width_0="0.4" -s raft_interface_speed="15.0" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s jerk_wall="8" -s infill_offset_x="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s zig_zaggify_infill="False" -s roofing_material_flow="100" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_travel_layer_0="100.0" -s xy_offset="0" -s acceleration_support="500" -s material_end_of_filament_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s brim_width="8.0" -s retraction_extra_prime_amount="0" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s shell="0" -s travel_avoid_supports="True" -s raft_surface_acceleration="500" -s jerk_roofing="8" -s bridge_skin_speed="10" -s wipe_brush_pos_x="100" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s jerk_topbottom="8" -s support_bottom_stair_step_height="0.3" -s wipe_retraction_retract_speed="25" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s retraction_hop="0.2" -s dual="0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="10" -s top_thickness="0.8" -s prime_blob_enable="False" -s material_adhesion_tendency="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_steps_per_mm_z="50" -s ironing_flow="10.0" -s bridge_enable_more_layers="True" -s material_flow_dependent_temperature="False" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s machine_endstop_positive_direction_x="False" -s mesh_position_y="0" -s support_tower_diameter="3.0" -s support_interface_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s wipe_hop_speed="5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s acceleration_support_roof="500" -s bridge_skin_material_flow_3="110" -s slicing_tolerance="middle" -s support_top_distance="0.2" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s speed_topbottom="20.0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="10" -s support_pattern="zigzag" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s machine_extruder_end_pos_x="0" -s retract_at_layer_change="False" -s jerk_layer_0="8" -s cool_min_layer_time_fan_speed_max="10" -s speed_support_interface="20.0" -s wall_0_inset="0" -s support_interface_skip_height="0.2" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s jerk_prime_tower="8" -s support_roof_pattern="grid" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_ironing="13.333333333333334" -s raft_surface_jerk="8" -s speed_z_hop="5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s wall_overhang_angle="90" -s support_bottom_stair_step_min_slope="10.0" -s speed_travel="150.0" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s travel_avoid_distance="0.625" -s material_print_temperature_layer_0="200" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_flow="100" -s retraction_extrusion_window="10" -s machine_extruder_start_pos_abs="False" -s machine_extruder_end_pos_abs="False" -s raft_surface_layers="2" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s bridge_sparse_infill_max_density="0" -s raft_surface_fan_speed="0" -s infill_multiplier="1" -s material_print_temperature="200" -s speed_support_roof="20.0" -s conical_overhang_angle="50" -s roofing_pattern="lines" -s raft_jerk="8" -s speed="0" -s z_seam_position="back" -s wall_0_wipe_dist="0.0" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_skin_support_threshold="50" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s speed_roofing="20.0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s raft_smoothing="5" -s outer_inset_first="False" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s acceleration_infill="500" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s roofing_angles="[ ]" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s bridge_fan_speed="100" -s support_offset="0" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s optimize_wall_printing_order="True" -s infill_overlap_mm="0.12" -s speed_infill="40.0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s cooling="0" -s roofing_line_width="0.4" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s raft_interface_line_spacing="1.0" -s infill="0" -s travel_avoid_other_parts="True" -s raft_interface_jerk="8" -s jerk_wall_x="8" -s coasting_volume="0.064" -s material_anti_ooze_retraction_speed="5" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s support_join_distance="2.0" -s material_diameter="1.75" -s support_tower_roof_angle="65" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 15:45:10,251 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.518075942993164 seconds
    2022-04-23 15:45:10,251 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 15:45:10,252 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 15:45:10,255 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 15:45:10,260 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 15:45:10,263 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 15:45:10,271 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 15:45:28,205 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_GW support 3.2.gcode]...
    2022-04-23 15:45:28,224 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_GW support 3.2.gcode in text mode
    2022-04-23 15:45:28,335 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.08284950256347656 seconds
    2022-04-23 15:45:29,313 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 16:05:03,601 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2022-04-23 16:05:03,601 - INFO - [MainThread] cura.CuraApplication.closeApplication [612]: Close application
    2022-04-23 16:05:03,617 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-23 16:05:03,652 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 16:05:03,678 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:05:03,683 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:05:03,711 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 16:05:03,717 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:05:03,721 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:05:03,952 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [488]: Shutting down cura
    2022-04-23 16:05:04,004 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 16:05:04,082 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 16:05:04,097 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/qml/UM/Preferences/PreferencesDialog.qml:113: TypeError: Cannot read property 'resetEnabled' of null
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-23 16:24:18,207 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager._loadManagementData [197]: Loaded user packages management file from C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-23 16:24:18,207 - INFO - [MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [119]: Loading plugin configuration file 'C:\Users\Ben360\AppData\Roaming\cura\4.13\plugins.json'
    2022-04-23 16:24:18,207 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-23 16:24:18,213 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-23 16:24:18,274 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-23 16:24:18,305 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-23 16:24:18,333 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-23 16:24:18,363 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-23 16:24:18,393 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-23 16:24:18,458 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-23 16:24:18,489 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-23 16:24:18,530 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-23 16:24:18,561 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-23 16:24:18,592 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-23 16:24:18,630 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-23 16:24:18,660 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-23 16:24:18,690 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-23 16:24:18,723 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-23 16:24:18,764 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-23 16:24:18,800 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-23 16:24:18,823 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-23 16:24:18,855 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-23 16:24:18,904 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-23 16:24:18,977 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-23 16:24:19,009 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-23 16:24:19,044 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-23 16:24:19,076 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-23 16:24:19,225 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-23 16:24:19,257 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-23 16:24:19,294 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-23 16:24:19,339 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-23 16:24:19,395 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-23 16:24:19,424 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-23 16:24:19,476 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-23 16:24:19,505 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-23 16:24:19,546 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-23 16:24:19,579 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-23 16:24:19,619 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-23 16:24:20,069 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-23 16:24:20,119 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-23 16:24:20,125 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-23 16:24:20,340 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-23 16:24:20,404 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-23 16:24:20,442 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-23 16:24:20,472 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-23 16:24:20,504 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-23 16:24:20,541 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-23 16:24:20,569 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-23 16:24:20,601 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-23 16:24:20,629 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-23 16:24:20,659 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-23 16:24:20,690 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-23 16:24:20,720 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-23 16:24:20,748 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-23 16:24:20,779 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-23 16:24:20,814 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-23 16:24:20,845 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-23 16:24:20,874 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-23 16:24:20,906 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-23 16:24:20,933 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-23 16:24:20,970 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-23 16:24:20,999 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-23 16:24:21,029 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-23 16:24:21,059 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-23 16:24:21,085 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-23 16:24:21,123 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-23 16:24:21,178 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-23 16:24:21,211 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-23 16:24:21,215 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 5.261878490447998 seconds
    2022-04-23 16:24:21,235 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-23 16:24:21,324 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.08784890174865723
    2022-04-23 16:24:21,341 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-23 16:24:21,358 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-23 16:24:28,888 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 7.513747930526733 seconds
    2022-04-23 16:24:28,908 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-23 16:24:28,913 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-23 16:24:29,130 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-23 16:24:29,275 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-23 16:24:29,275 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-23 16:24:30,750 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 1.4646577835083008 seconds.
    2022-04-23 16:24:30,779 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-23 16:24:30,786 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-23 16:24:30,796 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-23 16:24:30,803 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-23 16:24:30,813 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-23 16:24:30,824 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-23 16:24:30,833 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-23 16:24:30,843 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-23 16:24:30,853 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-23 16:24:30,861 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-23 16:24:30,871 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-23 16:24:30,880 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-23 16:24:30,890 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-23 16:24:30,891 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-23 16:24:31,099 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-23 16:24:31,149 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-23 16:24:31,154 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-23 16:24:31,215 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-23 16:24:31,242 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 16:24:31,254 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-23 16:24:31,284 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.004029273986816406 seconds
    2022-04-23 16:24:31,305 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.011520624160766602 seconds. 8 input vertices. 8 output vertices.
    2022-04-23 16:24:31,346 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 16:24:31,361 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 16:24:31,570 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-23 16:24:32,594 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-23 16:24:32,604 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[bfc41645][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "42bbc295-bf6d-4b46-a6db-bb30696e3a20", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 16:24:32,628 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 16:24:34,496 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-23 16:24:34,693 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-23 16:24:34,889 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-23 16:24:35,152 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-23 16:24:35,515 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:24:35,734 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 16:24:35,932 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:24:36,244 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 16:24:36,260 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-23 16:24:36,284 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-23 16:24:36,289 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-23 16:24:36,413 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-23 16:24:36,424 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.getAccessTokenUsingRefreshToken [64]: Refreshing the access token for [https://account.ultimaker.com]
    2022-04-23 16:24:36,429 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=STLReader:1.0.1&installed_packages=FileLogger:1.0.1&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=GCodeWriter:1.0.1&installed_packages=SelectionTool:1.0.1&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=UltimakerPC:1.4.0&installed_packages=GenericCPEPlus:1.4.0&installed_packages=ConsoleLogger:1.0.1&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=VertexDeltaABS:1.4.0&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=3MFWriter:1.0.1&installed_packages=CuraEngineBackend:1.0.1&installed_packages=SimulationView:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=LegacyProfileReader:1.0.1&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=RotateTool:1.0.1&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=TranslateTool:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=FirmwareUpdater:1.0.1&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=FABtotumPLA:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=UltimakerBAM:1.4.0&installed_packages=Filo3DPLA:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=OBJWriter:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=MonitorStage:1.0.1&installed_packages=GenericHIPS:1.4.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=UFPReader:1.0.0&installed_packages=GenericTPU:1.4.0&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericABS:1.4.0&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=PrepareStage:1.0.1&installed_packages=3MFReader:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=FABtotumTPU:1.4.0&installed_packages=GenericCFFCPE:1.4.0&installed_packages=SupportEraser:1.0.1&installed_packages=GCodeGzReader:1.0.1&installed_packages=CuraProfileWriter:1.0.1&installed_packages=FABtotumNylon:1.4.0&installed_packages=SimpleView:1.0.1&installed_packages=UltimakerPLA:1.4.0&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=ModelChecker:1.0.1&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=GenericPVA:1.4.0&installed_packages=SentryLogger:1.0.0&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=SolidView:1.0.1&installed_packages=GenericPP:1.4.0&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=MirrorTool:1.0.1&installed_packages=UltimakerPP:1.4.0&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=UltimakerCPE:1.4.0&installed_packages=UFPWriter:1.0.1&installed_packages=UpdateChecker:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=PreviewStage:1.0.1&installed_packages=CameraTool:1.0.1&installed_packages=GCodeReader:1.0.1&installed_packages=UltimakerNylon:1.4.0&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=FABtotumABS:1.4.0&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=UltimakerPVA:1.4.0&installed_packages=GenericPETG:1.4.0&installed_packages=GCodeProfileReader:1.0.1&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=XRayView:1.0.1&installed_packages=GenericGFFPA:1.4.0&installed_packages=UltimakerTPLA:1.4.0&installed_packages=UltimakerABS:1.4.0&installed_packages=TrimeshReader:1.0.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=LocalContainerProvider:1.0.1&installed_packages=PolyFlexPLA:1.0.1&installed_packages=GenericNylon:1.4.0&installed_packages=DigitalLibrary:1.1.0&installed_packages=ImageReader:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=AMFReader:1.0.0&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=ScaleTool:1.0.1&installed_packages=GenericPC:1.4.0&installed_packages=PolyPlusPLA:1.0.1&installed_packages=Toolbox:1.0.1&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=VertexDeltaPET:1.4.0&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=PolyWoodPLA:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=STLWriter:1.0.1&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=GenericPLA:1.4.0&installed_packages=GenericGFFCPE:1.4.0
    2022-04-23 16:24:36,444 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 21.570224046707153 seconds
    2022-04-23 16:24:36,444 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-23 16:24:36,510 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x000002321C1154C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-23 16:24:36,522 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 16:24:36,533 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 16:24:36,934 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-23 16:24:36,944 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-23 16:24:36,966 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-23 16:24:37,525 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-23 16:24:37,560 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-23 16:24:37,568 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-23 16:24:37,573 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-23 16:24:37,578 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-23 16:24:37,586 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-23 16:24:37,594 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 16:24:37,629 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-23 16:24:37,650 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-23 16:24:37,668 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 16:24:37,687 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-23 16:24:37,728 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 16:24:37,768 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 16:24:37,807 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 16:24:37,836 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 16:24:37,864 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 16:24:37,885 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-23 16:24:37,921 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-23 16:24:37,937 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-23 16:24:37,961 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-23 16:24:38,049 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 16:24:38,821 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[90611011][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "832bfc65-4f7c-45f9-a978-72a820536241"}'
    2022-04-23 16:24:38,826 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[a8613f95][post][PyQt5.QtCore.QUrl('https://account.ultimaker.com/token')][timeout=None][b'client_id='...] got an QNetworkReplyError Error transferring https://account.ultimaker.com/token - server replied: Bad Request. The server returned: b'{"error": "invalid_grant", "error_description": "OAuth invalid grant.", "error_details": "The provided authorization grant (e.g., authorization code, resource owner credentials) or refresh token is invalid, expired, revoked, does not match the redirection URI used in the authorization request, or was issued to another client.", "request_id": "3328a1f8-0076-4627-8626-9bebb52c5ed0"}'
    2022-04-23 16:24:38,860 - DEBUG - [MainThread] cura.OAuth2.AuthorizationHelpers.checkToken [115]: Checking the access token for [https://account.ultimaker.com/check-token]
    2022-04-23 16:24:38,866 - WARNING - [MainThread] UM.Logger.warning [143]: Failed to get a new access token from the server.
    2022-04-23 16:24:39,467 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestError [376]: request[062e809d][get][PyQt5.QtCore.QUrl('https://account.ultimaker.com/check-token')][timeout=None][no-data] got an QNetworkReplyError Error transferring https://account.ultimaker.com/check-token - server replied: Forbidden. The server returned: b'{"errors": [{"id": "a9fd48c8-3851-455b-b8c5-f58877e82317", "code": "invalidToken", "http_status": "403", "title": "The given token is invalid.", "meta": {"error_type": "AuthError", "url": "https://account.ultimaker.com/check-token"}}]}'
    2022-04-23 16:24:39,487 - WARNING - [MainThread] UM.Logger.warning [143]: The user profile could not be loaded. The user must log in again!
    2022-04-23 16:24:39,493 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [289]: Attempting to store the auth data for [https://account.ultimaker.com]
    2022-04-23 16:24:39,497 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._storeAuthData [300]: Clearing the user profile
    2022-04-23 16:24:39,503 - WARNING - [MainThread] UM.Logger.warning [143]: Unable to get user profile using auth data from preferences.
    2022-04-23 16:24:40,303 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 8.9s
    2022-04-23 16:24:49,586 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.02472376823425293 seconds
    2022-04-23 16:25:04,487 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.016305208206176758 seconds
    2022-04-23 16:25:05,905 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/GW support 3.1 (1).stl
    2022-04-23 16:25:05,912 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 16:25:05,919 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 16:25:05,921 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 1842 vertices
    2022-04-23 16:25:05,933 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.003985404968261719 seconds. 32 input vertices. 32 output vertices.
    2022-04-23 16:25:05,944 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 16:25:05,957 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.005547523498535156 seconds. 32 input vertices. 32 output vertices.
    2022-04-23 16:25:05,974 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000023236A6D550>, took 1ms
    2022-04-23 16:25:06,014 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:06,254 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:25:06,258 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:25:06,264 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:25:06,269 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 16:25:12,039 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 16:25:14,024 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 4ms
    2022-04-23 16:25:14,054 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 16:25:14,075 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 16:25:14,093 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.114,0.000>), took 3ms
    2022-04-23 16:25:14,111 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,127 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,143 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 16:25:14,161 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,186 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,200 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,226 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.000,0.000>), took 1ms
    2022-04-23 16:25:14,243 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.000,0.000>), took 2ms
    2022-04-23 16:25:14,261 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,277 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 2ms
    2022-04-23 16:25:14,294 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,310 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 2ms
    2022-04-23 16:25:14,327 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 2ms
    2022-04-23 16:25:14,344 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.115,0.000>), took 2ms
    2022-04-23 16:25:14,362 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.115,0.000>), took 1ms
    2022-04-23 16:25:14,380 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.229,0.000>), took 1ms
    2022-04-23 16:25:14,409 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 3ms
    2022-04-23 16:25:14,426 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.230,0.000>), took 2ms
    2022-04-23 16:25:14,445 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 3ms
    2022-04-23 16:25:14,461 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 1ms
    2022-04-23 16:25:14,477 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.116,0.000>), took 1ms
    2022-04-23 16:25:14,495 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 1ms
    2022-04-23 16:25:14,511 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.230,0.000>), took 2ms
    2022-04-23 16:25:14,543 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 1ms
    2022-04-23 16:25:14,560 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 16:25:14,578 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.116,0.000>), took 2ms
    2022-04-23 16:25:14,596 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.230,0.000>), took 2ms
    2022-04-23 16:25:14,625 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.230,0.000>), took 2ms
    2022-04-23 16:25:14,644 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.115,0.000>), took 2ms
    2022-04-23 16:25:14,660 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.115,0.000>), took 1ms
    2022-04-23 16:25:14,677 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.001,0.000>), took 1ms
    2022-04-23 16:25:14,694 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 1ms
    2022-04-23 16:25:14,711 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.115,0.000>), took 1ms
    2022-04-23 16:25:14,957 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.115,0.000>), took 4ms
    2022-04-23 16:25:14,984 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.114,0.000>), took 3ms
    2022-04-23 16:25:15,000 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.347,0.000>), took 1ms
    2022-04-23 16:25:15,025 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.460,0.000>), took 2ms
    2022-04-23 16:25:15,042 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.460,0.000>), took 2ms
    2022-04-23 16:25:15,060 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.229,0.000>), took 1ms
    2022-04-23 16:25:15,078 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.573,0.000>), took 1ms
    2022-04-23 16:25:15,094 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.230,0.000>), took 1ms
    2022-04-23 16:25:15,111 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.229,0.000>), took 3ms
    2022-04-23 16:25:15,127 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.345,0.000>), took 1ms
    2022-04-23 16:25:15,144 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.571,0.000>), took 3ms
    2022-04-23 16:25:15,161 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.114,0.000>), took 1ms
    2022-04-23 16:25:15,178 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.343,0.000>), took 2ms
    2022-04-23 16:25:15,195 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.000,0.000>), took 1ms
    2022-04-23 16:25:15,210 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.571,0.000>), took 2ms
    2022-04-23 16:25:15,227 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.113,0.000>), took 1ms
    2022-04-23 16:25:15,244 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.456,0.000>), took 3ms
    2022-04-23 16:25:15,260 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.342,0.000>), took 1ms
    2022-04-23 16:25:15,277 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.227,0.000>), took 2ms
    2022-04-23 16:25:15,294 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.114,0.000>), took 1ms
    2022-04-23 16:25:15,310 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.227,0.000>), took 1ms
    2022-04-23 16:25:15,326 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,0.114,0.000>), took 1ms
    2022-04-23 16:25:15,605 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.000,0.000>), took 2ms
    2022-04-23 16:25:15,626 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.113,0.000>), took 1ms
    2022-04-23 16:25:15,660 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 3ms
    2022-04-23 16:25:15,677 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.342,0.000>), took 1ms
    2022-04-23 16:25:15,693 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.113,0.000>), took 2ms
    2022-04-23 16:25:15,710 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.114,0.000>), took 1ms
    2022-04-23 16:25:15,727 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: TranslateOp.(node=<CuraSceneNode object: 'GW support 3.1 (1).stl'>,trans.=<0.000,-0.228,0.000>), took 2ms
    2022-04-23 16:25:15,857 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: PlatformPhysicsOp.(trans.=<0.000,-2.626,0.000>), took 2ms
    2022-04-23 16:25:18,141 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 16:25:18,151 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 16:25:18,162 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 16:25:18,191 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 16:25:18,215 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 16:25:18,544 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 16:25:18,545 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 16:25:18,889 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.3444554805755615 seconds
    2022-04-23 16:25:19,005 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="16:25:18" -s print_bed_temperature="60" -s material_name="empty" -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s machine_heated_build_volume="False" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s machine_height="250" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s support_pattern="zigzag" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s wireframe_bottom_delay="0" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s wireframe_printspeed_up="5" -s support_roof_height="0.8" -s wireframe_printspeed_bottom="5" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="25.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s wireframe_printspeed_down="5" -s skirt_brim_minimal_length="250" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_roof_density="33.333" -s material_standby_temperature="150" -s line_width="0.4" -s prime_tower_enable="False" -s jerk_wall_x="8" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s wireframe_top_delay="0" -s raft_surface_fan_speed="0" -s skin_monotonic="False" -s switch_extruder_extra_prime_amount="0" -s speed_ironing="16.666666666666668" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s adaptive_layer_height_enabled="False" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s cutting_mesh="False" -s wireframe_printspeed="5" -s infill_overlap="30.0" -s machine_extruders_share_heater="False" -s wireframe_height="3" -s ooze_shield_dist="2" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s layer_height="0.2" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s top_thickness="0.8" -s material_break_preparation_temperature="210" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s draft_shield_height_limitation="full" -s resolution="0" -s prime_tower_position_y="186.6" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s support_roof_enable="True" -s bridge_fan_speed_2="0" -s coasting_speed="90" -s support_offset="0" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s support_bottom_angles="[ ]" -s ironing_enabled="False" -s support_tower_diameter="3.0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s material_anti_ooze_retraction_speed="5" -s draft_shield_height="10" -s raft_surface_speed="20.0" -s acceleration_topbottom="500" -s skin_outline_count="1" -s blackmagic="0" -s zig_zaggify_infill="False" -s jerk_wall_0="8" -s wall_extruder_nr="-1" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s bridge_skin_density_2="75" -s machine_depth="220" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s extruder_prime_pos_abs="False" -s support_roof_offset="0.0" -s jerk_enabled="False" -s layer_start_x="0.0" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s adaptive_layer_height_variation_step="0.04" -s wireframe_flow_flat="100" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s machine_steps_per_mm_z="50" -s wipe_retraction_retract_speed="25" -s raft_interface_thickness="0.30000000000000004" -s bridge_skin_support_threshold="50" -s material_break_preparation_retracted_position="-16" -s skin_angles="[ ]" -s acceleration_ironing="500" -s support_infill_extruder_nr="0" -s speed_equalize_flow_max="150" -s retract_at_layer_change="False" -s retraction_combing="noskin" -s wipe_hop_amount="0.2" -s retraction_retract_speed="25" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_2="12.5" -s bottom_thickness="0.8" -s infill_extruder_nr="-1" -s support_bottom_stair_step_min_slope="10.0" -s support_xy_overrides_z="xy_overrides_z" -s infill_multiplier="1" -s ironing_flow="10.0" -s speed_travel="150.0" -s default_material_print_temperature="210" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s acceleration_support="500" -s xy_offset="0" -s speed_support_infill="20.0" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s small_feature_speed_factor_0="50" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s wipe_retraction_amount="6.5" -s speed_slowdown_layers="2" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s conical_overhang_enabled="False" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_firmware_retract="False" -s infill_support_angle="40" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s z_seam_relative="False" -s date="23-04-2022" -s machine_heat_zone_length="16" -s machine_max_jerk_e="5" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_always_write_active_tool="False" -s cross_infill_density_image="" -s machine_nozzle_expansion_angle="45" -s extruder_prime_pos_z="0" -s machine_max_acceleration_y="500" -s infill_pattern="cubic" -s experimental="0" -s support_wall_count="1" -s material_bed_temperature_layer_0="60" -s jerk_travel="8" -s roofing_layer_count="0" -s support_brim_enable="True" -s material_initial_print_temperature="210" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s brim_width="8.0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s outer_inset_first="False" -s mold_roof_height="0.5" -s infill_sparse_density="20" -s retraction_enable="True" -s brim_gap="0" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s wireframe_fall_down="0.5" -s z_seam_x="110.0" -s prime_tower_min_volume="6" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s support_enable="True" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s material_flow_layer_0="100" -s roofing_material_flow="100" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s filter_out_tiny_gaps="False" -s skin_material_flow="100" -s wireframe_roof_inset="3" -s raft_jerk="8" -s material_final_print_temperature="210" -s support_tree_angle="40" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s wireframe_straight_before_down="20" -s infill="0" -s raft_interface_line_spacing="1.0" -s center_object="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s wall_0_extruder_nr="-1" -s material_adhesion_tendency="10" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 16:25:19,015 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 16:25:19,019 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 16:25:19,029 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 16:25:19,039 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 16:25:19,044 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 16:25:19,054 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:25:19,064 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 16:25:19,069 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 16:25:19,074 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 16:25:19,079 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 16:25:19,084 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:25:19,089 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 16:25:19,094 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s jerk_layer_0="8" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s machine_show_variants="False" -s prime_tower_flow="100" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_speed_3="12.5" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s retraction_extra_prime_amount="0" -s wireframe_roof_fall_down="2" -s roofing_pattern="lines" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s mold_angle="40" -s gradual_infill_steps="0" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s smooth_spiralized_contours="True" -s wireframe_top_jump="0.6" -s top_bottom_thickness="0.8" -s support_roof_extruder_nr="0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_bottom_extruder_nr="0" -s speed_travel_layer_0="100.0" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s support_bottom_enable="True" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s material_diameter="1.75" -s wireframe_enabled="False" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s jerk_ironing="8" -s infill_mesh="False" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_crystallinity="False" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s jerk_support="8" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s material_bed_temp_prepend="True" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_extruder_count="1" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s default_material_bed_temperature="60" -s machine_max_jerk_xy="10" -s wireframe_drag_along="0.6" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s layer_0_z_overlap="0.15" -s support_type="everywhere" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s retraction_hop="0.2" -s dual="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s raft_base_fan_speed="0" -s sub_div_rad_add="0.4" -s machine_name="Creality Ender-3 Pro" -s initial_layer_line_width_factor="100.0" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s material_bed_temperature="60" -s lightning_infill_prune_angle="40" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s wall_overhang_angle="90" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s support_line_distance="8.0" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s gantry_height="25" -s support_interface_skip_height="0.2" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s wipe_repeat_count="5" -s cool_lift_head="False" -s fill_outline_gaps="False" -s infill_offset_x="0" -s jerk_wall="8" -s machine_max_acceleration_x="500" -s raft_interface_fan_speed="0" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s meshfix_union_all_remove_holes="False" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s optimize_wall_printing_order="True" -s machine_extruders_share_nozzle="False" -s support_angle="45" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s prime_tower_size="20" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s jerk_travel_layer_0="8" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="25.0" -s wireframe_strategy="compensate" -s slicing_tolerance="middle" -s wireframe_printspeed_flat="5" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s support_extruder_nr="0" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_use_extruder_offset_to_offset_coords="True" -s machine_endstop_positive_direction_x="False" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_extrusion_cool_down_speed="0.7" -s machine_max_feedrate_x="500" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s flow_rate_max_extrusion_offset="0" -s material_print_temperature="210" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 16:25:19,099 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 16:25:19,103 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 16:25:19,108 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 16:25:19,113 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 16:25:19,118 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 16:25:19,123 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 16:25:19,129 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 16:25:19,133 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 16:25:19,138 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 16:25:19,146 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s support_interface_height="0.8" -s gradual_support_infill_steps="0" -s machine_buildplate_type="glass" -s speed_wall="25.0" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s draft_shield_enabled="False" -s material_break_temperature="50" -s z_seam_type="back" -s acceleration_enabled="False" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s remove_empty_first_layers="True" -s raft_interface_acceleration="500" -s material_guid="" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s jerk_prime_tower="8" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_roof_pattern="grid" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_max_feedrate_z="10" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s ooze_shield_angle="60" -s speed_infill="50.0" -s support_brim_line_count="10" -s ooze_shield_enabled="False" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s speed_wall_0="25.0" -s meshfix="0" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -e0 -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s jerk_support_roof="8" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s acceleration_print="500" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s infill_line_width="0.4" -s support_pattern="zigzag" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s support_roof_height="0.8" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="20.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s skirt_brim_minimal_length="250" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s travel_compensate_overlapping_walls_0_enabled="False" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s machine_extruder_start_pos_y="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s line_width="0.4" -s jerk_wall_x="8" -s extruder_nr="0" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s raft_surface_fan_speed="0" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s skin_monotonic="False" -s alternate_extra_perimeter="False" -s switch_extruder_extra_prime_amount="0" -s skin_material_flow="100" -s speed_ironing="13.333333333333334" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s infill_overlap="30.0" -s resolution="0" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s top_thickness="0.8" -s material_break_preparation_temperature="200" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s gradual_infill_steps="0" -s initial_layer_line_width_factor="100.0" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_skip_zag_per_mm="20" -s speed_support_infill="20.0" -s bottom_layers="4" -s small_feature_speed_factor_0="50" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_retraction_amount="6.5" -s magic_fuzzy_skin_enabled="False" -s prime_tower_min_volume="6" -s z_seam_x="110.0" -s lightning_infill_prune_angle="40" -s mold_roof_height="0.5" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_layer_0="100" -s raft_base_jerk="8" -s acceleration_support="500" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s xy_offset="0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_offset="0.0" -s support_brim_enable="True" -s layer_start_x="0.0" -s support_wall_count="1" -s ironing_enabled="False" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruder_prime_pos_y="0" -s retraction_hop="0.2" -s dual="0" -s material_break_preparation_speed="2" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s wall_overhang_angle="90" -s conical_overhang_enabled="False" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_extruder_end_pos_x="0" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s infill_support_angle="40" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s z_seam_relative="False" -s machine_heat_zone_length="16" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s cool_lift_head="False" -s speed_print="40.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extra_prime_amount="0" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_z="0" -s filter_out_tiny_gaps="False" -s speed_wall_x="20.0" -s support_interface_material_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s machine_nozzle_size="0.4" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s skirt_brim_speed="20.0" -s hole_xy_offset="0" -s material_crystallinity="False" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s roofing_material_flow="100" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s jerk_support="8" -s brim_width="8.0" -s outer_inset_first="False" -s material_initial_print_temperature="200" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s material_diameter="1.75" -s prime_tower_flow="100" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s jerk_ironing="8" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s material_final_print_temperature="200" -s raft_jerk="8" -s support_tree_angle="40" -s support_bottom_enable="True" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s jerk_layer_0="8" -s infill="0" -s raft_interface_line_spacing="1.0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s infill_offset_x="0" -s jerk_wall="8" -s speed_travel="150.0" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s bridge_skin_speed_3="10" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s machine_nozzle_cool_down_speed="2.0" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s sub_div_rad_add="0.4" -s top_bottom_thickness="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s support_offset="0" -s bridge_fan_speed_2="0" -s infill_pattern="cubic" -s experimental="0" -s optimize_wall_printing_order="True" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s jerk_travel_layer_0="8" -s machine_extruder_cooling_fan_number="0" -s jerk_travel="8" -s roofing_layer_count="0" -s speed_equalize_flow_max="150" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="20.0" -s slicing_tolerance="middle" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_endstop_positive_direction_x="False" -s material_extrusion_cool_down_speed="0.7" -s z_seam_y="220" -s machine_extruder_start_code="" -s machine_extruder_end_code="" -s jerk_prime_tower="8" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s skin_angles="[ ]" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s coasting_volume="0.064" -s support_angle="45" -s support_bottom_stair_step_height="0.3" -s roofing_pattern="lines" -s support_interface_height="0.8" -s jerk_wall_0="8" -s gradual_support_infill_steps="0" -s speed_wall="20.0" -s bottom_thickness="0.8" -s coasting_speed="90" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s machine_extruder_start_pos_abs="False" -s wall_0_wipe_dist="0.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s infill_before_walls="False" -s minimum_interface_area="10" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s raft_interface_acceleration="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="10" -s jerk_roofing="8" -s material_print_temperature="200" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_infill="40.0" -s acceleration_ironing="500" -s material_break_temperature="50" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s bridge_skin_support_threshold="50" -s support_brim_line_count="10" -s bridge_fan_speed="100" -s support_top_distance="0.2" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -s meshfix_maximum_resolution="0.25" -s default_material_print_temperature="200" -s ironing_flow="10.0" -s infill_multiplier="1" -s support_bottom_stair_step_min_slope="10.0" -s support_roof_enable="True" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s support_interface_density="33.333" -s bridge_skin_speed_2="10" -s machine_steps_per_mm_e="1600" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s wipe_hop_amount="0.2" -s retract_at_layer_change="False" -s raft_interface_thickness="0.30000000000000004" -s wipe_retraction_retract_speed="25" -s machine_steps_per_mm_z="50" -s roofing_line_width="0.4" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s bridge_skin_density_2="75" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s extruder_prime_pos_abs="False" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s zig_zaggify_infill="False" -s raft_surface_speed="20.0" -s material_anti_ooze_retraction_speed="5" -s support_tower_diameter="3.0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s support_bottom_angles="[ ]" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 16:25:19,912 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.3671314716339111 seconds
    2022-04-23 16:25:19,913 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 16:25:19,913 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 16:25:19,929 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 16:25:19,935 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 16:25:19,939 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 16:25:19,940 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 16:25:26,919 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 16:25:29,077 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 16:25:29,124 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 16:25:29,125 - INFO - [MainThread] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 16:25:29,140 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 16:25:29,141 - DEBUG - [MainThread] STLReader.STLReader._read [105]: Loaded a mesh with 12612 vertices
    2022-04-23 16:25:29,146 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\simulationview_composite.shader]...
    2022-04-23 16:25:29,214 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 16:25:29,352 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.1370089054107666 seconds
    2022-04-23 16:25:29,491 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 16:25:29,507 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d.shader]...
    2022-04-23 16:25:29,589 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d_shadow.shader]...
    2022-04-23 16:25:29,642 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 16:25:29,653 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-23 16:25:29,663 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 16:25:29,724 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 16:25:36,969 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.02627706527709961 seconds
    2022-04-23 16:56:21,610 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000023226926040>, took 4ms
    2022-04-23 16:56:21,812 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 16:56:21,816 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 16:56:21,820 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 16:56:21,825 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 16:56:22,514 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 16:56:25,621 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 16:56:25,626 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 16:56:25,689 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:56:25,895 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 16:56:32,309 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/THWACK-sudo.stl
    2022-04-23 16:56:32,314 - INFO - [JobQueueWorker [1]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 16:56:32,326 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0009987354278564453 seconds
    2022-04-23 16:56:32,327 - DEBUG - [JobQueueWorker [1]] STLReader.STLReader._read [105]: Loaded a mesh with 8046 vertices
    2022-04-23 16:56:32,360 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.021979093551635742 seconds. 526 input vertices. 526 output vertices.
    2022-04-23 16:56:32,380 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 16:56:32,407 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.016671180725097656 seconds. 526 input vertices. 526 output vertices.
    2022-04-23 16:56:32,431 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000023228E90F40>, took 3ms
    2022-04-23 16:56:32,474 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-23 16:56:32,726 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:56:32,734 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:56:32,742 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:56:40,222 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-23 16:56:42,525 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03649592399597168 seconds
    2022-04-23 16:56:52,996 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 16:56:53,013 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 16:56:53,033 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 16:56:53,057 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 16:56:53,062 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 16:56:53,081 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<-0.0,-0.13052619222005157,-0.0,w=0.9914448613738104>), took 7ms
    2022-04-23 16:56:53,206 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<-0.0,-0.13052619222005157,-0.0,w=0.9914448613738104>), took 8ms
    2022-04-23 16:56:53,276 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:56:53,281 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 16:56:53,289 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 16:56:53,289 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 16:56:53,296 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 16:56:53,298 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:56:53,305 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 16:56:53,312 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 16:56:53,320 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 16:56:53,323 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 16:56:53,331 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:56:53,338 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 16:56:53,344 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 16:56:53,347 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 16:56:53,357 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 16:56:53,362 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:56:53,367 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 16:56:53,372 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 16:56:53,406 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<-0.0,-0.13052619222005157,-0.0,w=0.9914448613738104>), took 6ms
    2022-04-23 16:56:53,648 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<-0.0,-0.13052619222005157,-0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 16:56:54,655 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<-0.0,-0.13052619222005157,-0.0,w=0.9914448613738104>), took 8ms
    2022-04-23 16:57:12,749 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: LayFlatOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>), took 0ms
    2022-04-23 16:57:16,912 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: LayFlatOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>), took 0ms
    2022-04-23 16:57:26,894 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 18ms
    2022-04-23 16:57:27,045 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:27,279 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:27,576 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:27,945 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 5ms
    2022-04-23 16:57:28,209 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,0.0,0.13052619222005157,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:29,123 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: PlatformPhysicsOp.(trans.=<0.000,-51.500,0.000>), took 3ms
    2022-04-23 16:57:37,649 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 3ms
    2022-04-23 16:57:37,877 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 16:57:38,125 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:38,461 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 4ms
    2022-04-23 16:57:39,542 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 5ms
    2022-04-23 16:57:40,899 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.13052619222005157,0.0,0.0,w=0.9914448613738104>), took 6ms
    2022-04-23 16:57:42,139 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: PlatformPhysicsOp.(trans.=<0.000,-20.997,0.000>), took 1ms
    2022-04-23 16:57:59,994 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/THWACK-sudo.stl
    2022-04-23 16:58:00,000 - INFO - [JobQueueWorker [0]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 16:58:00,020 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 16:58:00,025 - DEBUG - [JobQueueWorker [0]] STLReader.STLReader._read [105]: Loaded a mesh with 8046 vertices
    2022-04-23 16:58:00,057 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.020943403244018555 seconds. 526 input vertices. 526 output vertices.
    2022-04-23 16:58:00,072 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 16:58:00,104 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.021941184997558594 seconds. 526 input vertices. 526 output vertices.
    2022-04-23 16:58:00,125 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000023228EB2730>, took 0ms
    2022-04-23 16:58:00,170 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,rot.=Q<0.0,4.0,0.0,w=-2.4492935982947064e-16>) TranslateOp.(node=<CuraSceneNode object: 'THWACK-sudo.stl'>,trans.=<6.426,0.000,45.308>), took 3ms
    2022-04-23 16:58:00,780 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:00,804 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:00,819 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:05,650 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/THWACK-V2.stl
    2022-04-23 16:58:05,656 - INFO - [JobQueueWorker [1]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 16:58:05,671 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.001995086669921875 seconds
    2022-04-23 16:58:05,673 - DEBUG - [JobQueueWorker [1]] STLReader.STLReader._read [105]: Loaded a mesh with 9408 vertices
    2022-04-23 16:58:05,706 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.023909568786621094 seconds. 543 input vertices. 543 output vertices.
    2022-04-23 16:58:05,719 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-23 16:58:05,752 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.022830486297607422 seconds. 543 input vertices. 543 output vertices.
    2022-04-23 16:58:05,779 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000023228EBCF40>, took 2ms
    2022-04-23 16:58:05,821 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'THWACK-V2.stl'>,rot.=Q<0.0,4.0,0.0,w=-2.4492935982947064e-16>) TranslateOp.(node=<CuraSceneNode object: 'THWACK-V2.stl'>,trans.=<7.590,0.000,-54.309>), took 2ms
    2022-04-23 16:58:06,441 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:06,446 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:06,450 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 16:58:15,902 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04160904884338379 seconds
    2022-04-23 16:58:22,641 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 16:58:22,648 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 16:58:22,655 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 16:58:22,670 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 16:58:22,684 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 16:58:22,890 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 16:58:22,890 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 16:58:23,126 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.23438358306884766 seconds
    2022-04-23 16:58:23,320 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="16:58:22" -s print_bed_temperature="60" -s material_name="empty" -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s machine_heated_build_volume="False" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s machine_height="250" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s support_pattern="zigzag" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s wireframe_bottom_delay="0" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s wireframe_printspeed_up="5" -s support_roof_height="0.8" -s wireframe_printspeed_bottom="5" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="25.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s wireframe_printspeed_down="5" -s skirt_brim_minimal_length="250" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_roof_density="33.333" -s material_standby_temperature="150" -s line_width="0.4" -s prime_tower_enable="False" -s jerk_wall_x="8" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s wireframe_top_delay="0" -s raft_surface_fan_speed="0" -s skin_monotonic="False" -s switch_extruder_extra_prime_amount="0" -s speed_ironing="16.666666666666668" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s adaptive_layer_height_enabled="False" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s cutting_mesh="False" -s wireframe_printspeed="5" -s infill_overlap="30.0" -s machine_extruders_share_heater="False" -s wireframe_height="3" -s ooze_shield_dist="2" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s layer_height="0.2" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s top_thickness="0.8" -s material_break_preparation_temperature="210" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s draft_shield_height_limitation="full" -s resolution="0" -s prime_tower_position_y="186.6" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s support_roof_enable="True" -s bridge_fan_speed_2="0" -s coasting_speed="90" -s support_offset="0" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s support_bottom_angles="[ ]" -s ironing_enabled="False" -s support_tower_diameter="3.0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s material_anti_ooze_retraction_speed="5" -s draft_shield_height="10" -s raft_surface_speed="20.0" -s acceleration_topbottom="500" -s skin_outline_count="1" -s blackmagic="0" -s zig_zaggify_infill="False" -s jerk_wall_0="8" -s wall_extruder_nr="-1" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s bridge_skin_density_2="75" -s machine_depth="220" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s extruder_prime_pos_abs="False" -s support_roof_offset="0.0" -s jerk_enabled="False" -s layer_start_x="0.0" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s adaptive_layer_height_variation_step="0.04" -s wireframe_flow_flat="100" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s machine_steps_per_mm_z="50" -s wipe_retraction_retract_speed="25" -s raft_interface_thickness="0.30000000000000004" -s bridge_skin_support_threshold="50" -s material_break_preparation_retracted_position="-16" -s skin_angles="[ ]" -s acceleration_ironing="500" -s support_infill_extruder_nr="0" -s speed_equalize_flow_max="150" -s retract_at_layer_change="False" -s retraction_combing="noskin" -s wipe_hop_amount="0.2" -s retraction_retract_speed="25" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_2="12.5" -s bottom_thickness="0.8" -s infill_extruder_nr="-1" -s support_bottom_stair_step_min_slope="10.0" -s support_xy_overrides_z="xy_overrides_z" -s infill_multiplier="1" -s ironing_flow="10.0" -s speed_travel="150.0" -s default_material_print_temperature="210" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s acceleration_support="500" -s xy_offset="0" -s speed_support_infill="20.0" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s small_feature_speed_factor_0="50" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s wipe_retraction_amount="6.5" -s speed_slowdown_layers="2" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s conical_overhang_enabled="False" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_firmware_retract="False" -s infill_support_angle="40" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s z_seam_relative="False" -s date="23-04-2022" -s machine_heat_zone_length="16" -s machine_max_jerk_e="5" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_always_write_active_tool="False" -s cross_infill_density_image="" -s machine_nozzle_expansion_angle="45" -s extruder_prime_pos_z="0" -s machine_max_acceleration_y="500" -s infill_pattern="cubic" -s experimental="0" -s support_wall_count="1" -s material_bed_temperature_layer_0="60" -s jerk_travel="8" -s roofing_layer_count="0" -s support_brim_enable="True" -s material_initial_print_temperature="210" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s brim_width="8.0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s outer_inset_first="False" -s mold_roof_height="0.5" -s infill_sparse_density="20" -s retraction_enable="True" -s brim_gap="0" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s wireframe_fall_down="0.5" -s z_seam_x="110.0" -s prime_tower_min_volume="6" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s support_enable="True" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s material_flow_layer_0="100" -s roofing_material_flow="100" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s filter_out_tiny_gaps="False" -s skin_material_flow="100" -s wireframe_roof_inset="3" -s raft_jerk="8" -s material_final_print_temperature="210" -s support_tree_angle="40" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s wireframe_straight_before_down="20" -s infill="0" -s raft_interface_line_spacing="1.0" -s center_object="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s wall_0_extruder_nr="-1" -s material_adhesion_tendency="10" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 16:58:23,330 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 16:58:23,335 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 16:58:23,340 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 16:58:23,345 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 16:58:23,350 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 16:58:23,358 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 16:58:23,363 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 16:58:23,368 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 16:58:23,378 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 16:58:23,383 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 16:58:23,389 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 16:58:23,394 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s jerk_layer_0="8" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s machine_show_variants="False" -s prime_tower_flow="100" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_speed_3="12.5" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s retraction_extra_prime_amount="0" -s wireframe_roof_fall_down="2" -s roofing_pattern="lines" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s mold_angle="40" -s gradual_infill_steps="0" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s smooth_spiralized_contours="True" -s wireframe_top_jump="0.6" -s top_bottom_thickness="0.8" -s support_roof_extruder_nr="0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_bottom_extruder_nr="0" -s speed_travel_layer_0="100.0" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s support_bottom_enable="True" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s material_diameter="1.75" -s wireframe_enabled="False" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s jerk_ironing="8" -s infill_mesh="False" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_crystallinity="False" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s jerk_support="8" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s material_bed_temp_prepend="True" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_extruder_count="1" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s default_material_bed_temperature="60" -s machine_max_jerk_xy="10" -s wireframe_drag_along="0.6" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s layer_0_z_overlap="0.15" -s support_type="everywhere" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s retraction_hop="0.2" -s dual="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s raft_base_fan_speed="0" -s sub_div_rad_add="0.4" -s machine_name="Creality Ender-3 Pro" -s initial_layer_line_width_factor="100.0" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s material_bed_temperature="60" -s lightning_infill_prune_angle="40" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s wall_overhang_angle="90" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s support_line_distance="8.0" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s gantry_height="25" -s support_interface_skip_height="0.2" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s wipe_repeat_count="5" -s cool_lift_head="False" -s fill_outline_gaps="False" -s infill_offset_x="0" -s jerk_wall="8" -s machine_max_acceleration_x="500" -s raft_interface_fan_speed="0" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s meshfix_union_all_remove_holes="False" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s optimize_wall_printing_order="True" -s machine_extruders_share_nozzle="False" -s support_angle="45" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s prime_tower_size="20" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s jerk_travel_layer_0="8" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="25.0" -s wireframe_strategy="compensate" -s slicing_tolerance="middle" -s wireframe_printspeed_flat="5" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s support_extruder_nr="0" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_use_extruder_offset_to_offset_coords="True" -s machine_endstop_positive_direction_x="False" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_extrusion_cool_down_speed="0.7" -s machine_max_feedrate_x="500" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s flow_rate_max_extrusion_offset="0" -s material_print_temperature="210" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 16:58:23,394 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 16:58:23,403 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 16:58:23,408 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 16:58:23,412 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 16:58:23,418 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 16:58:23,422 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 16:58:23,426 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 16:58:23,427 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 16:58:23,431 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 16:58:23,436 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s support_interface_height="0.8" -s gradual_support_infill_steps="0" -s machine_buildplate_type="glass" -s speed_wall="25.0" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s draft_shield_enabled="False" -s material_break_temperature="50" -s z_seam_type="back" -s acceleration_enabled="False" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s remove_empty_first_layers="True" -s raft_interface_acceleration="500" -s material_guid="" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s jerk_prime_tower="8" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_roof_pattern="grid" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_max_feedrate_z="10" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s ooze_shield_angle="60" -s speed_infill="50.0" -s support_brim_line_count="10" -s ooze_shield_enabled="False" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s speed_wall_0="25.0" -s meshfix="0" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -e0 -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s jerk_support_roof="8" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s acceleration_print="500" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s infill_line_width="0.4" -s support_pattern="zigzag" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s support_roof_height="0.8" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="20.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s skirt_brim_minimal_length="250" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s travel_compensate_overlapping_walls_0_enabled="False" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s machine_extruder_start_pos_y="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s line_width="0.4" -s jerk_wall_x="8" -s extruder_nr="0" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s raft_surface_fan_speed="0" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s skin_monotonic="False" -s alternate_extra_perimeter="False" -s switch_extruder_extra_prime_amount="0" -s skin_material_flow="100" -s speed_ironing="13.333333333333334" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s infill_overlap="30.0" -s resolution="0" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s top_thickness="0.8" -s material_break_preparation_temperature="200" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s gradual_infill_steps="0" -s initial_layer_line_width_factor="100.0" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_skip_zag_per_mm="20" -s speed_support_infill="20.0" -s bottom_layers="4" -s small_feature_speed_factor_0="50" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_retraction_amount="6.5" -s magic_fuzzy_skin_enabled="False" -s prime_tower_min_volume="6" -s z_seam_x="110.0" -s lightning_infill_prune_angle="40" -s mold_roof_height="0.5" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_layer_0="100" -s raft_base_jerk="8" -s acceleration_support="500" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s xy_offset="0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_offset="0.0" -s support_brim_enable="True" -s layer_start_x="0.0" -s support_wall_count="1" -s ironing_enabled="False" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruder_prime_pos_y="0" -s retraction_hop="0.2" -s dual="0" -s material_break_preparation_speed="2" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s wall_overhang_angle="90" -s conical_overhang_enabled="False" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_extruder_end_pos_x="0" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s infill_support_angle="40" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s z_seam_relative="False" -s machine_heat_zone_length="16" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s cool_lift_head="False" -s speed_print="40.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extra_prime_amount="0" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_z="0" -s filter_out_tiny_gaps="False" -s speed_wall_x="20.0" -s support_interface_material_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s machine_nozzle_size="0.4" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s skirt_brim_speed="20.0" -s hole_xy_offset="0" -s material_crystallinity="False" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s roofing_material_flow="100" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s jerk_support="8" -s brim_width="8.0" -s outer_inset_first="False" -s material_initial_print_temperature="200" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s material_diameter="1.75" -s prime_tower_flow="100" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s jerk_ironing="8" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s material_final_print_temperature="200" -s raft_jerk="8" -s support_tree_angle="40" -s support_bottom_enable="True" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s jerk_layer_0="8" -s infill="0" -s raft_interface_line_spacing="1.0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s infill_offset_x="0" -s jerk_wall="8" -s speed_travel="150.0" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s bridge_skin_speed_3="10" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s machine_nozzle_cool_down_speed="2.0" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s sub_div_rad_add="0.4" -s top_bottom_thickness="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s support_offset="0" -s bridge_fan_speed_2="0" -s infill_pattern="cubic" -s experimental="0" -s optimize_wall_printing_order="True" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s jerk_travel_layer_0="8" -s machine_extruder_cooling_fan_number="0" -s jerk_travel="8" -s roofing_layer_count="0" -s speed_equalize_flow_max="150" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="20.0" -s slicing_tolerance="middle" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_endstop_positive_direction_x="False" -s material_extrusion_cool_down_speed="0.7" -s z_seam_y="220" -s machine_extruder_start_code="" -s machine_extruder_end_code="" -s jerk_prime_tower="8" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s skin_angles="[ ]" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s coasting_volume="0.064" -s support_angle="45" -s support_bottom_stair_step_height="0.3" -s roofing_pattern="lines" -s support_interface_height="0.8" -s jerk_wall_0="8" -s gradual_support_infill_steps="0" -s speed_wall="20.0" -s bottom_thickness="0.8" -s coasting_speed="90" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s machine_extruder_start_pos_abs="False" -s wall_0_wipe_dist="0.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s infill_before_walls="False" -s minimum_interface_area="10" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s raft_interface_acceleration="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="10" -s jerk_roofing="8" -s material_print_temperature="200" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_infill="40.0" -s acceleration_ironing="500" -s material_break_temperature="50" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s bridge_skin_support_threshold="50" -s support_brim_line_count="10" -s bridge_fan_speed="100" -s support_top_distance="0.2" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -s meshfix_maximum_resolution="0.25" -s default_material_print_temperature="200" -s ironing_flow="10.0" -s infill_multiplier="1" -s support_bottom_stair_step_min_slope="10.0" -s support_roof_enable="True" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s support_interface_density="33.333" -s bridge_skin_speed_2="10" -s machine_steps_per_mm_e="1600" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s wipe_hop_amount="0.2" -s retract_at_layer_change="False" -s raft_interface_thickness="0.30000000000000004" -s wipe_retraction_retract_speed="25" -s machine_steps_per_mm_z="50" -s roofing_line_width="0.4" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s bridge_skin_density_2="75" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s extruder_prime_pos_abs="False" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s zig_zaggify_infill="False" -s raft_surface_speed="20.0" -s material_anti_ooze_retraction_speed="5" -s support_tower_diameter="3.0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s support_bottom_angles="[ ]" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 16:58:25,597 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 2.7052671909332275 seconds
    2022-04-23 16:58:25,597 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 16:58:25,598 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 16:58:25,611 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 16:58:25,616 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 16:58:25,619 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 16:58:25,620 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 16:58:39,595 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_THWACK-sudo.gcode]...
    2022-04-23 16:58:39,605 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_THWACK-sudo.gcode in text mode
    2022-04-23 16:58:39,736 - DEBUG - [JobQueueWorker [3]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.1183938980102539 seconds
    2022-04-23 16:58:40,878 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-23 16:58:48,676 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-23 16:58:48,700 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-23 16:58:48,742 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-23 16:58:49,151 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.4081542491912842 seconds
    2022-04-23 16:58:49,187 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-23 16:59:03,086 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-23 16:59:03,092 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-23 16:59:03,132 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 16:59:03,375 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-23 16:59:05,677 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x000002322902DE20>, took 3ms
    2022-04-23 16:59:05,889 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-23 16:59:05,895 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-23 16:59:05,900 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-23 16:59:05,905 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-23 16:59:06,598 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-23 17:18:32,263 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/Downloads/GW receptacle for support.stl
    2022-04-23 17:18:32,267 - INFO - [JobQueueWorker [1]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-23 17:18:32,279 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-23 17:18:32,280 - DEBUG - [JobQueueWorker [1]] STLReader.STLReader._read [105]: Loaded a mesh with 552 vertices
    2022-04-23 17:18:32,295 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.00498652458190918 seconds. 10 input vertices. 10 output vertices.
    2022-04-23 17:18:32,305 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.0 seconds
    2022-04-23 17:18:32,316 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.0029921531677246094 seconds. 10 input vertices. 10 output vertices.
    2022-04-23 17:18:32,355 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000023226F4FDC0>, took 1ms
    2022-04-23 17:18:32,394 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'GW receptacle for support.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'GW receptacle for support.stl'>,trans.=<0.000,0.000,0.000>), took 3ms
    2022-04-23 17:18:32,964 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 17:18:32,973 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 17:18:32,980 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-23 17:18:37,600 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 17:18:37,606 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 17:18:37,611 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 17:18:37,628 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 17:18:37,642 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 17:18:37,902 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 17:18:37,902 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 17:18:37,906 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 17:18:38,059 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 17:18:38,094 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 17:18:38,107 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 17:18:38,155 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.2517237663269043 seconds
    2022-04-23 17:18:38,283 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,291 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 17:18:38,291 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 17:18:38,298 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 17:18:38,298 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 17:18:38,302 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,305 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 17:18:38,308 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 17:18:38,312 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 17:18:38,316 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 17:18:38,320 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,323 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 17:18:38,326 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 17:18:38,330 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 17:18:38,334 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 17:18:38,337 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,340 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 17:18:38,344 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 17:18:38,396 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="17:18:37" -s print_bed_temperature="60" -s material_name="empty" -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s machine_heated_build_volume="False" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s machine_height="250" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s support_pattern="zigzag" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s wireframe_bottom_delay="0" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s wireframe_printspeed_up="5" -s support_roof_height="0.8" -s wireframe_printspeed_bottom="5" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="25.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s wireframe_printspeed_down="5" -s skirt_brim_minimal_length="250" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_roof_density="33.333" -s material_standby_temperature="150" -s line_width="0.4" -s prime_tower_enable="False" -s jerk_wall_x="8" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s wireframe_top_delay="0" -s raft_surface_fan_speed="0" -s skin_monotonic="False" -s switch_extruder_extra_prime_amount="0" -s speed_ironing="16.666666666666668" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s adaptive_layer_height_enabled="False" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s cutting_mesh="False" -s wireframe_printspeed="5" -s infill_overlap="30.0" -s machine_extruders_share_heater="False" -s wireframe_height="3" -s ooze_shield_dist="2" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s layer_height="0.2" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s top_thickness="0.8" -s material_break_preparation_temperature="210" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s draft_shield_height_limitation="full" -s resolution="0" -s prime_tower_position_y="186.6" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s support_roof_enable="True" -s bridge_fan_speed_2="0" -s coasting_speed="90" -s support_offset="0" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s support_bottom_angles="[ ]" -s ironing_enabled="False" -s support_tower_diameter="3.0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s material_anti_ooze_retraction_speed="5" -s draft_shield_height="10" -s raft_surface_speed="20.0" -s acceleration_topbottom="500" -s skin_outline_count="1" -s blackmagic="0" -s zig_zaggify_infill="False" -s jerk_wall_0="8" -s wall_extruder_nr="-1" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s bridge_skin_density_2="75" -s machine_depth="220" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s extruder_prime_pos_abs="False" -s support_roof_offset="0.0" -s jerk_enabled="False" -s layer_start_x="0.0" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s adaptive_layer_height_variation_step="0.04" -s wireframe_flow_flat="100" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s machine_steps_per_mm_z="50" -s wipe_retraction_retract_speed="25" -s raft_interface_thickness="0.30000000000000004" -s bridge_skin_support_threshold="50" -s material_break_preparation_retracted_position="-16" -s skin_angles="[ ]" -s acceleration_ironing="500" -s support_infill_extruder_nr="0" -s speed_equalize_flow_max="150" -s retract_at_layer_change="False" -s retraction_combing="noskin" -s wipe_hop_amount="0.2" -s retraction_retract_speed="25" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_2="12.5" -s bottom_thickness="0.8" -s infill_extruder_nr="-1" -s support_bottom_stair_step_min_slope="10.0" -s support_xy_overrides_z="xy_overrides_z" -s infill_multiplier="1" -s ironing_flow="10.0" -s speed_travel="150.0" -s default_material_print_temperature="210" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s acceleration_support="500" -s xy_offset="0" -s speed_support_infill="20.0" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s small_feature_speed_factor_0="50" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s wipe_retraction_amount="6.5" -s speed_slowdown_layers="2" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s cross_infill_pocket_size="6.0" -s speed_support="20.0" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s conical_overhang_enabled="False" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_firmware_retract="False" -s infill_support_angle="40" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s z_seam_relative="False" -s date="23-04-2022" -s machine_heat_zone_length="16" -s machine_max_jerk_e="5" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_always_write_active_tool="False" -s cross_infill_density_image="" -s machine_nozzle_expansion_angle="45" -s extruder_prime_pos_z="0" -s machine_max_acceleration_y="500" -s infill_pattern="cubic" -s experimental="0" -s support_wall_count="1" -s material_bed_temperature_layer_0="60" -s jerk_travel="8" -s roofing_layer_count="0" -s support_brim_enable="True" -s material_initial_print_temperature="210" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s brim_width="8.0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s outer_inset_first="False" -s mold_roof_height="0.5" -s infill_sparse_density="20" -s retraction_enable="True" -s brim_gap="0" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s wireframe_fall_down="0.5" -s z_seam_x="110.0" -s prime_tower_min_volume="6" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s support_enable="True" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s material_flow_layer_0="100" -s roofing_material_flow="100" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s filter_out_tiny_gaps="False" -s skin_material_flow="100" -s wireframe_roof_inset="3" -s raft_jerk="8" -s material_final_print_temperature="210" -s support_tree_angle="40" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s wireframe_straight_before_down="20" -s infill="0" -s raft_interface_line_spacing="1.0" -s center_object="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s wall_0_extruder_nr="-1" -s material_adhesion_tendency="10" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 17:18:38,401 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 17:18:38,405 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 17:18:38,409 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 17:18:38,413 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 17:18:38,417 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 17:18:38,421 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,425 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 17:18:38,428 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 17:18:38,433 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 17:18:38,436 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 17:18:38,439 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:18:38,443 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 17:18:38,447 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s jerk_layer_0="8" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s machine_show_variants="False" -s prime_tower_flow="100" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_speed_3="12.5" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s retraction_extra_prime_amount="0" -s wireframe_roof_fall_down="2" -s roofing_pattern="lines" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s mold_angle="40" -s gradual_infill_steps="0" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s smooth_spiralized_contours="True" -s wireframe_top_jump="0.6" -s top_bottom_thickness="0.8" -s support_roof_extruder_nr="0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_bottom_extruder_nr="0" -s speed_travel_layer_0="100.0" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s support_bottom_enable="True" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s material_diameter="1.75" -s wireframe_enabled="False" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s jerk_ironing="8" -s infill_mesh="False" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_crystallinity="False" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s jerk_support="8" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s material_bed_temp_prepend="True" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_extruder_count="1" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s default_material_bed_temperature="60" -s machine_max_jerk_xy="10" -s wireframe_drag_along="0.6" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s layer_0_z_overlap="0.15" -s support_type="everywhere" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s retraction_hop="0.2" -s dual="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s raft_base_fan_speed="0" -s sub_div_rad_add="0.4" -s machine_name="Creality Ender-3 Pro" -s initial_layer_line_width_factor="100.0" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s material_bed_temperature="60" -s lightning_infill_prune_angle="40" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s wall_overhang_angle="90" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s support_line_distance="8.0" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s gantry_height="25" -s support_interface_skip_height="0.2" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s wipe_repeat_count="5" -s cool_lift_head="False" -s fill_outline_gaps="False" -s infill_offset_x="0" -s jerk_wall="8" -s machine_max_acceleration_x="500" -s raft_interface_fan_speed="0" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s meshfix_union_all_remove_holes="False" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s optimize_wall_printing_order="True" -s machine_extruders_share_nozzle="False" -s support_angle="45" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s prime_tower_size="20" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s jerk_travel_layer_0="8" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="25.0" -s wireframe_strategy="compensate" -s slicing_tolerance="middle" -s wireframe_printspeed_flat="5" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s support_extruder_nr="0" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_use_extruder_offset_to_offset_coords="True" -s machine_endstop_positive_direction_x="False" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_extrusion_cool_down_speed="0.7" -s machine_max_feedrate_x="500" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s flow_rate_max_extrusion_offset="0" -s material_print_temperature="210" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 17:18:38,451 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 17:18:38,454 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 17:18:38,457 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 17:18:38,461 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 17:18:38,465 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 17:18:38,468 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 17:18:38,472 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 17:18:38,475 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 17:18:38,478 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 17:18:38,485 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s support_interface_height="0.8" -s gradual_support_infill_steps="0" -s machine_buildplate_type="glass" -s speed_wall="25.0" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s draft_shield_enabled="False" -s material_break_temperature="50" -s z_seam_type="back" -s acceleration_enabled="False" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s remove_empty_first_layers="True" -s raft_interface_acceleration="500" -s material_guid="" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s jerk_prime_tower="8" -s raft_speed="20.0" -s adaptive_layer_height_threshold="0.2" -s support_roof_pattern="grid" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_max_feedrate_z="10" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s ooze_shield_angle="60" -s speed_infill="50.0" -s support_brim_line_count="10" -s ooze_shield_enabled="False" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s speed_wall_0="25.0" -s meshfix="0" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -e0 -s raft_base_speed="15.0" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s jerk_support_roof="8" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s acceleration_print="500" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s infill_line_width="0.4" -s support_pattern="zigzag" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s support_roof_height="0.8" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="20.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s skirt_brim_minimal_length="250" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s travel_compensate_overlapping_walls_0_enabled="False" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s machine_extruder_start_pos_y="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s line_width="0.4" -s jerk_wall_x="8" -s extruder_nr="0" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s raft_surface_fan_speed="0" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s skin_monotonic="False" -s alternate_extra_perimeter="False" -s switch_extruder_extra_prime_amount="0" -s skin_material_flow="100" -s speed_ironing="13.333333333333334" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s infill_overlap="30.0" -s resolution="0" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s top_thickness="0.8" -s material_break_preparation_temperature="200" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="20.0" -s support_roof_material_flow="100" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s gradual_infill_steps="0" -s initial_layer_line_width_factor="100.0" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_skip_zag_per_mm="20" -s speed_support_infill="20.0" -s bottom_layers="4" -s small_feature_speed_factor_0="50" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_retraction_amount="6.5" -s magic_fuzzy_skin_enabled="False" -s prime_tower_min_volume="6" -s z_seam_x="110.0" -s lightning_infill_prune_angle="40" -s mold_roof_height="0.5" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_layer_0="100" -s raft_base_jerk="8" -s acceleration_support="500" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s xy_offset="0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_offset="0.0" -s support_brim_enable="True" -s layer_start_x="0.0" -s support_wall_count="1" -s ironing_enabled="False" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruder_prime_pos_y="0" -s retraction_hop="0.2" -s dual="0" -s material_break_preparation_speed="2" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s wall_overhang_angle="90" -s conical_overhang_enabled="False" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_extruder_end_pos_x="0" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s infill_support_angle="40" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s z_seam_relative="False" -s machine_heat_zone_length="16" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s cool_lift_head="False" -s speed_print="40.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extra_prime_amount="0" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_z="0" -s filter_out_tiny_gaps="False" -s speed_wall_x="20.0" -s support_interface_material_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s machine_nozzle_size="0.4" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s skirt_brim_speed="20.0" -s hole_xy_offset="0" -s material_crystallinity="False" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s roofing_material_flow="100" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s jerk_support="8" -s brim_width="8.0" -s outer_inset_first="False" -s material_initial_print_temperature="200" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s material_diameter="1.75" -s prime_tower_flow="100" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s jerk_ironing="8" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s material_final_print_temperature="200" -s raft_jerk="8" -s support_tree_angle="40" -s support_bottom_enable="True" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s jerk_layer_0="8" -s infill="0" -s raft_interface_line_spacing="1.0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s infill_offset_x="0" -s jerk_wall="8" -s speed_travel="150.0" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s bridge_skin_speed_3="10" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s machine_nozzle_cool_down_speed="2.0" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="20.0" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s sub_div_rad_add="0.4" -s top_bottom_thickness="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s support_offset="0" -s bridge_fan_speed_2="0" -s infill_pattern="cubic" -s experimental="0" -s optimize_wall_printing_order="True" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s jerk_travel_layer_0="8" -s machine_extruder_cooling_fan_number="0" -s jerk_travel="8" -s roofing_layer_count="0" -s speed_equalize_flow_max="150" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="20.0" -s slicing_tolerance="middle" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_endstop_positive_direction_x="False" -s material_extrusion_cool_down_speed="0.7" -s z_seam_y="220" -s machine_extruder_start_code="" -s machine_extruder_end_code="" -s jerk_prime_tower="8" -s raft_speed="20.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s skin_angles="[ ]" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s coasting_volume="0.064" -s support_angle="45" -s support_bottom_stair_step_height="0.3" -s roofing_pattern="lines" -s support_interface_height="0.8" -s jerk_wall_0="8" -s gradual_support_infill_steps="0" -s speed_wall="20.0" -s bottom_thickness="0.8" -s coasting_speed="90" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s machine_extruder_start_pos_abs="False" -s wall_0_wipe_dist="0.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_prime_tower="20.0" -s mesh_position_z="0" -s infill_before_walls="False" -s minimum_interface_area="10" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s raft_interface_acceleration="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="10" -s meshfix_union_all_remove_holes="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="10" -s jerk_roofing="8" -s material_print_temperature="200" -s conical_overhang_angle="50" -s speed_support_roof="20.0" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_infill="40.0" -s acceleration_ironing="500" -s material_break_temperature="50" -s raft_interface_speed="15.0" -s wall_line_width_0="0.4" -s bridge_skin_support_threshold="50" -s support_brim_line_count="10" -s bridge_fan_speed="100" -s support_top_distance="0.2" -s speed_wall_0="20.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -s meshfix_maximum_resolution="0.25" -s default_material_print_temperature="200" -s ironing_flow="10.0" -s infill_multiplier="1" -s support_bottom_stair_step_min_slope="10.0" -s support_roof_enable="True" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s support_interface_density="33.333" -s bridge_skin_speed_2="10" -s machine_steps_per_mm_e="1600" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s wipe_hop_amount="0.2" -s retract_at_layer_change="False" -s raft_interface_thickness="0.30000000000000004" -s wipe_retraction_retract_speed="25" -s machine_steps_per_mm_z="50" -s roofing_line_width="0.4" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s bridge_skin_density_2="75" -s speed_support="20.0" -s cross_infill_pocket_size="6.0" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s extruder_prime_pos_abs="False" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s zig_zaggify_infill="False" -s raft_surface_speed="20.0" -s material_anti_ooze_retraction_speed="5" -s support_tower_diameter="3.0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s support_bottom_angles="[ ]" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 17:18:39,181 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.2779741287231445 seconds
    2022-04-23 17:18:39,182 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 17:18:39,182 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 17:18:39,192 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 17:18:39,199 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 17:18:39,204 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 17:18:39,205 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 17:18:42,502 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.0473475456237793 seconds
    2022-04-23 17:19:01,302 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-23 17:19:03,920 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 17:19:03,925 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 17:19:04,036 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 17:19:04,045 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = True, time = 0.0s
    2022-04-23 17:19:04,132 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 17:19:04,137 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingTextField.qml:170:13: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 17:19:04,298 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-23 17:19:04,317 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 0.0s
    2022-04-23 17:19:07,923 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.039511919021606445 seconds
    2022-04-23 17:19:09,947 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-23 17:19:09,952 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-23 17:19:09,958 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-23 17:19:09,978 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-23 17:19:09,990 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-23 17:19:10,249 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-23 17:19:10,250 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-23 17:19:10,254 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-23 17:19:10,398 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-23 17:19:10,412 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-23 17:19:10,419 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-23 17:19:10,475 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.22616982460021973 seconds
    2022-04-23 17:19:10,580 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,586 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-23 17:19:10,588 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-23 17:19:10,592 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-23 17:19:10,598 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-23 17:19:10,600 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,604 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-23 17:19:10,608 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-23 17:19:10,612 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-23 17:19:10,615 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-23 17:19:10,618 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,621 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-23 17:19:10,625 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-23 17:19:10,629 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-23 17:19:10,634 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-23 17:19:10,637 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,641 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-23 17:19:10,646 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-23 17:19:10,691 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sat" -s time="17:19:10" -s print_bed_temperature="60" -s material_name="empty" -s raft_base_speed="18.75" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s machine_heated_build_volume="False" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s machine_height="250" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s support_pattern="zigzag" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s wireframe_bottom_delay="0" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s wireframe_printspeed_up="5" -s support_roof_height="0.8" -s wireframe_printspeed_bottom="5" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="25.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s wireframe_printspeed_down="5" -s skirt_brim_minimal_length="250" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_roof_density="33.333" -s material_standby_temperature="150" -s line_width="0.4" -s prime_tower_enable="False" -s jerk_wall_x="8" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s wireframe_top_delay="0" -s raft_surface_fan_speed="0" -s skin_monotonic="False" -s switch_extruder_extra_prime_amount="0" -s speed_ironing="16.666666666666668" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s adaptive_layer_height_enabled="False" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s cutting_mesh="False" -s wireframe_printspeed="5" -s infill_overlap="30.0" -s machine_extruders_share_heater="False" -s wireframe_height="3" -s ooze_shield_dist="2" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s layer_height="0.2" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s top_thickness="0.8" -s material_break_preparation_temperature="210" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s draft_shield_height_limitation="full" -s resolution="0" -s prime_tower_position_y="186.6" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="25.0" -s support_roof_material_flow="100" -s support_roof_enable="True" -s bridge_fan_speed_2="0" -s coasting_speed="90" -s support_offset="0" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s support_bottom_angles="[ ]" -s ironing_enabled="False" -s support_tower_diameter="3.0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s material_anti_ooze_retraction_speed="5" -s draft_shield_height="10" -s raft_surface_speed="25.0" -s acceleration_topbottom="500" -s skin_outline_count="1" -s blackmagic="0" -s zig_zaggify_infill="False" -s jerk_wall_0="8" -s wall_extruder_nr="-1" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s bridge_skin_density_2="75" -s machine_depth="220" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s extruder_prime_pos_abs="False" -s support_roof_offset="0.0" -s jerk_enabled="False" -s layer_start_x="0.0" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s adaptive_layer_height_variation_step="0.04" -s wireframe_flow_flat="100" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s machine_steps_per_mm_z="50" -s wipe_retraction_retract_speed="25" -s raft_interface_thickness="0.30000000000000004" -s bridge_skin_support_threshold="50" -s material_break_preparation_retracted_position="-16" -s skin_angles="[ ]" -s acceleration_ironing="500" -s support_infill_extruder_nr="0" -s speed_equalize_flow_max="150" -s retract_at_layer_change="False" -s retraction_combing="noskin" -s wipe_hop_amount="0.2" -s retraction_retract_speed="25" -s machine_steps_per_mm_e="1600" -s bridge_skin_speed_2="12.5" -s bottom_thickness="0.8" -s infill_extruder_nr="-1" -s support_bottom_stair_step_min_slope="10.0" -s support_xy_overrides_z="xy_overrides_z" -s infill_multiplier="1" -s ironing_flow="10.0" -s speed_travel="150.0" -s default_material_print_temperature="210" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s acceleration_support="500" -s xy_offset="0" -s speed_support_infill="25.0" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s small_feature_speed_factor_0="50" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s wipe_retraction_amount="6.5" -s speed_slowdown_layers="2" -s z_seam_y="220" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruders_enabled_count="1" -s extruder_prime_pos_y="0" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s conical_overhang_enabled="False" -s machine_width="220" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_firmware_retract="False" -s infill_support_angle="40" -s print_sequence="all_at_once" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s z_seam_relative="False" -s date="23-04-2022" -s machine_heat_zone_length="16" -s machine_max_jerk_e="5" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_always_write_active_tool="False" -s cross_infill_density_image="" -s machine_nozzle_expansion_angle="45" -s extruder_prime_pos_z="0" -s machine_max_acceleration_y="500" -s infill_pattern="cubic" -s experimental="0" -s support_wall_count="1" -s material_bed_temperature_layer_0="60" -s jerk_travel="8" -s roofing_layer_count="0" -s support_brim_enable="True" -s material_initial_print_temperature="210" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s brim_width="8.0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s outer_inset_first="False" -s mold_roof_height="0.5" -s infill_sparse_density="20" -s retraction_enable="True" -s brim_gap="0" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s wireframe_fall_down="0.5" -s z_seam_x="110.0" -s prime_tower_min_volume="6" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s support_enable="True" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s material_flow_layer_0="100" -s roofing_material_flow="100" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s filter_out_tiny_gaps="False" -s skin_material_flow="100" -s wireframe_roof_inset="3" -s raft_jerk="8" -s material_final_print_temperature="210" -s support_tree_angle="40" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s carve_multiple_volumes="False" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s wireframe_straight_before_down="20" -s infill="0" -s raft_interface_line_spacing="1.0" -s center_object="False" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s support_top_distance="0.2" -s wall_0_extruder_nr="-1" -s material_adhesion_tendency="10" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-23 17:19:10,698 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-23 17:19:10,703 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-23 17:19:10,707 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-23 17:19:10,711 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-23 17:19:10,718 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-23 17:19:10,721 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,725 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-23 17:19:10,730 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-23 17:19:10,734 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-23 17:19:10,738 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-23 17:19:10,742 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-23 17:19:10,747 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-23 17:19:10,751 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s jerk_layer_0="8" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s machine_show_variants="False" -s prime_tower_flow="100" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_speed_3="12.5" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s retraction_extra_prime_amount="0" -s wireframe_roof_fall_down="2" -s roofing_pattern="lines" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s mold_angle="40" -s gradual_infill_steps="0" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s smooth_spiralized_contours="True" -s wireframe_top_jump="0.6" -s top_bottom_thickness="0.8" -s support_roof_extruder_nr="0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s support_bottom_extruder_nr="0" -s speed_travel_layer_0="100.0" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s support_bottom_enable="True" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s material_diameter="1.75" -s wireframe_enabled="False" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s jerk_ironing="8" -s infill_mesh="False" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_fan_speed="0" -s wall_material_flow="100" -s support_interface_pattern="grid" -s material_crystallinity="False" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s jerk_support="8" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s material_bed_temp_prepend="True" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_extruder_count="1" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="25.0" -s default_material_bed_temperature="60" -s machine_max_jerk_xy="10" -s wireframe_drag_along="0.6" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s layer_0_z_overlap="0.15" -s support_type="everywhere" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s retraction_hop="0.2" -s dual="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s raft_base_fan_speed="0" -s sub_div_rad_add="0.4" -s machine_name="Creality Ender-3 Pro" -s initial_layer_line_width_factor="100.0" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s material_bed_temperature="60" -s lightning_infill_prune_angle="40" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s wall_overhang_angle="90" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s support_line_distance="8.0" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s gantry_height="25" -s support_interface_skip_height="0.2" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s wipe_repeat_count="5" -s cool_lift_head="False" -s fill_outline_gaps="False" -s infill_offset_x="0" -s jerk_wall="8" -s machine_max_acceleration_x="500" -s raft_interface_fan_speed="0" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s meshfix_union_all_remove_holes="False" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s optimize_wall_printing_order="True" -s machine_extruders_share_nozzle="False" -s support_angle="45" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s prime_tower_size="20" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -s jerk_travel_layer_0="8" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="25.0" -s wireframe_strategy="compensate" -s slicing_tolerance="middle" -s wireframe_printspeed_flat="5" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s support_extruder_nr="0" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_use_extruder_offset_to_offset_coords="True" -s machine_endstop_positive_direction_x="False" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_extrusion_cool_down_speed="0.7" -s machine_max_feedrate_x="500" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s flow_rate_max_extrusion_offset="0" -s material_print_temperature="210" -s conical_overhang_angle="50" -s speed_support_roof="25.0" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-23 17:19:10,754 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 17:19:10,758 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-23 17:19:10,763 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 17:19:10,767 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-23 17:19:10,771 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-23 17:19:10,775 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-23 17:19:10,780 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-23 17:19:10,784 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-23 17:19:10,788 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-23 17:19:10,795 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s support_interface_height="0.8" -s gradual_support_infill_steps="0" -s machine_buildplate_type="glass" -s speed_wall="25.0" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s draft_shield_enabled="False" -s material_break_temperature="50" -s z_seam_type="back" -s acceleration_enabled="False" -s retraction_prime_speed="25" -s alternate_carve_order="True" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s remove_empty_first_layers="True" -s raft_interface_acceleration="500" -s material_guid="" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s support_structure="normal" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s jerk_prime_tower="8" -s raft_speed="25.0" -s adaptive_layer_height_threshold="0.2" -s support_roof_pattern="grid" -s wall_min_flow_retract="False" -s jerk_infill="8" -s machine_max_feedrate_z="10" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s ooze_shield_angle="60" -s speed_infill="50.0" -s support_brim_line_count="10" -s ooze_shield_enabled="False" -s machine_center_is_zero="False" -s bridge_fan_speed="100" -s speed_wall_0="25.0" -s meshfix="0" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -e0 -s raft_base_speed="18.75" -s raft_surface_line_width="0.4" -s travel_avoid_other_parts="True" -s jerk_support_roof="8" -s mold_enabled="False" -s retraction_min_travel="1.5" -s small_feature_max_length="0.0" -s material_flow_dependent_temperature="False" -s cooling="0" -s support_join_distance="2.0" -s small_hole_max_size="0" -s bridge_enable_more_layers="True" -s skin_no_small_gaps_heuristic="False" -s min_infill_area="0" -s acceleration_print="500" -s bridge_wall_material_flow="50" -s retraction_combing_max_distance="30" -s support_line_width="0.4" -s cool_min_layer_time_fan_speed_max="10" -s infill_line_width="0.4" -s support_pattern="zigzag" -s bridge_skin_density="100" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s machine_nozzle_head_distance="3" -s raft_smoothing="5" -s support_roof_height="0.8" -s support_conical_angle="30" -s machine_settings="0" -s support_tree_collision_resolution="0.2" -s speed_roofing="25.0" -s infill_support_enabled="False" -s clean_between_layers="False" -s skirt_brim_minimal_length="250" -s material_flush_purge_speed="0.5" -s machine_endstop_positive_direction_z="True" -s jerk_support_bottom="8" -s travel_compensate_overlapping_walls_0_enabled="False" -s acceleration_infill="500" -s support_roof_line_width="0.4" -s acceleration_support_interface="500" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s machine_extruder_start_pos_y="0" -s support_roof_density="33.333" -s material_standby_temperature="175" -s line_width="0.4" -s jerk_wall_x="8" -s extruder_nr="0" -s magic_fuzzy_skin_thickness="0.3" -s prime_blob_enable="False" -s raft_surface_fan_speed="0" -s support_interface_angles="[ ]" -s cool_fan_speed_max="100.0" -s skin_monotonic="False" -s alternate_extra_perimeter="False" -s switch_extruder_extra_prime_amount="0" -s skin_material_flow="100" -s speed_ironing="16.666666666666668" -s connect_infill_polygons="False" -s gradual_support_infill_step_height="1" -s retraction_hop_only_when_collides="False" -s raft_interface_jerk="8" -s material_surface_energy="100" -s wall_thickness="0.8" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s top_layers="4" -s bridge_skin_material_flow_3="110" -s support_initial_layer_line_distance="8.0" -s infill_overlap="30.0" -s resolution="0" -s skirt_brim_line_width="0.4" -s retraction_count_max="100" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s mold_width="5" -s support_tower_roof_angle="65" -s top_skin_preshrink="0.8" -s small_feature_speed_factor="50" -s wall_line_count="2" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s bridge_sparse_infill_max_density="0" -s infill_line_distance="6.0" -s acceleration_wall_x="500" -s top_thickness="0.8" -s material_break_preparation_temperature="200" -s support_infill_angles="[ ]" -s raft_base_line_width="0.8" -s infill_wall_line_count="0" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s jerk_topbottom="8" -s raft_base_line_spacing="1.6" -s infill_overlap_mm="0.12" -s speed_support_bottom="25.0" -s support_roof_material_flow="100" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s gradual_infill_steps="0" -s initial_layer_line_width_factor="100.0" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s bottom_layers="4" -s small_feature_speed_factor_0="50" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_retraction_amount="6.5" -s magic_fuzzy_skin_enabled="False" -s prime_tower_min_volume="6" -s z_seam_x="110.0" -s lightning_infill_prune_angle="40" -s mold_roof_height="0.5" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s material_flow_layer_0="100" -s raft_base_jerk="8" -s acceleration_support="500" -s wall_min_flow="0" -s prime_tower_line_width="0.4" -s xy_offset="0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s support_bottom_offset="0.0" -s support_brim_enable="True" -s layer_start_x="0.0" -s support_wall_count="1" -s ironing_enabled="False" -s ironing_pattern="zigzag" -s top_bottom="0" -s ironing_monotonic="False" -s raft_surface_thickness="0.2" -s meshfix_maximum_travel_resolution="0.25" -s retraction_speed="25" -s infill_offset_y="0" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s extruder_prime_pos_y="0" -s retraction_hop="0.2" -s dual="0" -s material_break_preparation_speed="2" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s speed_equalize_flow_enabled="False" -s support_infill_rate="5" -s jerk_skirt_brim="8" -s wall_overhang_angle="90" -s conical_overhang_enabled="False" -s acceleration_travel_layer_0="500" -s support_bottom_material_flow="100" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s support_conical_enabled="False" -s machine_extruder_end_pos_x="0" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s infill_support_angle="40" -s support_xy_distance_overhang="0.4" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s minimum_support_area="2" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s z_seam_relative="False" -s machine_heat_zone_length="16" -s skin_overlap_mm="0.04" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s cross_infill_density_image="" -s support_roof_offset="0.0" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extra_prime_amount="0" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_z="0" -s filter_out_tiny_gaps="False" -s speed_wall_x="25.0" -s support_interface_material_flow="100" -s max_extrusion_before_wipe="10" -s travel="0" -s material_no_load_move_factor="0.940860215" -s raft_surface_jerk="8" -s speed_z_hop="5" -s support_tower_maximum_supported_diameter="3.0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s machine_nozzle_size="0.4" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s skirt_brim_speed="20.0" -s hole_xy_offset="0" -s material_crystallinity="False" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s roofing_material_flow="100" -s travel_avoid_supports="True" -s shell="0" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s jerk_support="8" -s brim_width="8.0" -s outer_inset_first="False" -s material_initial_print_temperature="200" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s material_diameter="1.75" -s prime_tower_flow="100" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s jerk_ironing="8" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s material_final_print_temperature="200" -s raft_jerk="8" -s support_tree_angle="40" -s support_bottom_enable="True" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s jerk_layer_0="8" -s infill="0" -s raft_interface_line_spacing="1.0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s switch_extruder_prime_speed="20" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s infill_offset_x="0" -s jerk_wall="8" -s speed_travel="150.0" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s bridge_skin_speed_3="12.5" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s lightning_infill_support_angle="40" -s support_bottom_line_width="0.4" -s lightning_infill_overhang_angle="40" -s cool_fan_speed_0="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s machine_nozzle_cool_down_speed="2.0" -s wall_line_width="0.4" -s acceleration_travel="500" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s wall_0_inset="0" -s speed_support_interface="25.0" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s sub_div_rad_add="0.4" -s top_bottom_thickness="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s support_offset="0" -s bridge_fan_speed_2="0" -s infill_pattern="cubic" -s experimental="0" -s optimize_wall_printing_order="True" -s skirt_brim_material_flow="100" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s jerk_travel_layer_0="8" -s machine_extruder_cooling_fan_number="0" -s jerk_travel="8" -s roofing_layer_count="0" -s speed_equalize_flow_max="150" -s acceleration_support_roof="500" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s support_tree_branch_diameter="2" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s speed_topbottom="25.0" -s slicing_tolerance="middle" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s machine_endstop_positive_direction_x="False" -s material_extrusion_cool_down_speed="0.7" -s z_seam_y="220" -s machine_extruder_start_code="" -s machine_extruder_end_code="" -s jerk_prime_tower="8" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s skin_angles="[ ]" -s acceleration_support_infill="500" -s support_bottom_line_distance="2.4000240002400024" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s coasting_volume="0.064" -s support_angle="45" -s support_bottom_stair_step_height="0.3" -s roofing_pattern="lines" -s support_interface_height="0.8" -s jerk_wall_0="8" -s gradual_support_infill_steps="0" -s speed_wall="25.0" -s bottom_thickness="0.8" -s coasting_speed="90" -s raft_surface_layers="2" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s material="0" -s expand_skins_expand_distance="0.8" -s machine_extruder_start_pos_abs="False" -s wall_0_wipe_dist="0.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s infill_before_walls="False" -s minimum_interface_area="10" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s material_end_of_filament_purge_speed="0.5" -s raft_interface_acceleration="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s material_print_temperature="200" -s conical_overhang_angle="50" -s speed_support_roof="25.0" -s mesh_position_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_infill="50.0" -s acceleration_ironing="500" -s material_break_temperature="50" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s bridge_skin_support_threshold="50" -s support_brim_line_count="10" -s bridge_fan_speed="100" -s support_top_distance="0.2" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s magic_fuzzy_skin_outside_only="False" -s wipe_hop_speed="5" -s meshfix_maximum_resolution="0.25" -s default_material_print_temperature="200" -s ironing_flow="10.0" -s infill_multiplier="1" -s support_bottom_stair_step_min_slope="10.0" -s support_roof_enable="True" -s raft_acceleration="500" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s support_interface_density="33.333" -s bridge_skin_speed_2="12.5" -s machine_steps_per_mm_e="1600" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s wipe_hop_amount="0.2" -s retract_at_layer_change="False" -s raft_interface_thickness="0.30000000000000004" -s wipe_retraction_retract_speed="25" -s machine_steps_per_mm_z="50" -s roofing_line_width="0.4" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s bridge_skin_density_2="75" -s speed_support="25.0" -s cross_infill_pocket_size="6.0" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s extruder_prime_pos_abs="False" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s zig_zaggify_infill="False" -s raft_surface_speed="25.0" -s material_anti_ooze_retraction_speed="5" -s support_tower_diameter="3.0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s support_bottom_angles="[ ]" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-23 17:19:11,451 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 1.2023231983184814 seconds
    2022-04-23 17:19:11,452 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-23 17:19:11,452 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-23 17:19:11,457 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-23 17:19:11,461 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-23 17:19:11,472 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-23 17:19:11,474 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-23 18:06:54,997 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2022-04-23 18:06:55,002 - INFO - [MainThread] cura.CuraApplication.closeApplication [612]: Close application
    2022-04-23 18:06:55,007 - INFO - [MainThread] UM.Logger.info [137]: Initializing Active Machine...
    2022-04-23 18:06:55,040 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 18:06:55,052 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 18:06:55,056 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 18:06:55,074 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:59: TypeError: Cannot read property 'extruders' of null
    2022-04-23 18:06:55,079 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 18:06:55,084 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-23 18:06:55,339 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [488]: Shutting down cura
    2022-04-23 18:06:55,365 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [354]: Attempting to kill the engine process
    2022-04-23 18:06:55,405 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-23 18:06:55,424 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/qml/UM/Preferences/PreferencesDialog.qml:113: TypeError: Cannot read property 'resetEnabled' of null
    2022-04-24 06:00:28,778 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [83]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-24 06:00:28,778 - INFO - [MainThread] UM.Qt.QtApplication.__init__ [93]: Adding QT5 plugin path: C:\Program Files\Ultimaker Cura 4.13.1\PyQt5\plugins
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Application.initialize [161]: Initializing Ultimaker Cura
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Application.initialize [162]: App Version 4.13.1
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Application.initialize [163]: Api Version 7.9.0
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Application.initialize [164]: Build type None
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\uranium\plugins must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Ultimaker Cura 4.13.1\share\cura\plugins must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\uranium must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib64\uranium must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib32\uranium must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\uranium\plugins must be a folder.
    2022-04-24 06:00:28,778 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\Resources\cura\plugins must be a folder.
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [447]: Initializing storage paths
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [457]: Config storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [465]: Data storage path is C:\Users\Ben360\AppData\Roaming\cura\4.13
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.Resources.__initializeStoragePaths [477]: Cache storage path is C:\Users\Ben360\AppData\Local\cura\4.13\cache
    2022-04-24 06:00:28,778 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-24 06:00:28,778 - INFO - [MainThread] UM.PackageManager.__init__ [55]: Found bundled packages JSON file: C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-24 06:00:28,778 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [123]: Trying OpenGL context 4.1...
    2022-04-24 06:00:28,786 - DEBUG - [MainThread] UM.View.GL.OpenGLContext.detectBestOpenGLVersion [131]: Yay, we got at least OpenGL 4.1 core: 4.1 Core profile
    2022-04-24 06:00:28,786 - DEBUG - [MainThread] UM.Qt.QtApplication.initialize [177]: Detected most suitable OpenGL context version: 4.1 Core profile
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.Qt.QtApplication.initialize [184]: Initializing job queue ...
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.Qt.QtApplication.initialize [188]: Initializing version upgrade manager ...
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\cura.json
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.PackageManager._loadManagementData [170]: Loaded bundled packages data from C:\Program Files\Ultimaker Cura 4.13.1\resources\bundled_packages\uranium.json
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.PackageManager._loadManagementData [197]: Loaded user packages management file from C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.PackageManager._saveManagementData [270]: Package management file C:\Users\Ben360\AppData\Roaming\cura\4.13\packages.json was saved
    2022-04-24 06:00:28,786 - INFO - [MainThread] UM.PluginRegistry.initializeBeforePluginsAreLoaded [119]: Loading plugin configuration file 'C:\Users\Ben360\AppData\Roaming\cura\4.13\plugins.json'
    2022-04-24 06:00:28,786 - WARNING - [MainThread] UM.Logger.warning [143]: Plugin location C:\Program Files\lib\cura must be a folder.
    2022-04-24 06:00:28,796 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FileLogger
    2022-04-24 06:00:28,862 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdateChecker
    2022-04-24 06:00:28,904 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin FirmwareUpdater
    2022-04-24 06:00:28,944 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzReader
    2022-04-24 06:00:28,972 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeGzWriter
    2022-04-24 06:00:29,004 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeProfileReader
    2022-04-24 06:00:29,089 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeReader
    2022-04-24 06:00:29,140 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin GCodeWriter
    2022-04-24 06:00:29,213 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ImageReader
    2022-04-24 06:00:29,263 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LegacyProfileReader
    2022-04-24 06:00:29,326 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalContainerProvider
    2022-04-24 06:00:29,397 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin LocalFileOutputDevice
    2022-04-24 06:00:29,451 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MachineSettingsAction
    2022-04-24 06:00:29,511 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ModelChecker
    2022-04-24 06:00:29,560 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MonitorStage
    2022-04-24 06:00:29,644 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PerObjectSettingsTool
    2022-04-24 06:00:29,696 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PostProcessingPlugin
    2022-04-24 06:00:29,747 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PrepareStage
    2022-04-24 06:00:29,796 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin PreviewStage
    2022-04-24 06:00:29,881 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RemovableDriveOutputDevice
    2022-04-24 06:00:30,022 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimulationView
    2022-04-24 06:00:30,082 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SliceInfoPlugin
    2022-04-24 06:00:30,146 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SolidView
    2022-04-24 06:00:30,202 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SupportEraser
    2022-04-24 06:00:30,511 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin Toolbox
    2022-04-24 06:00:30,550 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin CameraTool
    2022-04-24 06:00:30,595 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin MirrorTool
    2022-04-24 06:00:30,646 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin RotateTool
    2022-04-24 06:00:30,697 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin ScaleTool
    2022-04-24 06:00:30,747 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SelectionTool
    2022-04-24 06:00:30,812 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TranslateTool
    2022-04-24 06:00:30,861 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin TrimeshReader
    2022-04-24 06:00:30,948 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPReader
    2022-04-24 06:00:30,999 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UFPWriter
    2022-04-24 06:00:31,075 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UltimakerMachineActions
    2022-04-24 06:00:31,977 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UM3NetworkPrinting
    2022-04-24 06:00:32,073 - INFO - [MainThread] UpdateChecker.UpdateChecker.checkNewVersion [68]: Checking for new version
    2022-04-24 06:00:32,082 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin UpdateChecker
    2022-04-24 06:00:32,401 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin USBPrinting
    2022-04-24 06:00:32,463 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade21to22
    2022-04-24 06:00:32,510 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade22to24
    2022-04-24 06:00:32,546 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade25to26
    2022-04-24 06:00:32,578 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade26to27
    2022-04-24 06:00:32,613 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade27to30
    2022-04-24 06:00:32,645 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade30to31
    2022-04-24 06:00:32,694 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade32to33
    2022-04-24 06:00:32,746 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade33to34
    2022-04-24 06:00:32,796 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade34to35
    2022-04-24 06:00:32,853 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade35to40
    2022-04-24 06:00:32,899 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade40to41
    2022-04-24 06:00:32,950 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade411to412
    2022-04-24 06:00:33,014 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade41to42
    2022-04-24 06:00:33,063 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade42to43
    2022-04-24 06:00:33,111 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade43to44
    2022-04-24 06:00:33,175 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade44to45
    2022-04-24 06:00:33,229 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade45to46
    2022-04-24 06:00:33,295 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade460to462
    2022-04-24 06:00:33,342 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade462to47
    2022-04-24 06:00:33,379 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade47to48
    2022-04-24 06:00:33,414 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade48to49
    2022-04-24 06:00:33,463 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin VersionUpgrade49to410
    2022-04-24 06:00:33,521 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin SimpleView
    2022-04-24 06:00:33,579 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin X3DReader
    2022-04-24 06:00:33,661 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XmlMaterialProfile
    2022-04-24 06:00:33,709 - INFO - [MainThread] UM.Logger.info [137]: Loaded plugin XRayView
    2022-04-24 06:00:33,714 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [398]: Loading all plugins took 8.67487359046936 seconds
    2022-04-24 06:00:33,747 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [163]: Looking for old configuration files to upgrade.
    2022-04-24 06:00:33,845 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [177]: Checking and performing updates took 0.09890413284301758
    2022-04-24 06:00:33,870 - INFO - [MainThread] UM.Logger.info [137]: Completed loading preferences.
    2022-04-24 06:00:33,894 - INFO - [MainThread] UM.Logger.info [137]: Created system tray icon.
    2022-04-24 06:00:46,949 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [534]: Loading metadata into container registry took 13.02968168258667 seconds
    2022-04-24 06:00:46,980 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [142]: Select build plate: 0
    2022-04-24 06:00:46,992 - INFO - [MainThread] cura.CuraApplication.run [809]: Initializing machine error checker
    2022-04-24 06:00:47,392 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [74]: Default machine actions added for machine definition [creality_ender3pro]
    2022-04-24 06:00:47,684 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [202]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3 Pro] at position [0]
    2022-04-24 06:00:47,692 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [79]: No machine with name Creality Ender-3 Pro in list of firmware to check.
    2022-04-24 06:00:50,341 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [120]: Adding container tree for creality_ender3pro took 2.6350536346435547 seconds.
    2022-04-24 06:00:50,390 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ChangeAtZ
    2022-04-24 06:00:50,408 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: ColorMix
    2022-04-24 06:00:50,425 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: CreateThumbnail
    2022-04-24 06:00:50,442 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2022-04-24 06:00:50,458 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: DisplayProgressOnLCD
    2022-04-24 06:00:50,474 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: FilamentChange
    2022-04-24 06:00:50,491 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: InsertAtLayerChange
    2022-04-24 06:00:50,512 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: PauseAtHeight
    2022-04-24 06:00:50,516 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: RetractContinue
    2022-04-24 06:00:50,534 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: SearchAndReplace
    2022-04-24 06:00:50,560 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: Stretch
    2022-04-24 06:00:50,577 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: TimeLapse
    2022-04-24 06:00:50,592 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [204]: Begin loading of script: UsePreviousProbeMeasurements
    2022-04-24 06:00:50,592 - WARNING - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadAllScripts [155]: Unable to create a folder for scripts: C:\Program Files\Ultimaker Cura 4.13.1\resources\scripts
    2022-04-24 06:00:51,026 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [300]: The definition cache for definition fdmprinter failed to pickle.
    2022-04-24 06:00:51,107 - INFO - [MainThread] cura.CuraApplication.run [814]: Initializing machine manager
    2022-04-24 06:00:51,110 - INFO - [MainThread] cura.CuraApplication.run [819]: Initializing container manager
    2022-04-24 06:00:51,158 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.loadAuthDataFromPreferences [258]: Attempting to load the auth data from preferences.
    2022-04-24 06:00:51,162 - WARNING - [MainThread] UM.OutputDevice.OutputDeviceManager.removeOutputDevice [235]: Could not find output device with id digital_factory to remove
    2022-04-24 06:00:51,240 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.001096487045288086 seconds
    2022-04-24 06:00:51,259 - DEBUG - [JobQueueWorker [0]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.012988567352294922 seconds. 8 input vertices. 8 output vertices.
    2022-04-24 06:00:51,270 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [154]: New error check scheduled.
    2022-04-24 06:00:51,286 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-24 06:00:51,527 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [182]: Loading theme file: C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light\theme.json
    2022-04-24 06:00:52,727 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [287]: Loaded theme C:\Program Files\Ultimaker Cura 4.13.1\resources\themes\cura-light
    2022-04-24 06:00:54,495 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [342]: Creating post processing plugin view.
    2022-04-24 06:00:54,676 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [352]: Post processing view created.
    2022-04-24 06:00:54,950 - WARNING - [MainThread] UM.Qt.Bindings.Theme.getIcon [144]: The icon 'search' is deprecated. Please use icon 'Magnifier' instead.
    2022-04-24 06:00:55,243 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/Settings/SettingView.qml:140:5: QML SettingVisibilityPresetsMenu: Binding loop detected for property "width"
    2022-04-24 06:00:55,706 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-24 06:00:55,935 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-24 06:00:56,093 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-24 06:00:56,506 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-24 06:00:56,524 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [118]: Creating model checker view.
    2022-04-24 06:00:56,542 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [127]: Model checker view created.
    2022-04-24 06:00:56,542 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [76]: Creating dialog [MoreInfoWindow.qml]
    2022-04-24 06:00:56,646 - DEBUG - [MainThread] UM.Logger.debug [131]: Requesting updates metadata from server.
    2022-04-24 06:00:56,657 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [145]: No auth data to retrieve the access_token from
    2022-04-24 06:00:56,657 - DEBUG - [MainThread] UM.Logger.debug [131]: User is not logged in for Cloud API request to https://api.ultimaker.com/cura-packages/v1/cura/v7.9.0/packages/package-updates?installed_packages=FABtotumABS:1.4.0&installed_packages=DigitalLibrary:1.1.0&installed_packages=VersionUpgrade45to46:1.0.0&installed_packages=FABtotumNylon:1.4.0&installed_packages=RotateTool:1.0.1&installed_packages=AMFReader:1.0.0&installed_packages=VersionUpgrade34to35:1.0.1&installed_packages=IMADE3DJellyBOXPETG:1.0.1&installed_packages=VersionUpgrade40to41:1.0.1&installed_packages=SentryLogger:1.0.0&installed_packages=GenericPP:1.4.0&installed_packages=UFPWriter:1.0.1&installed_packages=VersionUpgrade35to40:1.0.0&installed_packages=FABtotumPLA:1.4.0&installed_packages=GenericCFFPA:1.4.0&installed_packages=GenericPETG:1.4.0&installed_packages=VersionUpgrade27to30:1.0.1&installed_packages=GCodeGzWriter:1.0.1&installed_packages=XmlMaterialProfile:1.0.1&installed_packages=GCodeProfileReader:1.0.1&installed_packages=3MFWriter:1.0.1&installed_packages=GCodeWriter:1.0.1&installed_packages=UltimakerTPLA:1.4.0&installed_packages=CameraTool:1.0.1&installed_packages=UltimakerPC:1.4.0&installed_packages=ImageReader:1.0.1&installed_packages=VersionUpgrade411to412:1.0.0&installed_packages=LocalContainerProvider:1.0.1&installed_packages=SelectionTool:1.0.1&installed_packages=LocalFileOutputDevice:1.0.1&installed_packages=VertexDeltaABS:1.4.0&installed_packages=FileLogger:1.0.1&installed_packages=ConsoleLogger:1.0.1&installed_packages=SimpleView:1.0.1&installed_packages=GenericToughPLA:1.4.0&installed_packages=VersionUpgrade32to33:1.0.1&installed_packages=GenericNylon:1.4.0&installed_packages=VertexDeltaPET:1.4.0&installed_packages=MirrorTool:1.0.1&installed_packages=UltimakerMachineActions:1.0.1&installed_packages=VertexDeltaPLA:1.4.0&installed_packages=CuraEngineBackend:1.0.1&installed_packages=VersionUpgrade44to45:1.0.0&installed_packages=CuraProfileReader:1.0.1&installed_packages=LegacyProfileReader:1.0.1&installed_packages=IMADE3DJellyBOXPLA:1.0.1&installed_packages=OctofiberPLA:1.0.1&installed_packages=OBJWriter:1.0.1&installed_packages=VersionUpgrade49to410:1.0.0&installed_packages=PerObjectSettingsTool:1.0.1&installed_packages=GenericCFFCPE:1.4.0&installed_packages=UltimakerPP:1.4.0&installed_packages=VersionUpgrade48to49:1.0.0&installed_packages=PrepareStage:1.0.1&installed_packages=Filo3DPLA:1.0.1&installed_packages=3MFReader:1.0.1&installed_packages=PolyMaxPLA:1.0.1&installed_packages=MonitorStage:1.0.1&installed_packages=TrimeshReader:1.0.0&installed_packages=GCodeGzReader:1.0.1&installed_packages=GenericTPU:1.4.0&installed_packages=UltimakerBAM:1.4.0&installed_packages=UltimakerNylon:1.4.0&installed_packages=FirmwareUpdater:1.0.1&installed_packages=MachineSettingsAction:1.0.1&installed_packages=UFPReader:1.0.0&installed_packages=UM3NetworkPrinting:1.0.1&installed_packages=VersionUpgrade21to22:1.0.1&installed_packages=VersionUpgrade47to48:1.0.0&installed_packages=TranslateTool:1.0.1&installed_packages=SupportEraser:1.0.1&installed_packages=PreviewStage:1.0.1&installed_packages=GenericABS:1.4.0&installed_packages=FABtotumTPU:1.4.0&installed_packages=VertexDeltaTPU:1.4.0&installed_packages=UltimakerCPE:1.4.0&installed_packages=GenericGFFCPE:1.4.0&installed_packages=FirmwareUpdateChecker:1.0.1&installed_packages=RemovableDriveOutputDevice:1.0.1&installed_packages=SimulationView:1.0.1&installed_packages=VersionUpgrade41to42:1.0.0&installed_packages=VersionUpgrade33to34:1.0.1&installed_packages=UltimakerABS:1.4.0&installed_packages=GenericCPE:1.4.0&installed_packages=UltimakerPVA:1.4.0&installed_packages=DagomaChromatikPLA:1.0.1&installed_packages=GenericBAM:1.4.0&installed_packages=SolidView:1.0.1&installed_packages=VersionUpgrade462to47:1.0.0&installed_packages=VersionUpgrade460to462:1.0.0&installed_packages=VersionUpgrade43to44:1.0.0&installed_packages=ModelChecker:1.0.1&installed_packages=GenericGFFPA:1.4.0&installed_packages=PolyWoodPLA:1.0.1&installed_packages=STLWriter:1.0.1&installed_packages=SliceInfoPlugin:1.0.1&installed_packages=OBJReader:1.0.1&installed_packages=GCodeReader:1.0.1&installed_packages=VersionUpgrade30to31:1.0.1&installed_packages=UltimakerPLA:1.4.0&installed_packages=XRayView:1.0.1&installed_packages=VersionUpgrade25to26:1.0.1&installed_packages=Toolbox:1.0.1&installed_packages=GenericPVA:1.4.0&installed_packages=PolyFlexPLA:1.0.1&installed_packages=UpdateChecker:1.0.1&installed_packages=CuraProfileWriter:1.0.1&installed_packages=USBPrinting:1.0.2&installed_packages=VersionUpgrade26to27:1.0.1&installed_packages=STLReader:1.0.1&installed_packages=CuraDrive:1.2.0&installed_packages=GenericHIPS:1.4.0&installed_packages=ScaleTool:1.0.1&installed_packages=FiberlogyHDPLA:1.0.1&installed_packages=PolyPlusPLA:1.0.1&installed_packages=X3DReader:1.0.1&installed_packages=UltimakerTPU:1.4.0&installed_packages=PostProcessingPlugin:2.2.1&installed_packages=VersionUpgrade42to43:1.0.0&installed_packages=UltimakerCPEP:1.4.0&installed_packages=GenericCPEPlus:1.4.0&installed_packages=VersionUpgrade22to24:1.0.1&installed_packages=GenericPLA:1.4.0&installed_packages=GenericPC:1.4.0
    2022-04-24 06:00:56,676 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [174]: Started background loading of MachineNodes
    2022-04-24 06:00:56,677 - DEBUG - [MainThread] cura.CuraApplication.run [863]: Booting Cura took 33.33169102668762 seconds
    2022-04-24 06:00:56,769 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x0000024D23E254C0> is deprecated (since 4.4): Please use extruderList instead.
    2022-04-24 06:00:56,793 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-24 06:00:56,817 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-24 06:00:57,200 - DEBUG - [JobQueueWorker [1]] cura.Machines.ContainerTree.run [185]: All MachineNode loading completed
    2022-04-24 06:00:57,358 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [58]: Updating QualityProfilesDropDownMenuModel.
    2022-04-24 06:00:57,368 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [33]: Updating CustomQualityProfilesDropDownMenuModel.
    2022-04-24 06:00:58,268 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [210]: Support for Vertex Array Objects: True
    2022-04-24 06:00:58,300 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2022-04-24 06:00:58,304 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 21.20.16.4664
    2022-04-24 06:00:58,310 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2022-04-24 06:00:58,315 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) HD Graphics 620
    2022-04-24 06:00:58,321 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2022-04-24 06:00:58,327 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-24 06:00:58,395 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\selection.shader]...
    2022-04-24 06:00:58,432 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\select_face.shader]...
    2022-04-24 06:00:58,466 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-24 06:00:58,493 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\composite.shader]...
    2022-04-24 06:00:58,548 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-24 06:00:58,597 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:00:58,647 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:00:58,691 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:00:58,730 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-24 06:00:58,753 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray_composite.shader]...
    2022-04-24 06:00:58,786 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\default.shader]...
    2022-04-24 06:00:58,802 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\grid.shader]...
    2022-04-24 06:00:58,821 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\platform.shader]...
    2022-04-24 06:00:58,917 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-24 06:01:03,690 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [213]: Error check finished, result = False, time = 12.4s
    2022-04-24 06:01:10,203 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.043236732482910156 seconds
    2022-04-24 06:01:33,666 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/MODELS/Earring stand for Krystina/EarRingBase.stl
    2022-04-24 06:01:33,677 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:01:33,699 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0 seconds
    2022-04-24 06:01:33,703 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 52812 vertices
    2022-04-24 06:01:33,798 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.08627128601074219 seconds. 1404 input vertices. 1404 output vertices.
    2022-04-24 06:01:33,828 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.1 seconds
    2022-04-24 06:01:33,922 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.09047436714172363 seconds. 1404 input vertices. 1404 output vertices.
    2022-04-24 06:01:33,957 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000024D3A007FA0>, took 2ms
    2022-04-24 06:01:34,016 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'EarRingBase.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'EarRingBase.stl'>,trans.=<0.000,0.000,0.000>), took 3ms
    2022-04-24 06:01:34,324 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:01:34,630 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:01:34,643 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:01:34,651 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:02:01,488 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.03299832344055176 seconds
    2022-04-24 06:02:01,493 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-24 06:02:01,501 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-24 06:02:01,507 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-24 06:02:01,527 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:02:01,545 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:02:01,983 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-24 06:02:01,984 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-24 06:02:02,210 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.2265617847442627 seconds
    2022-04-24 06:02:02,371 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sun" -s time="06:02:02" -s print_bed_temperature="60" -s material_name="empty" -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s draft_shield_height="10" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s wireframe_printspeed_bottom="5" -s wall_min_flow="0" -s wireframe_fall_down="0.5" -s material_adhesion_tendency="10" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s speed_slowdown_layers="2" -s prime_tower_flow="100" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s wireframe_drag_along="0.6" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s machine_always_write_active_tool="False" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s support_extruder_nr="0" -s acceleration_support="500" -s raft_margin="15" -s infill_mesh="False" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s support_roof_extruder_nr="0" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s material_bed_temp_prepend="True" -s machine_buildplate_type="glass" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s machine_max_jerk_e="5" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s machine_max_feedrate_z="10" -s material_initial_print_temperature="210" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s wireframe_roof_fall_down="2" -s alternate_carve_order="True" -s top_bottom_thickness="0.8" -s draft_shield_enabled="False" -s adaptive_layer_height_enabled="False" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s jerk_travel="8" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s support_enable="True" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s machine_height="250" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-24 06:02:02,383 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:02:02,384 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-24 06:02:02,384 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:02:02,392 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-24 06:02:02,400 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-24 06:02:02,400 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-24 06:02:02,400 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-24 06:02:02,408 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:02:02,408 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:02:02,415 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s ooze_shield_angle="60" -s machine_extruders_share_nozzle="False" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s acceleration_infill="500" -s machine_max_jerk_xy="10" -s support_bottom_stair_step_min_slope="10.0" -s magic_fuzzy_skin_thickness="0.3" -s retraction_combing="noskin" -s layer_height="0.2" -s wipe_retraction_amount="6.5" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s draft_shield_height_limitation="full" -s infill_extruder_nr="-1" -s jerk_support="8" -s raft_surface_layers="2" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="False" -s travel_compensate_overlapping_walls_x_enabled="True" -s roofing_layer_count="0" -s retraction_min_travel="1.5" -s date="24-04-2022" -s machine_heat_zone_length="16" -s blackmagic="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s bridge_wall_material_flow="50" -s raft_interface_fan_speed="0" -s skin_outline_count="1" -s acceleration_topbottom="500" -s travel_compensate_overlapping_walls_enabled="True" -s jerk_wall_x="8" -s default_material_bed_temperature="60" -s support_interface_material_flow="100" -s small_feature_speed_factor="50" -s z_seam_relative="False" -s skin_monotonic="False" -s xy_offset="0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s machine_depth="220" -s prime_tower_size="20" -s machine_settings="0" -s machine_max_acceleration_x="500" -s infill_offset_x="0" -s jerk_wall="8" -s support_bottom_offset="0.0" -s lightning_infill_prune_angle="40" -s speed_support_infill="25.0" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s switch_extruder_prime_speed="20" -s expand_skins_expand_distance="0.8" -s material="0" -s support_line_width="0.4" -s infill_offset_y="0" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s fill_outline_gaps="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s machine_width="220" -s acceleration_travel_layer_0="500" -s lightning_infill_straightening_angle="40" -s support_supported_skin_fan_speed="100" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s wireframe_straight_before_down="20" -s infill_overlap="30.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s acceleration_support_infill="500" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s retraction_hop_only_when_collides="False" -s flow_rate_max_extrusion_offset="0" -s raft_base_fan_speed="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s outer_inset_first="False" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s support_roof_density="33.333" -s material_standby_temperature="150" -s material_flow_layer_0="100" -s wall_0_extruder_nr="-1" -s raft_surface_jerk="8" -s speed_z_hop="5" -s material_no_load_move_factor="0.940860215" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_multiplier="1" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s support_join_distance="2.0" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s machine_max_feedrate_x="500" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s extruder_prime_pos_abs="False" -s material_guid="" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s raft_base_jerk="8" -s skirt_brim_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s wireframe_printspeed_flat="5" -s machine_heated_build_volume="False" -s ironing_pattern="zigzag" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s retraction_retract_speed="25" -s slicing_tolerance="middle" -s machine_steps_per_mm_x="50" -s material_flush_purge_length="60" -s wireframe_flow_connection="100" -s acceleration_wall_0="500" -s mold_angle="40" -s support_tower_maximum_supported_diameter="3.0" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s retract_at_layer_change="False" -s default_material_print_temperature="210" -s line_width="0.4" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_wall="25.0" -s coasting_speed="90" -s material_bed_temperature_layer_0="60" -s infill_pattern="cubic" -s retraction_extra_prime_amount="0" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s resolution="0" -s prime_tower_position_y="186.6" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s jerk_support_bottom="8" -s raft_speed="25.0" -s support_roof_pattern="grid" -s adaptive_layer_height_threshold="0.2" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s machine_max_acceleration_y="500" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s bridge_settings_enabled="False" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s machine_extruders_share_heater="False" -s support_skip_zag_per_mm="20" -s shell="0" -s travel_avoid_supports="True" -s jerk_enabled="False" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s support_type="everywhere" -s wireframe_printspeed_down="5" -s support_zag_skip_count="2" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s cool_fan_speed_0="0" -s command_line_settings="0" -s acceleration_support_bottom="500" -s jerk_print="8" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s material_bed_temperature="60" -s support_interface_skip_height="0.2" -s gantry_height="25" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s zig_zaggify_support="False" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-24 06:02:02,415 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-24 06:02:02,423 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-24 06:02:02,423 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-24 06:02:02,431 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-24 06:02:02,431 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-24 06:02:02,439 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:02:02,439 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-24 06:02:02,449 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-24 06:02:02,457 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-24 06:02:02,458 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-24 06:02:02,468 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:02:02,469 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-24 06:02:02,481 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s wireframe_bottom_delay="0" -s bottom_layers="4" -s prime_tower_brim_enable="False" -s remove_empty_first_layers="True" -s infill_overlap_mm="0.12" -s support_brim_enable="True" -s layer_start_x="0.0" -s min_infill_area="0" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s wireframe_top_jump="0.6" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s roofing_line_width="0.4" -s adhesion_type="skirt" -s wireframe_flow_flat="100" -s machine_max_acceleration_z="100" -s acceleration_print="500" -s prime_tower_enable="False" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s gradual_infill_steps="0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s raft_smoothing="5" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s ironing_flow="10.0" -s support_initial_layer_line_distance="8.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s bridge_enable_more_layers="True" -s top_layers="4" -s speed_support_interface="25.0" -s wall_0_inset="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_skin_expand_distance="0.8" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s max_extrusion_before_wipe="10" -s travel="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wireframe_top_delay="0" -s machine_name="Creality Ender-3 Pro" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s top_skin_preshrink="0.8" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s wall_thickness="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s support_xy_overrides_z="xy_overrides_z" -s speed_wall_0="25.0" -s meshfix="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_roof_height="0.8" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s speed_support_bottom="25.0" -s machine_show_variants="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s small_feature_max_length="0.0" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s center_object="False" -s material_break_preparation_retracted_position="-16" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_offset="0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s retraction_hop_after_extruder_switch_height="0.2" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s wall_0_wipe_dist="0.0" -s travel_retract_before_outer_wall="True" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s support_brim_width="4" -s support_interface_enable="True" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s support_top_distance="0.2" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s infill_support_angle="40" -s machine_firmware_retract="False" -s z_seam_y="220" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s adaptive_layer_height_variation_step="0.04" -s machine_nozzle_cool_down_speed="2.0" -s support_interface_density="33.333" -s raft_acceleration="500" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s infill_mesh_order="0" -s machine_min_cool_heat_time_window="50.0" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s hole_xy_offset="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s layer_height_0="0.2" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s machine_extruder_count="1" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s wireframe_printspeed_up="5" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s raft_interface_jerk="8" -s wireframe_enabled="False" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s cutting_mesh="False" -s wireframe_printspeed="5" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_structure="normal" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s smooth_spiralized_contours="True" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s material_bed_temp_wait="True" -s jerk_ironing="8" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s ooze_shield_enabled="False" -s bridge_fan_speed="100" -s machine_center_is_zero="False" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s skin_angles="[ ]" -s jerk_topbottom="8" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s material_final_print_temperature="210" -s fill_perimeter_gaps="everywhere" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -e0 -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s infill_support_angle="40" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s material_break_preparation_speed="2" -s material_extrusion_cool_down_speed="0.7" -s wall_min_flow="0" -s material_adhesion_tendency="0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s prime_tower_flow="100" -s raft_margin="15" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s acceleration_support="500" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s support_xy_distance_overhang="0.4" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s material_initial_print_temperature="200" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s extruder_nr="0" -s top_bottom_thickness="0.8" -s roofing_line_width="0.4" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s machine_extruder_end_pos_x="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s support_top_distance="0.2" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s retraction_hop_after_extruder_switch_height="0.2" -s support_offset="0" -s bridge_fan_speed_2="0" -s support_initial_layer_line_distance="8.0" -s ironing_flow="10.0" -s skirt_brim_material_flow="100" -s support_roof_density="33.333" -s material_standby_temperature="175" -s material_flow_layer_0="100" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s small_feature_max_length="0.0" -s lightning_infill_support_angle="40" -s support_brim_width="4" -s support_interface_enable="True" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s resolution="0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s retraction_min_travel="1.5" -s acceleration_support_infill="500" -s retraction_hop_only_when_collides="False" -s machine_extruder_start_pos_y="0" -s bridge_skin_speed_3="12.5" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s infill_line_width="0.4" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s retraction_extra_prime_amount="0" -s outer_inset_first="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s infill_multiplier="1" -s machine_settings="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s support_join_distance="2.0" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s material_no_load_move_factor="0.940860215" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_roof_height="0.8" -s extruder_prime_pos_abs="False" -s acceleration_travel_layer_0="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s speed_support_interface="25.0" -s wall_0_inset="0" -s top_layers="4" -s material_break_speed="25" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_fan_speed="100" -s brim_width="8.0" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s shell="0" -s travel_avoid_supports="True" -s jerk_support_bottom="8" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s ironing_pattern="zigzag" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s layer_start_x="0.0" -s support_brim_enable="True" -s min_infill_area="0" -s bridge_sparse_infill_max_density="0" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wall_0_wipe_dist="0.0" -s skin_monotonic="False" -s top_skin_preshrink="0.8" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s machine_endstop_positive_direction_x="False" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s support="0" -s skin_edge_support_layers="0" -s raft_base_jerk="8" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s support_roof_line_distance="2.4000240002400024" -s default_material_print_temperature="200" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s raft_smoothing="5" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s acceleration_print="500" -s gradual_infill_steps="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s cool_fan_speed_0="0" -s bridge_enable_more_layers="True" -s retract_at_layer_change="False" -s extruder_prime_pos_y="0" -s jerk_support_roof="8" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s acceleration_infill="500" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="6.5" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s wall_thickness="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_wall="25.0" -s coasting_speed="90" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s jerk_infill="8" -s wall_min_flow_retract="False" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s infill_pattern="cubic" -s skin_line_width="0.4" -s wipe_move_distance="20" -s support_tower_maximum_supported_diameter="3.0" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s line_width="0.4" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s slicing_tolerance="middle" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s switch_extruder_prime_speed="20" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s max_extrusion_before_wipe="10" -s travel="0" -s small_feature_speed_factor="50" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s lightning_infill_prune_angle="40" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s alternate_extra_perimeter="False" -s raft_interface_jerk="8" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s infill_overlap_mm="0.12" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s machine_extruder_start_pos_abs="False" -s machine_extruder_start_code="" -s z_seam_y="220" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s jerk_topbottom="8" -s wipe_brush_pos_x="100" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s raft_surface_acceleration="500" -s meshfix_maximum_resolution="0.25" -s material_final_print_temperature="200" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s xy_offset="0" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_bottom_stair_step_height="0.3" -s infill_offset_y="0" -s expand_skins_expand_distance="0.8" -s material="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s support_line_width="0.4" -s support_bottom_offset="0.0" -s infill_offset_x="0" -s jerk_wall="8" -s z_seam_relative="False" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s jerk_wall_x="8" -s support_interface_material_flow="100" -s skin_outline_count="1" -s acceleration_topbottom="500" -s bridge_wall_material_flow="50" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s speed_layer_0="20.0" -s top_skin_expand_distance="0.8" -s machine_heat_zone_length="16" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s magic_fuzzy_skin_enabled="False" -s raft_surface_layers="2" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s jerk_support="8" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s magic_fuzzy_skin_thickness="0.3" -s support_bottom_stair_step_min_slope="10.0" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-24 06:02:10,430 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 8.44737195968628 seconds
    2022-04-24 06:02:10,431 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-24 06:02:10,432 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-24 06:02:10,437 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-24 06:02:10,441 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-24 06:02:10,448 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-24 06:02:10,451 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-24 06:02:23,723 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingBase.gcode]...
    2022-04-24 06:02:23,735 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingBase.gcode in text mode
    2022-04-24 06:02:24,043 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.26665759086608887 seconds
    2022-04-24 06:02:26,211 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-24 06:02:34,246 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-24 06:02:34,250 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-24 06:02:34,325 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-24 06:02:34,329 - INFO - [MainThread] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:02:34,356 - DEBUG - [MainThread] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0009968280792236328 seconds
    2022-04-24 06:02:34,358 - DEBUG - [MainThread] STLReader.STLReader._read [105]: Loaded a mesh with 12612 vertices
    2022-04-24 06:02:34,370 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\simulationview_composite.shader]...
    2022-04-24 06:02:34,505 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-24 06:02:35,039 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-24 06:02:35,083 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d.shader]...
    2022-04-24 06:02:35,235 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\plugins\SimulationView\layers3d_shadow.shader]...
    2022-04-24 06:02:35,333 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-24 06:02:35,364 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\color.shader]...
    2022-04-24 06:02:35,385 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:02:35,801 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 1.2955477237701416 seconds
    2022-04-24 06:02:35,877 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-24 06:02:45,546 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.038704872131347656 seconds
    2022-04-24 06:03:02,768 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-24 06:03:02,775 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-24 06:03:02,782 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-24 06:03:02,843 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-24 06:03:03,490 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-24 06:03:05,189 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\toolhandle.shader]...
    2022-04-24 06:03:06,578 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000024D39FF4040>, took 19ms
    2022-04-24 06:03:07,167 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-24 06:03:07,179 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-24 06:03:07,192 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-24 06:03:07,203 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-24 06:03:07,452 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-24 06:03:10,952 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/MODELS/Earring stand for Krystina/EarRingStop.stl
    2022-04-24 06:03:10,963 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:03:10,989 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0020935535430908203 seconds
    2022-04-24 06:03:10,993 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 33666 vertices
    2022-04-24 06:03:11,170 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.16852760314941406 seconds. 4745 input vertices. 4745 output vertices.
    2022-04-24 06:03:11,191 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.2 seconds
    2022-04-24 06:03:11,364 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.16314029693603516 seconds. 4745 input vertices. 4745 output vertices.
    2022-04-24 06:03:11,390 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000024D42EF8340>, took 2ms
    2022-04-24 06:03:11,437 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'EarRingStop.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'EarRingStop.stl'>,trans.=<0.000,0.000,0.000>), took 4ms
    2022-04-24 06:03:12,045 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:03:12,056 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:03:12,066 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:03:24,155 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-24 06:03:24,159 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-24 06:03:24,165 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-24 06:03:24,185 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:03:24,200 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:03:24,689 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-24 06:03:24,689 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-24 06:03:24,694 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-24 06:03:24,837 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-24 06:03:24,853 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-24 06:03:24,860 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-24 06:03:24,911 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.22114849090576172 seconds
    2022-04-24 06:03:25,035 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:03:25,041 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-24 06:03:25,047 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-24 06:03:25,051 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-24 06:03:25,056 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-24 06:03:25,057 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:03:25,057 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-24 06:03:25,065 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-24 06:03:25,070 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-24 06:03:25,078 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-24 06:03:25,079 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:03:25,079 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-24 06:03:25,087 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-24 06:03:25,095 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-24 06:03:25,105 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-24 06:03:25,113 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-24 06:03:25,113 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-24 06:03:25,163 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sun" -s time="06:03:24" -s print_bed_temperature="60" -s material_name="empty" -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s draft_shield_height="10" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s wireframe_printspeed_bottom="5" -s wall_min_flow="0" -s wireframe_fall_down="0.5" -s material_adhesion_tendency="10" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s speed_slowdown_layers="2" -s prime_tower_flow="100" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s wireframe_drag_along="0.6" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s machine_always_write_active_tool="False" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s support_extruder_nr="0" -s acceleration_support="500" -s raft_margin="15" -s infill_mesh="False" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s support_roof_extruder_nr="0" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s material_bed_temp_prepend="True" -s machine_buildplate_type="glass" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s machine_max_jerk_e="5" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s machine_max_feedrate_z="10" -s material_initial_print_temperature="210" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s wireframe_roof_fall_down="2" -s alternate_carve_order="True" -s top_bottom_thickness="0.8" -s draft_shield_enabled="False" -s adaptive_layer_height_enabled="False" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s jerk_travel="8" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s support_enable="True" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s machine_height="250" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-24 06:03:25,172 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:03:25,172 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-24 06:03:25,188 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:03:25,189 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-24 06:03:25,198 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-24 06:03:25,204 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-24 06:03:25,212 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-24 06:03:25,222 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:03:25,222 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:03:25,230 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s ooze_shield_angle="60" -s machine_extruders_share_nozzle="False" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s acceleration_infill="500" -s machine_max_jerk_xy="10" -s support_bottom_stair_step_min_slope="10.0" -s magic_fuzzy_skin_thickness="0.3" -s retraction_combing="noskin" -s layer_height="0.2" -s wipe_retraction_amount="6.5" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s draft_shield_height_limitation="full" -s infill_extruder_nr="-1" -s jerk_support="8" -s raft_surface_layers="2" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="False" -s travel_compensate_overlapping_walls_x_enabled="True" -s roofing_layer_count="0" -s retraction_min_travel="1.5" -s date="24-04-2022" -s machine_heat_zone_length="16" -s blackmagic="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s bridge_wall_material_flow="50" -s raft_interface_fan_speed="0" -s skin_outline_count="1" -s acceleration_topbottom="500" -s travel_compensate_overlapping_walls_enabled="True" -s jerk_wall_x="8" -s default_material_bed_temperature="60" -s support_interface_material_flow="100" -s small_feature_speed_factor="50" -s z_seam_relative="False" -s skin_monotonic="False" -s xy_offset="0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s machine_depth="220" -s prime_tower_size="20" -s machine_settings="0" -s machine_max_acceleration_x="500" -s infill_offset_x="0" -s jerk_wall="8" -s support_bottom_offset="0.0" -s lightning_infill_prune_angle="40" -s speed_support_infill="25.0" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s switch_extruder_prime_speed="20" -s expand_skins_expand_distance="0.8" -s material="0" -s support_line_width="0.4" -s infill_offset_y="0" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s fill_outline_gaps="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s machine_width="220" -s acceleration_travel_layer_0="500" -s lightning_infill_straightening_angle="40" -s support_supported_skin_fan_speed="100" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s wireframe_straight_before_down="20" -s infill_overlap="30.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s acceleration_support_infill="500" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s retraction_hop_only_when_collides="False" -s flow_rate_max_extrusion_offset="0" -s raft_base_fan_speed="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s outer_inset_first="False" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s support_roof_density="33.333" -s material_standby_temperature="150" -s material_flow_layer_0="100" -s wall_0_extruder_nr="-1" -s raft_surface_jerk="8" -s speed_z_hop="5" -s material_no_load_move_factor="0.940860215" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_multiplier="1" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s support_join_distance="2.0" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s machine_max_feedrate_x="500" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s extruder_prime_pos_abs="False" -s material_guid="" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s raft_base_jerk="8" -s skirt_brim_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s wireframe_printspeed_flat="5" -s machine_heated_build_volume="False" -s ironing_pattern="zigzag" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s retraction_retract_speed="25" -s slicing_tolerance="middle" -s machine_steps_per_mm_x="50" -s material_flush_purge_length="60" -s wireframe_flow_connection="100" -s acceleration_wall_0="500" -s mold_angle="40" -s support_tower_maximum_supported_diameter="3.0" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s retract_at_layer_change="False" -s default_material_print_temperature="210" -s line_width="0.4" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_wall="25.0" -s coasting_speed="90" -s material_bed_temperature_layer_0="60" -s infill_pattern="cubic" -s retraction_extra_prime_amount="0" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s resolution="0" -s prime_tower_position_y="186.6" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s jerk_support_bottom="8" -s raft_speed="25.0" -s support_roof_pattern="grid" -s adaptive_layer_height_threshold="0.2" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s machine_max_acceleration_y="500" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s bridge_settings_enabled="False" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s machine_extruders_share_heater="False" -s support_skip_zag_per_mm="20" -s shell="0" -s travel_avoid_supports="True" -s jerk_enabled="False" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s support_type="everywhere" -s wireframe_printspeed_down="5" -s support_zag_skip_count="2" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s cool_fan_speed_0="0" -s command_line_settings="0" -s acceleration_support_bottom="500" -s jerk_print="8" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s material_bed_temperature="60" -s support_interface_skip_height="0.2" -s gantry_height="25" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s zig_zaggify_support="False" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-24 06:03:25,240 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-24 06:03:25,248 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-24 06:03:25,256 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-24 06:03:25,264 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-24 06:03:25,271 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-24 06:03:25,287 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-24 06:03:25,297 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-24 06:03:25,306 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-24 06:03:25,307 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-24 06:03:25,321 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:03:25,324 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-24 06:03:25,339 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s wireframe_bottom_delay="0" -s bottom_layers="4" -s prime_tower_brim_enable="False" -s remove_empty_first_layers="True" -s infill_overlap_mm="0.12" -s support_brim_enable="True" -s layer_start_x="0.0" -s min_infill_area="0" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s wireframe_top_jump="0.6" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s roofing_line_width="0.4" -s adhesion_type="skirt" -s wireframe_flow_flat="100" -s machine_max_acceleration_z="100" -s acceleration_print="500" -s prime_tower_enable="False" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s gradual_infill_steps="0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s raft_smoothing="5" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s ironing_flow="10.0" -s support_initial_layer_line_distance="8.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s bridge_enable_more_layers="True" -s top_layers="4" -s speed_support_interface="25.0" -s wall_0_inset="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_skin_expand_distance="0.8" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s max_extrusion_before_wipe="10" -s travel="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wireframe_top_delay="0" -s machine_name="Creality Ender-3 Pro" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s top_skin_preshrink="0.8" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s wall_thickness="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s support_xy_overrides_z="xy_overrides_z" -s speed_wall_0="25.0" -s meshfix="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_roof_height="0.8" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s speed_support_bottom="25.0" -s machine_show_variants="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s small_feature_max_length="0.0" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s center_object="False" -s material_break_preparation_retracted_position="-16" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_offset="0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s retraction_hop_after_extruder_switch_height="0.2" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s wall_0_wipe_dist="0.0" -s travel_retract_before_outer_wall="True" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s support_brim_width="4" -s support_interface_enable="True" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s support_top_distance="0.2" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s infill_support_angle="40" -s machine_firmware_retract="False" -s z_seam_y="220" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s adaptive_layer_height_variation_step="0.04" -s machine_nozzle_cool_down_speed="2.0" -s support_interface_density="33.333" -s raft_acceleration="500" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s infill_mesh_order="0" -s machine_min_cool_heat_time_window="50.0" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s hole_xy_offset="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s layer_height_0="0.2" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s machine_extruder_count="1" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s wireframe_printspeed_up="5" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s raft_interface_jerk="8" -s wireframe_enabled="False" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s cutting_mesh="False" -s wireframe_printspeed="5" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_structure="normal" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s smooth_spiralized_contours="True" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s material_bed_temp_wait="True" -s jerk_ironing="8" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s ooze_shield_enabled="False" -s bridge_fan_speed="100" -s machine_center_is_zero="False" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s skin_angles="[ ]" -s jerk_topbottom="8" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s material_final_print_temperature="210" -s fill_perimeter_gaps="everywhere" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -e0 -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s infill_support_angle="40" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s material_break_preparation_speed="2" -s material_extrusion_cool_down_speed="0.7" -s wall_min_flow="0" -s material_adhesion_tendency="0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s prime_tower_flow="100" -s raft_margin="15" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s acceleration_support="500" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s support_xy_distance_overhang="0.4" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s material_initial_print_temperature="200" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s extruder_nr="0" -s top_bottom_thickness="0.8" -s roofing_line_width="0.4" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s machine_extruder_end_pos_x="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s support_top_distance="0.2" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s retraction_hop_after_extruder_switch_height="0.2" -s support_offset="0" -s bridge_fan_speed_2="0" -s support_initial_layer_line_distance="8.0" -s ironing_flow="10.0" -s skirt_brim_material_flow="100" -s support_roof_density="33.333" -s material_standby_temperature="175" -s material_flow_layer_0="100" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s small_feature_max_length="0.0" -s lightning_infill_support_angle="40" -s support_brim_width="4" -s support_interface_enable="True" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s resolution="0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s retraction_min_travel="1.5" -s acceleration_support_infill="500" -s retraction_hop_only_when_collides="False" -s machine_extruder_start_pos_y="0" -s bridge_skin_speed_3="12.5" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s infill_line_width="0.4" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s retraction_extra_prime_amount="0" -s outer_inset_first="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s infill_multiplier="1" -s machine_settings="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s support_join_distance="2.0" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s material_no_load_move_factor="0.940860215" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_roof_height="0.8" -s extruder_prime_pos_abs="False" -s acceleration_travel_layer_0="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s speed_support_interface="25.0" -s wall_0_inset="0" -s top_layers="4" -s material_break_speed="25" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_fan_speed="100" -s brim_width="8.0" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s shell="0" -s travel_avoid_supports="True" -s jerk_support_bottom="8" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s ironing_pattern="zigzag" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s layer_start_x="0.0" -s support_brim_enable="True" -s min_infill_area="0" -s bridge_sparse_infill_max_density="0" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wall_0_wipe_dist="0.0" -s skin_monotonic="False" -s top_skin_preshrink="0.8" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s machine_endstop_positive_direction_x="False" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s support="0" -s skin_edge_support_layers="0" -s raft_base_jerk="8" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s support_roof_line_distance="2.4000240002400024" -s default_material_print_temperature="200" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s raft_smoothing="5" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s acceleration_print="500" -s gradual_infill_steps="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s cool_fan_speed_0="0" -s bridge_enable_more_layers="True" -s retract_at_layer_change="False" -s extruder_prime_pos_y="0" -s jerk_support_roof="8" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s acceleration_infill="500" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="6.5" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s wall_thickness="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_wall="25.0" -s coasting_speed="90" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s jerk_infill="8" -s wall_min_flow_retract="False" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s infill_pattern="cubic" -s skin_line_width="0.4" -s wipe_move_distance="20" -s support_tower_maximum_supported_diameter="3.0" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s line_width="0.4" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s slicing_tolerance="middle" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s switch_extruder_prime_speed="20" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s max_extrusion_before_wipe="10" -s travel="0" -s small_feature_speed_factor="50" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s lightning_infill_prune_angle="40" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s alternate_extra_perimeter="False" -s raft_interface_jerk="8" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s infill_overlap_mm="0.12" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s machine_extruder_start_pos_abs="False" -s machine_extruder_start_code="" -s z_seam_y="220" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s jerk_topbottom="8" -s wipe_brush_pos_x="100" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s raft_surface_acceleration="500" -s meshfix_maximum_resolution="0.25" -s material_final_print_temperature="200" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s xy_offset="0" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_bottom_stair_step_height="0.3" -s infill_offset_y="0" -s expand_skins_expand_distance="0.8" -s material="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s support_line_width="0.4" -s support_bottom_offset="0.0" -s infill_offset_x="0" -s jerk_wall="8" -s z_seam_relative="False" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s jerk_wall_x="8" -s support_interface_material_flow="100" -s skin_outline_count="1" -s acceleration_topbottom="500" -s bridge_wall_material_flow="50" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s speed_layer_0="20.0" -s top_skin_expand_distance="0.8" -s machine_heat_zone_length="16" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s magic_fuzzy_skin_enabled="False" -s raft_surface_layers="2" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s jerk_support="8" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s magic_fuzzy_skin_thickness="0.3" -s support_bottom_stair_step_min_slope="10.0" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-24 06:03:26,515 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04066205024719238 seconds
    2022-04-24 06:03:28,143 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 3.4533371925354004 seconds
    2022-04-24 06:03:28,145 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-24 06:03:28,146 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-24 06:03:28,158 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-24 06:03:28,167 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-24 06:03:28,179 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-24 06:03:28,196 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-24 06:03:32,236 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-24 06:03:32,241 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-24 06:03:32,275 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-24 06:03:32,345 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-24 06:03:32,735 - DEBUG - [JobQueueWorker [0]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.38797783851623535 seconds
    2022-04-24 06:03:32,807 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-24 06:03:42,814 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.030165672302246094 seconds
    2022-04-24 06:03:43,282 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingStop.gcode]...
    2022-04-24 06:03:43,303 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingStop.gcode in text mode
    2022-04-24 06:03:43,410 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.09107398986816406 seconds
    2022-04-24 06:03:44,073 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-24 06:03:46,355 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-24 06:03:46,355 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-24 06:03:46,366 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-24 06:03:46,415 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-24 06:03:46,854 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-24 06:03:50,071 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000024D40F1AC70>, took 16ms
    2022-04-24 06:03:50,662 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-24 06:03:50,676 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-24 06:03:50,691 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-24 06:03:50,705 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-24 06:03:50,967 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-24 06:03:56,972 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.02806711196899414 seconds
    2022-04-24 06:03:59,160 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/MODELS/Earring stand for Krystina/EarRingTop.stl
    2022-04-24 06:03:59,170 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:03:59,377 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.05303335189819336 seconds
    2022-04-24 06:03:59,397 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 1082718 vertices
    2022-04-24 06:04:00,437 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 1.0245654582977295 seconds. 3371 input vertices. 3371 output vertices.
    2022-04-24 06:04:00,637 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 1.5 seconds
    2022-04-24 06:04:01,435 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.7981574535369873 seconds. 3371 input vertices. 3371 output vertices.
    2022-04-24 06:04:01,462 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000024D36D61430>, took 2ms
    2022-04-24 06:04:01,517 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'EarRingTop.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'EarRingTop.stl'>,trans.=<0.000,0.000,0.000>), took 3ms
    2022-04-24 06:04:02,109 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:04:02,121 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:04:02,130 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:04:06,084 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-24 06:04:06,089 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-24 06:04:06,095 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-24 06:04:06,114 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:04:06,128 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:04:06,506 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-24 06:04:06,507 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-24 06:04:06,518 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-24 06:04:06,657 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-24 06:04:06,686 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-24 06:04:06,697 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-24 06:04:06,952 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:06,969 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-24 06:04:06,970 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-24 06:04:06,971 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-24 06:04:06,989 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-24 06:04:06,991 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:07,003 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-24 06:04:07,015 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-24 06:04:07,024 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-24 06:04:07,044 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-24 06:04:07,053 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:07,064 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-24 06:04:07,069 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-24 06:04:07,085 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-24 06:04:07,093 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-24 06:04:07,099 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:07,107 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-24 06:04:07,115 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-24 06:04:07,281 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.7739057540893555 seconds
    2022-04-24 06:04:08,624 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sun" -s time="06:04:07" -s print_bed_temperature="60" -s material_name="empty" -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s draft_shield_height="10" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s wireframe_printspeed_bottom="5" -s wall_min_flow="0" -s wireframe_fall_down="0.5" -s material_adhesion_tendency="10" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s speed_slowdown_layers="2" -s prime_tower_flow="100" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s wireframe_drag_along="0.6" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s machine_always_write_active_tool="False" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s support_extruder_nr="0" -s acceleration_support="500" -s raft_margin="15" -s infill_mesh="False" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s support_roof_extruder_nr="0" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s material_bed_temp_prepend="True" -s machine_buildplate_type="glass" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s machine_max_jerk_e="5" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s machine_max_feedrate_z="10" -s material_initial_print_temperature="210" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s wireframe_roof_fall_down="2" -s alternate_carve_order="True" -s top_bottom_thickness="0.8" -s draft_shield_enabled="False" -s adaptive_layer_height_enabled="False" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s jerk_travel="8" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s support_enable="True" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s machine_height="250" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-24 06:04:08,633 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:04:08,633 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-24 06:04:08,641 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:04:08,649 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-24 06:04:08,657 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-24 06:04:08,665 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-24 06:04:08,667 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-24 06:04:08,675 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:04:08,682 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:04:08,682 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s ooze_shield_angle="60" -s machine_extruders_share_nozzle="False" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s acceleration_infill="500" -s machine_max_jerk_xy="10" -s support_bottom_stair_step_min_slope="10.0" -s magic_fuzzy_skin_thickness="0.3" -s retraction_combing="noskin" -s layer_height="0.2" -s wipe_retraction_amount="6.5" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s draft_shield_height_limitation="full" -s infill_extruder_nr="-1" -s jerk_support="8" -s raft_surface_layers="2" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="False" -s travel_compensate_overlapping_walls_x_enabled="True" -s roofing_layer_count="0" -s retraction_min_travel="1.5" -s date="24-04-2022" -s machine_heat_zone_length="16" -s blackmagic="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s bridge_wall_material_flow="50" -s raft_interface_fan_speed="0" -s skin_outline_count="1" -s acceleration_topbottom="500" -s travel_compensate_overlapping_walls_enabled="True" -s jerk_wall_x="8" -s default_material_bed_temperature="60" -s support_interface_material_flow="100" -s small_feature_speed_factor="50" -s z_seam_relative="False" -s skin_monotonic="False" -s xy_offset="0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s machine_depth="220" -s prime_tower_size="20" -s machine_settings="0" -s machine_max_acceleration_x="500" -s infill_offset_x="0" -s jerk_wall="8" -s support_bottom_offset="0.0" -s lightning_infill_prune_angle="40" -s speed_support_infill="25.0" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s switch_extruder_prime_speed="20" -s expand_skins_expand_distance="0.8" -s material="0" -s support_line_width="0.4" -s infill_offset_y="0" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s fill_outline_gaps="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s machine_width="220" -s acceleration_travel_layer_0="500" -s lightning_infill_straightening_angle="40" -s support_supported_skin_fan_speed="100" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s wireframe_straight_before_down="20" -s infill_overlap="30.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s acceleration_support_infill="500" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s retraction_hop_only_when_collides="False" -s flow_rate_max_extrusion_offset="0" -s raft_base_fan_speed="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s outer_inset_first="False" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s support_roof_density="33.333" -s material_standby_temperature="150" -s material_flow_layer_0="100" -s wall_0_extruder_nr="-1" -s raft_surface_jerk="8" -s speed_z_hop="5" -s material_no_load_move_factor="0.940860215" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_multiplier="1" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s support_join_distance="2.0" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s machine_max_feedrate_x="500" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s extruder_prime_pos_abs="False" -s material_guid="" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s raft_base_jerk="8" -s skirt_brim_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s wireframe_printspeed_flat="5" -s machine_heated_build_volume="False" -s ironing_pattern="zigzag" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s retraction_retract_speed="25" -s slicing_tolerance="middle" -s machine_steps_per_mm_x="50" -s material_flush_purge_length="60" -s wireframe_flow_connection="100" -s acceleration_wall_0="500" -s mold_angle="40" -s support_tower_maximum_supported_diameter="3.0" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s retract_at_layer_change="False" -s default_material_print_temperature="210" -s line_width="0.4" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_wall="25.0" -s coasting_speed="90" -s material_bed_temperature_layer_0="60" -s infill_pattern="cubic" -s retraction_extra_prime_amount="0" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s resolution="0" -s prime_tower_position_y="186.6" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s jerk_support_bottom="8" -s raft_speed="25.0" -s support_roof_pattern="grid" -s adaptive_layer_height_threshold="0.2" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s machine_max_acceleration_y="500" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s bridge_settings_enabled="False" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s machine_extruders_share_heater="False" -s support_skip_zag_per_mm="20" -s shell="0" -s travel_avoid_supports="True" -s jerk_enabled="False" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s support_type="everywhere" -s wireframe_printspeed_down="5" -s support_zag_skip_count="2" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s cool_fan_speed_0="0" -s command_line_settings="0" -s acceleration_support_bottom="500" -s jerk_print="8" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s material_bed_temperature="60" -s support_interface_skip_height="0.2" -s gantry_height="25" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s zig_zaggify_support="False" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-24 06:04:08,690 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-24 06:04:08,698 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-24 06:04:08,698 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-24 06:04:08,706 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-24 06:04:08,716 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-24 06:04:08,717 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:08,717 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-24 06:04:08,725 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-24 06:04:08,734 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-24 06:04:08,734 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-24 06:04:08,742 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:04:08,742 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-24 06:04:08,754 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s wireframe_bottom_delay="0" -s bottom_layers="4" -s prime_tower_brim_enable="False" -s remove_empty_first_layers="True" -s infill_overlap_mm="0.12" -s support_brim_enable="True" -s layer_start_x="0.0" -s min_infill_area="0" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s wireframe_top_jump="0.6" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s roofing_line_width="0.4" -s adhesion_type="skirt" -s wireframe_flow_flat="100" -s machine_max_acceleration_z="100" -s acceleration_print="500" -s prime_tower_enable="False" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s gradual_infill_steps="0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s raft_smoothing="5" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s ironing_flow="10.0" -s support_initial_layer_line_distance="8.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s bridge_enable_more_layers="True" -s top_layers="4" -s speed_support_interface="25.0" -s wall_0_inset="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_skin_expand_distance="0.8" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s max_extrusion_before_wipe="10" -s travel="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wireframe_top_delay="0" -s machine_name="Creality Ender-3 Pro" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s top_skin_preshrink="0.8" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s wall_thickness="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s support_xy_overrides_z="xy_overrides_z" -s speed_wall_0="25.0" -s meshfix="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_roof_height="0.8" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s speed_support_bottom="25.0" -s machine_show_variants="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s small_feature_max_length="0.0" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s center_object="False" -s material_break_preparation_retracted_position="-16" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_offset="0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s retraction_hop_after_extruder_switch_height="0.2" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s wall_0_wipe_dist="0.0" -s travel_retract_before_outer_wall="True" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s support_brim_width="4" -s support_interface_enable="True" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s support_top_distance="0.2" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s infill_support_angle="40" -s machine_firmware_retract="False" -s z_seam_y="220" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s adaptive_layer_height_variation_step="0.04" -s machine_nozzle_cool_down_speed="2.0" -s support_interface_density="33.333" -s raft_acceleration="500" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s infill_mesh_order="0" -s machine_min_cool_heat_time_window="50.0" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s hole_xy_offset="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s layer_height_0="0.2" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s machine_extruder_count="1" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s wireframe_printspeed_up="5" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s raft_interface_jerk="8" -s wireframe_enabled="False" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s cutting_mesh="False" -s wireframe_printspeed="5" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_structure="normal" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s smooth_spiralized_contours="True" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s material_bed_temp_wait="True" -s jerk_ironing="8" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s ooze_shield_enabled="False" -s bridge_fan_speed="100" -s machine_center_is_zero="False" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s skin_angles="[ ]" -s jerk_topbottom="8" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s material_final_print_temperature="210" -s fill_perimeter_gaps="everywhere" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -e0 -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s infill_support_angle="40" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s material_break_preparation_speed="2" -s material_extrusion_cool_down_speed="0.7" -s wall_min_flow="0" -s material_adhesion_tendency="0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s prime_tower_flow="100" -s raft_margin="15" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s acceleration_support="500" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s support_xy_distance_overhang="0.4" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s material_initial_print_temperature="200" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s extruder_nr="0" -s top_bottom_thickness="0.8" -s roofing_line_width="0.4" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s machine_extruder_end_pos_x="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s support_top_distance="0.2" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s retraction_hop_after_extruder_switch_height="0.2" -s support_offset="0" -s bridge_fan_speed_2="0" -s support_initial_layer_line_distance="8.0" -s ironing_flow="10.0" -s skirt_brim_material_flow="100" -s support_roof_density="33.333" -s material_standby_temperature="175" -s material_flow_layer_0="100" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s small_feature_max_length="0.0" -s lightning_infill_support_angle="40" -s support_brim_width="4" -s support_interface_enable="True" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s resolution="0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s retraction_min_travel="1.5" -s acceleration_support_infill="500" -s retraction_hop_only_when_collides="False" -s machine_extruder_start_pos_y="0" -s bridge_skin_speed_3="12.5" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s infill_line_width="0.4" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s retraction_extra_prime_amount="0" -s outer_inset_first="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s infill_multiplier="1" -s machine_settings="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s support_join_distance="2.0" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s material_no_load_move_factor="0.940860215" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_roof_height="0.8" -s extruder_prime_pos_abs="False" -s acceleration_travel_layer_0="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s speed_support_interface="25.0" -s wall_0_inset="0" -s top_layers="4" -s material_break_speed="25" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_fan_speed="100" -s brim_width="8.0" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s shell="0" -s travel_avoid_supports="True" -s jerk_support_bottom="8" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s ironing_pattern="zigzag" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s layer_start_x="0.0" -s support_brim_enable="True" -s min_infill_area="0" -s bridge_sparse_infill_max_density="0" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wall_0_wipe_dist="0.0" -s skin_monotonic="False" -s top_skin_preshrink="0.8" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s machine_endstop_positive_direction_x="False" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s support="0" -s skin_edge_support_layers="0" -s raft_base_jerk="8" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s support_roof_line_distance="2.4000240002400024" -s default_material_print_temperature="200" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s raft_smoothing="5" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s acceleration_print="500" -s gradual_infill_steps="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s cool_fan_speed_0="0" -s bridge_enable_more_layers="True" -s retract_at_layer_change="False" -s extruder_prime_pos_y="0" -s jerk_support_roof="8" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s acceleration_infill="500" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="6.5" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s wall_thickness="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_wall="25.0" -s coasting_speed="90" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s jerk_infill="8" -s wall_min_flow_retract="False" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s infill_pattern="cubic" -s skin_line_width="0.4" -s wipe_move_distance="20" -s support_tower_maximum_supported_diameter="3.0" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s line_width="0.4" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s slicing_tolerance="middle" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s switch_extruder_prime_speed="20" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s max_extrusion_before_wipe="10" -s travel="0" -s small_feature_speed_factor="50" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s lightning_infill_prune_angle="40" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s alternate_extra_perimeter="False" -s raft_interface_jerk="8" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s infill_overlap_mm="0.12" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s machine_extruder_start_pos_abs="False" -s machine_extruder_start_code="" -s z_seam_y="220" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s jerk_topbottom="8" -s wipe_brush_pos_x="100" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s raft_surface_acceleration="500" -s meshfix_maximum_resolution="0.25" -s material_final_print_temperature="200" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s xy_offset="0" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_bottom_stair_step_height="0.3" -s infill_offset_y="0" -s expand_skins_expand_distance="0.8" -s material="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s support_line_width="0.4" -s support_bottom_offset="0.0" -s infill_offset_x="0" -s jerk_wall="8" -s z_seam_relative="False" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s jerk_wall_x="8" -s support_interface_material_flow="100" -s skin_outline_count="1" -s acceleration_topbottom="500" -s bridge_wall_material_flow="50" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s speed_layer_0="20.0" -s top_skin_expand_distance="0.8" -s machine_heat_zone_length="16" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s magic_fuzzy_skin_enabled="False" -s raft_surface_layers="2" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s jerk_support="8" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s magic_fuzzy_skin_thickness="0.3" -s support_bottom_stair_step_min_slope="10.0" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-24 06:04:11,616 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.04183697700500488 seconds
    2022-04-24 06:04:27,582 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 21.075739860534668 seconds
    2022-04-24 06:04:27,583 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-24 06:04:27,585 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-24 06:04:27,605 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-24 06:04:27,615 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-24 06:04:27,623 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-24 06:04:27,624 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-24 06:08:33,552 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingTop.gcode]...
    2022-04-24 06:08:33,619 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingTop.gcode in text mode
    2022-04-24 06:08:33,713 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.06874561309814453 seconds
    2022-04-24 06:08:34,890 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-24 06:08:37,683 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PreviewStage
    2022-04-24 06:08:37,692 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    This behavior is deprecated.
    You have to import QtQml 2.15 after any QtQuick imports and set
    the restoreMode of the binding to fix this warning.
    In Qt < 6.0 the default is Binding.RestoreBinding.
    In Qt >= 6.0 the default is Binding.RestoreBindingOrValue.
    2022-04-24 06:08:37,721 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SimulationView
    2022-04-24 06:08:37,767 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [74]: Processing new layer for build plate 0...
    2022-04-24 06:08:38,314 - DEBUG - [JobQueueWorker [1]] CuraEngineBackend.ProcessSlicedLayersJob.run [254]: Processing layers took 0.5475149154663086 seconds
    2022-04-24 06:08:38,610 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [996]: See if there is more to slice(2)...
    2022-04-24 06:08:46,221 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2022-04-24 06:08:46,231 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2022-04-24 06:08:46,243 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/PrintSetupSelector/Custom/QualitiesWithIntentMenu.qml:168:25: QML Binding: Not restoring previous value because restoreMode has not been set.
    2022-04-24 06:08:46,300 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2022-04-24 06:08:46,583 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\xray.shader]...
    2022-04-24 06:08:48,745 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000024D2EA12610>, took 12ms
    2022-04-24 06:08:48,950 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-24 06:08:48,957 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-24 06:08:48,966 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-24 06:08:48,974 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-24 06:08:49,688 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-24 06:08:56,762 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.039058685302734375 seconds
    2022-04-24 06:09:01,010 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/MODELS/Earring stand for Krystina/EarRingTube.stl
    2022-04-24 06:09:01,020 - INFO - [JobQueueWorker [2]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:09:01,048 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.0019953250885009766 seconds
    2022-04-24 06:09:01,050 - DEBUG - [JobQueueWorker [2]] STLReader.STLReader._read [105]: Loaded a mesh with 37512 vertices
    2022-04-24 06:09:01,174 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.1171269416809082 seconds. 2756 input vertices. 2756 output vertices.
    2022-04-24 06:09:01,199 - DEBUG - [JobQueueWorker [2]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.2 seconds
    2022-04-24 06:09:01,313 - DEBUG - [JobQueueWorker [2]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.108062744140625 seconds. 2756 input vertices. 2756 output vertices.
    2022-04-24 06:09:01,337 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000024D2EB05D60>, took 3ms
    2022-04-24 06:09:01,386 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'EarRingTube.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'EarRingTube.stl'>,trans.=<0.000,0.000,0.000>), took 5ms
    2022-04-24 06:09:01,989 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:01,998 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:02,005 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:06,067 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend._createSnapshot [269]: Creating thumbnail image (just before slice)...
    2022-04-24 06:09:06,075 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2022-04-24 06:09:06,083 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\overhang.shader]...
    2022-04-24 06:09:06,104 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\transparent_object.shader]...
    2022-04-24 06:09:06,119 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [60]: Loading [C:\Program Files\Ultimaker Cura 4.13.1\resources\shaders\striped.shader]...
    2022-04-24 06:09:06,504 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [284]: Starting to slice...
    2022-04-24 06:09:06,505 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [303]: Going to slice build plate [0]!
    2022-04-24 06:09:06,513 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [231]: Previous socket existed. Closing that first.
    2022-04-24 06:09:06,563 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Listening
    2022-04-24 06:09:06,638 - INFO - [MainThread] UM.Backend.Backend.startEngine [90]: Started engine process: C:\Program Files\Ultimaker Cura 4.13.1\CuraEngine.exe
    2022-04-24 06:09:06,678 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [110]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.13.1\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2022-04-24 06:09:06,853 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:09:06,871 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Cura_SteamEngine version 4.13.1
    2022-04-24 06:09:06,872 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [192]: Socket state changed to Connected
    2022-04-24 06:09:06,884 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] Copyright (C) 2021 Ultimaker
    2022-04-24 06:09:06,893 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:09:06,903 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is free software: you can redistribute it and/or modify
    2022-04-24 06:09:06,907 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [181]: Backend connected on port 49674
    2022-04-24 06:09:06,909 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2022-04-24 06:09:06,918 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2022-04-24 06:09:06,928 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] (at your option) any later version.
    2022-04-24 06:09:06,935 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:09:06,940 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] This program is distributed in the hope that it will be useful,
    2022-04-24 06:09:06,945 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2022-04-24 06:09:06,948 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2022-04-24 06:09:06,953 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] GNU Affero General Public License for more details.
    2022-04-24 06:09:06,958 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:09:06,963 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] You should have received a copy of the GNU Affero General Public License
    2022-04-24 06:09:06,967 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2022-04-24 06:09:06,976 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [510]: Sending slice message took 0.47127389907836914 seconds
    2022-04-24 06:09:07,128 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] [WARNING]  -s initial_extruder_nr="0" -s day="Sun" -s time="06:09:06" -s print_bed_temperature="60" -s material_name="empty" -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s draft_shield_height="10" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s wireframe_printspeed_bottom="5" -s wall_min_flow="0" -s wireframe_fall_down="0.5" -s material_adhesion_tendency="10" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s speed_slowdown_layers="2" -s prime_tower_flow="100" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s wireframe_drag_along="0.6" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s machine_always_write_active_tool="False" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s support_extruder_nr="0" -s acceleration_support="500" -s raft_margin="15" -s infill_mesh="False" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s support_roof_extruder_nr="0" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s material_bed_temp_prepend="True" -s machine_buildplate_type="glass" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s machine_max_jerk_e="5" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s machine_max_feedrate_z="10" -s material_initial_print_temperature="210" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s wireframe_roof_fall_down="2" -s alternate_carve_order="True" -s top_bottom_thickness="0.8" -s draft_shield_enabled="False" -s adaptive_layer_height_enabled="False" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s jerk_travel="8" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s support_enable="True" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s machine_height="250" -s machine_max_acceleration_e="5000" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2022-04-24 06:09:07,136 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:09:07,145 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G28 ; Home all axes
    2022-04-24 06:09:07,161 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:09:07,176 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2022-04-24 06:09:07,176 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2022-04-24 06:09:07,184 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2022-04-24 06:09:07,195 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2022-04-24 06:09:07,203 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G92 E0 ; Reset Extruder
    2022-04-24 06:09:07,212 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2022-04-24 06:09:07,215 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s ooze_shield_angle="60" -s machine_extruders_share_nozzle="False" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s acceleration_infill="500" -s machine_max_jerk_xy="10" -s support_bottom_stair_step_min_slope="10.0" -s magic_fuzzy_skin_thickness="0.3" -s retraction_combing="noskin" -s layer_height="0.2" -s wipe_retraction_amount="6.5" -s prime_tower_position_x="208.6" -s support_meshes_present="False" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s draft_shield_height_limitation="full" -s infill_extruder_nr="-1" -s jerk_support="8" -s raft_surface_layers="2" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="False" -s travel_compensate_overlapping_walls_x_enabled="True" -s roofing_layer_count="0" -s retraction_min_travel="1.5" -s date="24-04-2022" -s machine_heat_zone_length="16" -s blackmagic="0" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s bridge_wall_material_flow="50" -s raft_interface_fan_speed="0" -s skin_outline_count="1" -s acceleration_topbottom="500" -s travel_compensate_overlapping_walls_enabled="True" -s jerk_wall_x="8" -s default_material_bed_temperature="60" -s support_interface_material_flow="100" -s small_feature_speed_factor="50" -s z_seam_relative="False" -s skin_monotonic="False" -s xy_offset="0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s machine_minimum_feedrate="0.0" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s machine_depth="220" -s prime_tower_size="20" -s machine_settings="0" -s machine_max_acceleration_x="500" -s infill_offset_x="0" -s jerk_wall="8" -s support_bottom_offset="0.0" -s lightning_infill_prune_angle="40" -s speed_support_infill="25.0" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s switch_extruder_prime_speed="20" -s expand_skins_expand_distance="0.8" -s material="0" -s support_line_width="0.4" -s infill_offset_y="0" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s fill_outline_gaps="False" -s material_print_temperature="210" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s bridge_fan_speed_2="0" -s wireframe_strategy="compensate" -s machine_width="220" -s acceleration_travel_layer_0="500" -s lightning_infill_straightening_angle="40" -s support_supported_skin_fan_speed="100" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s wireframe_straight_before_down="20" -s infill_overlap="30.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s acceleration_support_infill="500" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s retraction_hop_only_when_collides="False" -s flow_rate_max_extrusion_offset="0" -s raft_base_fan_speed="0" -s machine_disallowed_areas="[]" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s outer_inset_first="False" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.025" -s support_roof_density="33.333" -s material_standby_temperature="150" -s material_flow_layer_0="100" -s wall_0_extruder_nr="-1" -s raft_surface_jerk="8" -s speed_z_hop="5" -s material_no_load_move_factor="0.940860215" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s infill_multiplier="1" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_mesh="False" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s support_join_distance="2.0" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s cool_fan_speed_max="100.0" -s roofing_extruder_nr="-1" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s machine_max_feedrate_x="500" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s extruder_prime_pos_abs="False" -s material_guid="" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s raft_base_jerk="8" -s skirt_brim_material_flow="100" -s material_shrinkage_percentage="100.0" -s wipe_move_distance="20" -s skin_line_width="0.4" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s wireframe_printspeed_flat="5" -s machine_heated_build_volume="False" -s ironing_pattern="zigzag" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s retraction_retract_speed="25" -s slicing_tolerance="middle" -s machine_steps_per_mm_x="50" -s material_flush_purge_length="60" -s wireframe_flow_connection="100" -s acceleration_wall_0="500" -s mold_angle="40" -s support_tower_maximum_supported_diameter="3.0" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s retract_at_layer_change="False" -s default_material_print_temperature="210" -s line_width="0.4" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_wall="25.0" -s coasting_speed="90" -s material_bed_temperature_layer_0="60" -s infill_pattern="cubic" -s retraction_extra_prime_amount="0" -s print_temperature="210" -s bridge_sparse_infill_max_density="0" -s resolution="0" -s prime_tower_position_y="186.6" -s wireframe_nozzle_clearance="1" -s minimum_roof_area="10" -s jerk_support_bottom="8" -s raft_speed="25.0" -s support_roof_pattern="grid" -s adaptive_layer_height_threshold="0.2" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s machine_max_acceleration_y="500" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s bridge_settings_enabled="False" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s machine_extruders_share_heater="False" -s support_skip_zag_per_mm="20" -s shell="0" -s travel_avoid_supports="True" -s jerk_enabled="False" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s support_type="everywhere" -s wireframe_printspeed_down="5" -s support_zag_skip_count="2" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s cool_fan_speed_0="0" -s command_line_settings="0" -s acceleration_support_bottom="500" -s jerk_print="8" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s material_bed_temperature="60" -s support_interface_skip_height="0.2" -s gantry_height="25" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s zig_zaggify_support="False" -s machine_end_gcode="G91 ;Relative positioning
    2022-04-24 06:09:07,227 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 F2700 ;Retract a bit
    2022-04-24 06:09:07,227 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2022-04-24 06:09:07,235 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2022-04-24 06:09:07,242 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 Z10 ;Raise Z more
    2022-04-24 06:09:07,251 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G90 ;Absolute positioning
    2022-04-24 06:09:07,261 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] G1 X0 Y220 ;Present print
    2022-04-24 06:09:07,269 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M106 S0 ;Turn-off fan
    2022-04-24 06:09:07,275 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M104 S0 ;Turn-off hotend
    2022-04-24 06:09:07,278 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M140 S0 ;Turn-off bed
    2022-04-24 06:09:07,286 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend]
    2022-04-24 06:09:07,286 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] M84 X Y E ;Disable all steppers but Z
    2022-04-24 06:09:07,293 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [110]: [Backend] " -s raft_base_thickness="0.24" -s infill_line_width="0.4" -s support_interface_extruder_nr="0" -s wireframe_bottom_delay="0" -s bottom_layers="4" -s prime_tower_brim_enable="False" -s remove_empty_first_layers="True" -s infill_overlap_mm="0.12" -s support_brim_enable="True" -s layer_start_x="0.0" -s min_infill_area="0" -s support_roof_line_distance="2.4000240002400024" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s wireframe_top_jump="0.6" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s roofing_line_width="0.4" -s adhesion_type="skirt" -s wireframe_flow_flat="100" -s machine_max_acceleration_z="100" -s acceleration_print="500" -s prime_tower_enable="False" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s gradual_infill_steps="0" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s raft_smoothing="5" -s brim_width="8.0" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s ironing_flow="10.0" -s support_initial_layer_line_distance="8.0" -s material_type="empty" -s support_extruder_nr_layer_0="0" -s bridge_enable_more_layers="True" -s top_layers="4" -s speed_support_interface="25.0" -s wall_0_inset="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_skin_expand_distance="0.8" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s material_id="empty_material" -s wireframe_up_half_speed="0.3" -s max_extrusion_before_wipe="10" -s travel="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wireframe_top_delay="0" -s machine_name="Creality Ender-3 Pro" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s top_skin_preshrink="0.8" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.25" -s wall_thickness="0.8" -s acceleration_enabled="False" -s z_seam_type="back" -s retraction_prime_speed="25" -s support_xy_overrides_z="xy_overrides_z" -s speed_wall_0="25.0" -s meshfix="0" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_roof_height="0.8" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s material_brand="" -s wireframe_roof_outer_delay="0.2" -s speed_support_bottom="25.0" -s machine_show_variants="False" -s wall_min_flow_retract="False" -s jerk_infill="8" -s small_feature_max_length="0.0" -s minimum_polygon_circumference="1.0" -s lightning_infill_support_angle="40" -s center_object="False" -s material_break_preparation_retracted_position="-16" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s support_offset="0" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s acceleration_skirt_brim="500" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s retraction_hop_after_extruder_switch_height="0.2" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s wall_0_wipe_dist="0.0" -s travel_retract_before_outer_wall="True" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s support_brim_width="4" -s support_interface_enable="True" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s support_top_distance="0.2" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s infill_support_angle="40" -s machine_firmware_retract="False" -s z_seam_y="220" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s adaptive_layer_height_variation_step="0.04" -s machine_nozzle_cool_down_speed="2.0" -s support_interface_density="33.333" -s raft_acceleration="500" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s infill_mesh_order="0" -s machine_min_cool_heat_time_window="50.0" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s machine_shape="rectangular" -s hole_xy_offset="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s layer_height_0="0.2" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s machine_extruder_count="1" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s wireframe_printspeed_up="5" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s raft_interface_jerk="8" -s wireframe_enabled="False" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s cutting_mesh="False" -s wireframe_printspeed="5" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_structure="normal" -s support_bottom_stair_step_width="5.0" -s xy_offset_layer_0="0" -s bridge_wall_speed="12.5" -s meshfix_union_all_remove_holes="False" -s smooth_spiralized_contours="True" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s bridge_skin_speed_3="12.5" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s material_bed_temp_wait="True" -s jerk_ironing="8" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s ooze_shield_enabled="False" -s bridge_fan_speed="100" -s machine_center_is_zero="False" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s skin_angles="[ ]" -s jerk_topbottom="8" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s material_final_print_temperature="210" -s fill_perimeter_gaps="everywhere" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s build_volume_temperature="28" -e0 -s optimize_wall_printing_order="True" -s support_angle="45" -s material_crystallinity="False" -s machine_steps_per_mm_e="1600" -s wall_overhang_angle="90" -s support_brim_line_count="10" -s gradual_support_infill_steps="0" -s z_seam_x="110.0" -s infill_support_angle="40" -s support_roof_offset="0.0" -s raft_surface_thickness="0.2" -s material_break_preparation_speed="2" -s material_extrusion_cool_down_speed="0.7" -s wall_min_flow="0" -s material_adhesion_tendency="0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s prime_blob_enable="False" -s bridge_skin_material_flow_3="110" -s support_conical_enabled="False" -s prime_tower_flow="100" -s raft_margin="15" -s roofing_pattern="lines" -s speed_travel="150.0" -s small_hole_max_size="0" -s ironing_enabled="False" -s speed_wall_x="25.0" -s jerk_wall_0="8" -s infill_support_enabled="False" -s infill_wall_line_count="0" -s raft_base_line_spacing="1.6" -s cool_min_layer_time_fan_speed_max="10" -s connect_infill_polygons="False" -s support_tree_angle="40" -s acceleration_support="500" -s raft_jerk="8" -s wall_line_count="2" -s minimum_support_area="2" -s roofing_material_flow="100" -s skin_overlap_mm="0.04" -s ironing_line_spacing="0.1" -s material_flow_dependent_temperature="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s machine_nozzle_temp_enabled="True" -s top_thickness="0.8" -s minimum_bottom_area="10" -s meshfix_keep_open_polygons="False" -s raft_interface_thickness="0.30000000000000004" -s support_xy_distance_overhang="0.4" -s wall_line_width="0.4" -s acceleration_travel="500" -s material_break_temperature="50" -s coasting_volume="0.064" -s support_bottom_line_distance="2.4000240002400024" -s material_initial_print_temperature="200" -s bottom_thickness="0.8" -s raft_interface_line_spacing="1.0" -s infill="0" -s speed_ironing="16.666666666666668" -s support_interface_height="0.8" -s machine_endstop_positive_direction_z="True" -s skirt_brim_minimal_length="250" -s extruder_nr="0" -s top_bottom_thickness="0.8" -s roofing_line_width="0.4" -s travel_avoid_other_parts="True" -s support_wall_count="1" -s mold_enabled="False" -s support_bottom_material_flow="100" -s cool_fan_speed_min="100.0" -s support_roof_enable="True" -s wipe_hop_amount="0.2" -s brim_outside_only="True" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s support_roof_material_flow="100" -s support_bottom_enable="True" -s prime_tower_min_volume="6" -s support_pattern="zigzag" -s speed_roofing="25.0" -s skin_no_small_gaps_heuristic="False" -s machine_nozzle_size="0.4" -s initial_layer_line_width_factor="100.0" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s machine_extruder_end_pos_x="0" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s support_top_distance="0.2" -s wall_line_width_x="0.4" -s platform_adhesion="0" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s retraction_hop_after_extruder_switch_height="0.2" -s support_offset="0" -s bridge_fan_speed_2="0" -s support_initial_layer_line_distance="8.0" -s ironing_flow="10.0" -s skirt_brim_material_flow="100" -s support_roof_density="33.333" -s material_standby_temperature="175" -s material_flow_layer_0="100" -s speed_wall_0="25.0" -s meshfix="0" -s support_xy_overrides_z="xy_overrides_z" -s small_feature_max_length="0.0" -s lightning_infill_support_angle="40" -s support_brim_width="4" -s support_interface_enable="True" -s material_break_preparation_retracted_position="-16" -s center_object="False" -s raft_surface_speed="25.0" -s bridge_skin_density_2="75" -s infill_overlap="30.0" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s retraction_speed="25" -s meshfix_maximum_travel_resolution="0.25" -s infill_line_distance="6.0" -s resolution="0" -s material_anti_ooze_retraction_speed="5" -s filter_out_tiny_gaps="False" -s magic_fuzzy_skin_outside_only="False" -s retraction_min_travel="1.5" -s acceleration_support_infill="500" -s retraction_hop_only_when_collides="False" -s machine_extruder_start_pos_y="0" -s bridge_skin_speed_3="12.5" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s acceleration_support_interface="500" -s raft_base_line_width="0.8" -s support_bottom_angles="[ ]" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s infill_material_flow="100" -s conical_overhang_hole_size="0" -s bridge_skin_density="100" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s meshfix_maximum_deviation="0.025" -s infill_wipe_dist="0.0" -s infill_line_width="0.4" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s retraction_extra_prime_amount="0" -s outer_inset_first="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s ironing_inset="0.38" -s skin_preshrink="0.8" -s acceleration_skirt_brim="500" -s meshfix_extensive_stitching="False" -s raft_interface_line_width="0.8" -s infill_multiplier="1" -s machine_settings="0" -s minimum_interface_area="10" -s infill_before_walls="False" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s travel_compensate_overlapping_walls_0_enabled="False" -s experimental="0" -s support_interface_offset="0.0" -s support_tree_branch_diameter_angle="5" -s travel_compensate_overlapping_walls_enabled="True" -s support_join_distance="2.0" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s jerk_skirt_brim="8" -s material_no_load_move_factor="0.940860215" -s support_infill_rate="5" -s speed_equalize_flow_enabled="False" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_roof_height="0.8" -s extruder_prime_pos_abs="False" -s acceleration_travel_layer_0="500" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s material_surface_energy="100" -s raft_base_speed="18.75" -s brim_gap="0" -s infill_sparse_density="20" -s retraction_enable="True" -s blackmagic="0" -s speed_support_interface="25.0" -s wall_0_inset="0" -s top_layers="4" -s material_break_speed="25" -s speed_travel_layer_0="100.0" -s minimum_roof_area="10" -s jerk_support_infill="8" -s support_use_towers="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s bridge_fan_speed="100" -s brim_width="8.0" -s bottom_layers="4" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s shell="0" -s travel_avoid_supports="True" -s jerk_support_bottom="8" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s support_roof_pattern="grid" -s jerk_prime_tower="8" -s conical_overhang_enabled="False" -s ironing_pattern="zigzag" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s retraction_retract_speed="25" -s layer_start_x="0.0" -s support_brim_enable="True" -s min_infill_area="0" -s bridge_sparse_infill_max_density="0" -s jerk_travel_layer_0="8" -s speed_infill="50.0" -s acceleration_ironing="500" -s jerk_print_layer_0="8" -s travel_compensate_overlapping_walls_x_enabled="True" -s wall_0_wipe_dist="0.0" -s skin_monotonic="False" -s top_skin_preshrink="0.8" -s bridge_skin_support_threshold="50" -s retraction_combing_max_distance="30" -s machine_endstop_positive_direction_x="False" -s skin_material_flow="100" -s retraction_count_max="100" -s support_tower_roof_angle="65" -s support_line_distance="8.0" -s speed_print_layer_0="20.0" -s support="0" -s skin_edge_support_layers="0" -s raft_base_jerk="8" -s wall_line_width_0="0.4" -s raft_interface_speed="18.75" -s wall_x_material_flow="100" -s support_interface_line_width="0.4" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s lightning_infill_overhang_angle="40" -s support_bottom_line_width="0.4" -s meshfix_union_all="True" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s support_roof_line_distance="2.4000240002400024" -s default_material_print_temperature="200" -s speed_equalize_flow_max="150" -s roofing_layer_count="0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s gradual_support_infill_step_height="1" -s wipe_retraction_retract_speed="25" -s support_tree_collision_resolution="0.2" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s raft_smoothing="5" -s wall_overhang_speed_factor="100" -s raft_base_acceleration="500" -s acceleration_print="500" -s gradual_infill_steps="0" -s layer_start_y="0.0" -s prime_tower_wipe_enabled="True" -s cool_fan_speed_0="0" -s bridge_enable_more_layers="True" -s retract_at_layer_change="False" -s extruder_prime_pos_y="0" -s jerk_support_roof="8" -s zig_zaggify_infill="False" -s skirt_line_count="3" -s acceleration_infill="500" -s sub_div_rad_add="0.4" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="6.5" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s wipe_pause="0" -s machine_extruders_shared_nozzle_initial_retraction="0" -s acceleration_support_roof="500" -s wall_thickness="0.8" -s z_seam_type="back" -s retraction_prime_speed="25" -s speed_wall="25.0" -s coasting_speed="90" -s machine_nozzle_head_distance="3" -s skirt_brim_line_width="0.4" -s speed_support_bottom="25.0" -s acceleration_support_bottom="500" -s jerk_print="8" -s command_line_settings="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s mold_angle="40" -s machine_extruder_end_pos_abs="False" -s jerk_infill="8" -s wall_min_flow_retract="False" -s cross_infill_density_image="" -s cool_lift_head="False" -s speed_print="50.0" -s brim_replaces_support="False" -s z_seam_position="back" -s speed="0" -s infill_pattern="cubic" -s skin_line_width="0.4" -s wipe_move_distance="20" -s support_tower_maximum_supported_diameter="3.0" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s line_width="0.4" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s retraction_extrusion_window="10" -s material_flow="100" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s mold_roof_height="0.5" -s raft_surface_line_width="0.4" -s slicing_tolerance="middle" -s skirt_gap="10.0" -s support_zag_skip_count="2" -s machine_steps_per_mm_x="50" -s acceleration_wall_0="500" -s switch_extruder_prime_speed="20" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s machine_nozzle_cool_down_speed="2.0" -s raft_acceleration="500" -s support_interface_density="33.333" -s machine_nozzle_offset_x="0" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s hole_xy_offset="0" -s skirt_brim_speed="20.0" -s jerk_layer_0="8" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s max_extrusion_before_wipe="10" -s travel="0" -s small_feature_speed_factor="50" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s bridge_fan_speed_3="0" -s lightning_infill_prune_angle="40" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s mesh_position_y="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s switch_extruder_extra_prime_amount="0" -s support_tree_branch_distance="1" -s speed_topbottom="25.0" -s support_roof_line_width="0.4" -s alternate_extra_perimeter="False" -s raft_interface_jerk="8" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s bridge_skin_speed_2="12.5" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s infill_overlap_mm="0.12" -s material_flush_purge_speed="0.5" -s ironing_monotonic="False" -s top_bottom="0" -s machine_extruder_start_pos_abs="False" -s machine_extruder_start_code="" -s z_seam_y="220" -s jerk_ironing="8" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s raft_surface_fan_speed="0" -s roofing_monotonic="False" -s bottom_skin_preshrink="0.8" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s wall_material_flow="100" -s mold_width="5" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s machine_steps_per_mm_z="50" -s cooling="0" -s dual="0" -s retraction_hop="0.2" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s jerk_topbottom="8" -s wipe_brush_pos_x="100" -s jerk_roofing="8" -s bridge_skin_speed="12.5" -s raft_surface_acceleration="500" -s meshfix_maximum_resolution="0.25" -s material_final_print_temperature="200" -s fill_perimeter_gaps="everywhere" -s retraction_amount="6.5" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s wipe_hop_speed="5" -s prime_tower_line_width="0.4" -s xy_offset="0" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s support_bottom_stair_step_height="0.3" -s infill_offset_y="0" -s expand_skins_expand_distance="0.8" -s material="0" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s support_line_width="0.4" -s support_bottom_offset="0.0" -s infill_offset_x="0" -s jerk_wall="8" -s z_seam_relative="False" -s infill_enable_travel_optimization="False" -s cool_fan_full_layer="4" -s jerk_wall_x="8" -s support_interface_material_flow="100" -s skin_outline_count="1" -s acceleration_topbottom="500" -s bridge_wall_material_flow="50" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s speed_layer_0="20.0" -s top_skin_expand_distance="0.8" -s machine_heat_zone_length="16" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s magic_fuzzy_skin_enabled="False" -s raft_surface_layers="2" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s machine_endstop_positive_direction_y="False" -s bridge_skin_material_flow_2="100" -s jerk_support="8" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s support_supported_skin_fan_speed="100" -s lightning_infill_straightening_angle="40" -s magic_fuzzy_skin_thickness="0.3" -s support_bottom_stair_step_min_slope="10.0" -g -e0 -l "0" -s extruder_nr="0"
    2022-04-24 06:09:11,449 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.046390533447265625 seconds
    2022-04-24 06:09:15,181 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [764]: Slicing took 8.67620062828064 seconds
    2022-04-24 06:09:15,182 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [765]: Number of models per buildplate: {0: 1}
    2022-04-24 06:09:15,183 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [779]: See if there is more to slice...
    2022-04-24 06:09:15,190 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [196]: Socket state changed to Closing
    2022-04-24 06:09:15,198 - DEBUG - [MainThread] UM.Backend.Backend._onSocketError [220]: Socket debug: Arcus Error (13): Closing socket because other side requested close.
    2022-04-24 06:09:15,205 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [198]: Socket state changed to Closed
    2022-04-24 06:09:15,206 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [959]: Backend finished slicing. Resetting process and socket.
    2022-04-24 06:09:20,034 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [136]: Writing to [C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingTube.gcode]...
    2022-04-24 06:09:20,045 - DEBUG - [MainThread] LocalFileOutputDevice.LocalFileOutputDevice.requestWrite [156]: Writing to Local File C:/Users/Ben360/3D Objects/OUTPUT/CE3PRO_EarRingTube.gcode in text mode
    2022-04-24 06:09:20,183 - DEBUG - [JobQueueWorker [0]] UM.FileHandler.WriteFileJob.run [80]: Writing file took 0.10713887214660645 seconds
    2022-04-24 06:09:20,724 - INFO - [MainThread] SliceInfoPlugin.SliceInfo._onRequestFinished [294]: SliceInfo sent successfully
    2022-04-24 06:09:24,458 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000024D4102F1F0>, took 16ms
    2022-04-24 06:09:25,067 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-24 06:09:25,080 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-24 06:09:25,095 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-24 06:09:25,111 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-24 06:09:25,341 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-24 06:09:30,528 - INFO - [MainThread] cura.CuraApplication.readLocalFile [1770]: Attempting to read file file:///C:/Users/Ben360/3D Objects/MODELS/Earring stand for Krystina/EarRingTube70.stl
    2022-04-24 06:09:30,539 - INFO - [JobQueueWorker [1]] STLReader.STLReader.load_file [53]: Using NumPy-STL to load STL data.
    2022-04-24 06:09:30,559 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.calculateNormalsFromVertices [558]: Calculating normals took 0.001993417739868164 seconds
    2022-04-24 06:09:30,561 - DEBUG - [JobQueueWorker [1]] STLReader.STLReader._read [105]: Loaded a mesh with 37512 vertices
    2022-04-24 06:09:30,677 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.10644698143005371 seconds. 2756 input vertices. 2756 output vertices.
    2022-04-24 06:09:30,693 - DEBUG - [JobQueueWorker [1]] UM.FileHandler.ReadFileJob.run [83]: Loading file took 0.2 seconds
    2022-04-24 06:09:30,791 - DEBUG - [JobQueueWorker [1]] UM.Mesh.MeshData.approximateConvexHull [505]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.08879804611206055 seconds. 2756 input vertices. 2756 output vertices.
    2022-04-24 06:09:30,813 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x0000024D4105CA60>, took 3ms
    2022-04-24 06:09:30,852 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=2) RotateOp.(node=<CuraSceneNode object: 'EarRingTube70.stl'>,rot.=Q<0.0,0.0,0.0,w=4.0>) TranslateOp.(node=<CuraSceneNode object: 'EarRingTube70.stl'>,trans.=<0.000,0.000,0.000>), took 2ms
    2022-04-24 06:09:31,109 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:31,121 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:31,132 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectItemButton.qml:79:9: QML Button: Binding loop detected for property "width"
    2022-04-24 06:09:37,250 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: GroupedOp.(#=1) <UM.Operations.RemoveSceneNodeOperation.RemoveSceneNodeOperation object at 0x0000024D36D61EE0>, took 18ms
    2022-04-24 06:09:37,839 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:137:17: Unable to assign [undefined] to int
    2022-04-24 06:09:37,854 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:136:17: Unable to assign [undefined] to QString
    2022-04-24 06:09:37,870 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:135:17: Unable to assign [undefined] to int
    2022-04-24 06:09:37,886 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [424]: file:///C:/Program Files/Ultimaker Cura 4.13.1/resources/qml/ObjectSelector.qml:134:17: Unable to assign [undefined] to bool
    2022-04-24 06:09:38,128 - WARNING - [MainThread] cura.UI.PrintInformation.setBaseName [369]: Unsupported Mime Type Database file extension
    2022-04-24 06:09:40,936 - DEBUG - [MainThread] cura.AutoSave._onTimeout [64]: Autosaving preferences, instances and profiles took 0.06980752944946289 seconds
    Posted (edited) · first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
    I would have preferred both files as attachments instead of pasted in a long, unwieldy message.
    Funny, you have almost the exact same computer as I have, only I have double the RAM and an i7 instead of your i5.
    Unfortunately, looking over they logs has not given me any new insights or ideas for things to try.
    Edited by ahoeben
    Posted · first time using Cura, installed 4.13.1 - mouse pointer doesn't align with on screen icons
    sorry, tried attaching the rtf and it wasn't happy. blame that on my inexperience.
    i'm wishing i had your PC right now.
    seriously, thanks for your efforts, they have been genuinely appreciated.
