Profile for Sovol SV04
mich011
Posted · Profile for Sovol SV04
Hello,
Is someone has created the profile for the Sovol SV04 printers (I mean dual, copy and mirror printers). It is the same printer but Sovol on its CURA release has created 3 different printers.
I would like to use the last release of Cura which is not supplied by SOVOL.
Thanks in advance.
Kind regards
Michel
    • 2 months later...
    Posted (edited) · Profile for Sovol SV04
    I didn't made one, but you can easily copy the settings from Sovol's Cura Version (definitons,extruders from Sovol) to the current Cura files. If you are able to navigate trough the folder structure of Cura.
    If you copied all files you can add in Cura a non-network printer., and there you can find your printer under Sovol-3D.
    Edited by RedJoy
