Post Processing Script Management
Keith_Ward
Posted (edited) · Post Processing Script Management
I seem to have a need for a way to manage post processing scripts.  In particular those that are to be used for every print, "public" or "global", and those that are used for specific prints only, "private" or "local".  Right now if I don't want one I have added, my only option is to delete it and create it again when I do and having to write copy these to a file or write them down.  I think adding scripts with each having an option of on/off, and global/local would be very useful.  initially I did not use post processing but I'm using it more and more with increased experience and more specific needs.  Also maybe even saving grouped PP scripts under one name or descriptions.  Have others found a way to do this already and I have just possible missed something?
Edited by Keith_Ward
    Posted · Post Processing Script Management
    One solution could be to add in each of your script this option of enable/disable , you will keep like that the full list of your script. But it will be not very handy because you will need to check every script one by one to know if it is active or not.. No real smart solution , execpt perhaps transform every  script into a plugin.
        • 31 replies
        • 25 replies
