ProfilAnalyser Plugin Question
Dools56
Posted · ProfilAnalyser Plugin Question
I can't figure out how to get the
ProfilAnalyser plugin to work.  I have installed it on both Versions 4 and 5 and can't figure out how to access it.
Saw on the 5axes web site where it said you need to copy the the ProfilAnalyser directory into the plugins directory. But I don't know where to copy that from. And there doesn't appear to be a plugins directory in Version 5.0. so confused!
Any help would be greatly appreciated!
    I did install it several times from the Marketplace  (for both version 4 and 5) the other day but it didn't show up under extensions even after restarting Cura several times. Today, it now shows up in Extensions in both versions. Not sure what caused it to start showing up. Thanks for your help.
