Cura stl. models are black silhouettes - Solved
chris24
Posted · Cura stl. models are black silhouettes - Solved
Hi
I am having a problem with Cura. 14.01.
When an stl is loaded it comes up as a featureless black silhouette, when in normal view. I have tried changing the model colour in preferences, which was set as yellow by default. The model just stays black.
I have reinstalled the software but the issue remains.
Any ideas?
Solved by following instructions on this post.
Any color you like, as long as it's black... - solved
Started by DonMilne, Feb 02 2014 01:19 PM
    • 8 years later...
    Posted (edited) · Cura stl. models are black silhouettes - Solved
    On 2/11/2014 at 8:07 PM, chris24 said:
    Solved problem by following instructions on this post.
    Link: http://umforum.ultimaker.com/index.php?/topic/4299-any-color-you-like-as-long-as-its-black-solved/
    well, the link doesn't work anymore. Pretty annoying. Next time just post the solution, for internets sake
    Edited by hansmeier
