were is "ignore small z axis gaps"
imnotdream
  • 8 months later...
Posted · were is "ignore small z axis gaps"
Which slicer do you use?
If you use Cura, the new update changed "ignore small z gaps" to "no skin in z gaps".
To enable the "no skin in z gaps" option, you have to enable expert options.
Of course, if you don't use Cura, then I can't help you.
I hope this helps!
