using cura for Bfb 3D Touch
Ikaru31
Posted · using cura for Bfb 3D Touch
Hey after weeks of try and error i finally got the old Bfb 3d Touch from my University to work with cura. But right now i have to change the gcode everytime i use extruder 2.
The Bfb 3D Touch can work with up to 3 hotends, currently equiped with 2 hotends. So far i got it only to work with 1 extruder at a Time, because f the following issue:
The bfb uses the comand M104 {prin_temperature} for hotend 1 and M204{prin_temperature} for hotend 2. But when cura changes the temperature it uses m104 everytime so only hot end 1 is heating.
My fix is currently to edit the gcode when i use extruder 2 and change every M104 to M204. But when i use both extruder at the same time i can not tell wich m104 has to change and wich not.
Sadly it didnt work to implement the m104/204 in the start gcode of the extruder.
Is there a way that cura uses the right m104/204 depending on wich extruder to use next?
Another minor issue i have is, that the flowrate has to set to 4700% and because of that the lines in the prview are so thick that you can not see whats going on. is there a way that cura does not refere to the flowrate for the line thickness in the preview or another way of setting the flowrate to a correct level?
    If there is someone also trying to use cura on a Bfb 3d Touch here is how i managed it to work:
    create a standard fff-printer in cura
    change start gcode to:
    ^Checksum: NO
    ^Time: 1234
    ^Ex1: PLA White
    ^Ex2: PLA white
    ^Ex3: None
    M227 P3200 S3200
    M105
    M113 S1.0
    change end gcode to:
    M103
    (</nestedRing>)
    ~M104 S0
    M113 S0.0
    Change extruder 1 Start gcode to:
    ;extruder 1
    M106
    M542
    ;start extruder 1 extruding
    M107
    M104 S{material_print_temperature_layer_0}
    M106
    M551 P57600 S600;priming p-extrudingmass s-speedofextrusion
    M543
    M101
    Change extruder 1 end gcode to:
    M103
    Change extruder 2 Start gcode to:
    ;extruder 2
    M542
    M107
    M204 S{material_print_temperature_layer_0}
    M106
    M552 P57600 S600;priming p-extrudingmass s-speedofextrusion
    M543
    M201
    Change extruder 2 end gcode to:
    M103
    Printer settings:
    x 395.0
    y285.0
    z201.0
    origin at center
    gcode Flavour
    Bits from bites
    Nozzeloffset x extruder 2 50mm
    Print settings custom expert:
    flowrate to arround 4700
    uncheck infill bevore wall
    Buildplate adhesion :none (Change in flowrate strangly does not apply here so its not extruding the raft until you change it manually)
    slice your stl and save gcode
    open the stl with notpad or simillar
    open an .bfb made with axon and delete everything
    Copie the gcode from cura in the .bfb file and save. This is necessary to avoid an file read error, may be possible to do otherwise.
    At the printer  settings of the bfb you have to uncheck the chek file before printing
