Cura' xyz home origin
PeterT08
Posted · Cura' xyz home origin
Goog morning everyone. After many questions and trying to figure out how to explaining what is going with my cura I think I figured it out. I just not sure how to fix it hopefully someone here will have a simple fill. Ok here we go this is the best way to e plain this. I open my cura 5.0 and I'm running windows 11, so when you open cura it has its own xyz origin on bottom left corner of work area ok. So now I go and bring in my model and as I always do I scale my model and rotate it and it changes the scale but now I know why the scale is changing. The scale is changing because even though I rotate my model no matter what degree cura is scaling the model to the xyz origin in the left bottom corner of cura's original work area and not of the actual model how can we fix that. I hope that explains the problem much better.
        • 56 replies
        • 30 replies
