Support On/off check box
Johnmgg
Posted · Support On/off check box
Hi I am using Cura 5.0. also CURA 5.0 Keeps crashing. Why does my profile in cura 5.0 Sometimes show the Check box to enable support and then it disappears. I am using the manual support plugin. Some of my profiles were from Cura 4.x. I tried one of my profiles and at first it showed the check box to enable support like it should. Then I saved profile setting and now it does not show the check box. This might be intelligent enough to know I am using Custom Supports. Maybe that is the reason. I know that some of the support feature are still active when you use a custom support, like a BRIM. But very confusing. Can someone explain? I spend so much time searching for the Enable check box that I am pulling my hair out. I wish it would just remain in profile settings instead of Appearing and disappearing.
        • 56 replies
        • 29 replies
