GregValiant 1,364
I'll start on the "Rotation Device" design. The potential market for these could be huge.
Will you need the "right hand" configuration? (Only having two end-point stops would make it simpler.)
Also, how do you want the rotation mechanism powered? I'm thinking Diesel but a Flux Capacitor might work.
GregValiant 1,364
"Buy a bigger screen ? ". Not necessary. I have come up with a workaround.
That would work until some random contributor adds another 8 or 9 plugins and you run out of room again.
Â
Cuq 206
You're a GENIUS @GregValiant. On top Of that it also partialy solved the issue of too long parameter list !! Thanks a lot It will become my new prefered Cura configuration !
