GregValiant 1,351
If the model isn't solid through-and-through then spiralize will print the outer wall that is facing outwards, and the outer wall that is facing inwards. That is not what you are looking for but Cura is trying to print the model you have open.
You can enable the Mesh Fixes setting "Remove All Holes" to make the model solid so it has a single exterior surface. That will allow spiralize to work.
There have also been complaints about the bottom layer pattern in Spiralize. There is only one option now and it is "concentric". There has been a bug report opened on GitHub regarding that.
- 1
stampydriver 0
In addition since 5.x the spiralize feature seems to generate a double wall when it should just be sprializing the outer wall.
