Axis issues
PeterT08
Hi how is everyone. Ok I konw everyone thinks this is a repeat of a prior issue but the issue was never really answered. So I hope someone will actually be able to help me. Ok I do alot of 3d printing with cura, flash print prusa and superslicer to name a few. Here is my issue these past few months and I dont know why this happened in both cura and flash print I can no longer use then becuse when I go to rotate my print it changes my scale on all axis. I tried putting blockers that doesnt work. I know its a world and local space thing because I use prusa and and super slicer and I have no issue cause they give you the option to change the model over into a local space allowing the model to rotate and scale properly please I just want a fix so I can use cura and flash print again please anyone.
Thank You'
Peter
