I have a Mega S which uses Marlin firmware. When you use the Pause at Height script it inserts an M0 command at the height/layer you selected. The M0 command has several flags, P is the delay time in milliseconds, S is the delay time in seconds. Edit your gcode file an search for the M0 command and insert your choice of flags. I use S typically, S120 will give you 2 minutes to insert nuts, magnets, or whatever in to your print.
- 1
MariMakes 203
Hey @constantine42,
Welcome to the Ultimaker Community 🎉
Unfortunetly I do not have a Kobra Max Printer so I cannot help you there. Let's hope that there is someone in the community that can help you out.
I did notice that the type of post processing script you use matter on different printers.
If you are stuck I reccommend experimenting with the different settings here until you find some that work for you.
Good luck!
