Cura 5.1 not slice
iceb09
Posted · Cura 5.1 not slice
Hey @iceb09,
I tried to slice your file and it works for me on Windows 10, Cura 5.1 🤔
Can you tell me more about the operating system that you are on?
Have you had successful slices before?
Could your Temp File have Non-Latin Characters like Russian or Chinese?
A work around could be to change your path of the temp folder:
  • Search for environment variables in the windows search bar.
  • This will open system properties and there you can click on Environment Variables.
  • Edit the TEMP variable.
  • Change the Variable value to something like C:\Temp
Here you can read more about modify environment variables: https://docs.oracle.com/en/database/oracle/machine-learning/oml4r/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0
Posted (edited) · Cura 5.1 not slice
I use cura for a month, everything was fine. But yesterday stopped slicing. Path contains only latin letters C\program files\Ultimaker Cura 5.1.1, path stl file C\.stl
and when I delete all cura files from my computer and reinstall them,cura makes 2-3 slice and stops working again
Edited by iceb09
