Ultimaker 2+ in Buffalo, NY
Posted · Ultimaker 2+ in Buffalo, NY
For sale is an Ultimaker 2+ 3D printer. This machine was acquired from a makerspace at a local school where it saw light use. I bought it with the intention to use it for my printing shop but instead I've decided to sell it to downsize my collection. Parts were replaced as needed to bring it back to a like new condition.
Maintenance Performed:
  • Interior and Exterior of Printer Cleaned.
  • Check for play on axles
  • Axles calibrated and adjusted for squareness
  • All smooth rods lubricated with light machine oil
  • Lead screw for Z motor lubricated with Magnalube
  • Short belts checked and tensioned
  • Long belts tension checked
  • Feeder disassembled, cleaned and rebuilt
Parts Replaced:
  • Bowden Tube
  • PT100B Temperature Sensor
  • Olsson Block
  • TFM Coupler
  • Build Plate Clamps
  • Hot End Cooling Fan
  • Printhead Linear Bearings
  • Rear frame panel
The printer will be bundled with all the items that you would receive as if it was purchased new from Ultimaker. Which includes the following:
  • 220W Power Supply
  • Nozzle pack with 0.25mm, 0.4mm, 0.6mm and 0.8mm nozzles
  • USB A Cable (for updating firmware or printing over USB)
  • SD Card preloaded with gcode and STL files
  • 2mm hex key, 7mm wrench and Philips screwdriver
  • Printhead calibration tool
  • 750g spool of Fillamentum 2.85mm filament
  • stock clip-in spoolholder
  • will also include a low friction spoolholder for better performance
Asking $1400. Available for shipping to the USA (buyer pays) or for local pickup near Buffalo NY. Open to offers.
    • 2 weeks later...
