Unable to slice... help
rafeiro
Posted · Unable to slice... help
someone can help me? when i try slice i have this message:
Unable to slice
Please review settings and check if your models:
- Fit within the build volume
- Are assigned to an enabled extruder
- Are not all set as modifier meshes
My cura version is 5.2.0, what do i need to do to solve this problem?
Thanks.
