Cura works in mm, and the Barbarian plugin does not change that (nor is there any other plugin that does).
If you have a 1" cube, it should become a 25.4mm cube in Cura. The barbarian plugin helps you if the model instead imports as a 1mm cube. Note that a 25.4mm cube is in fact the same ("original") dimensions as a 1" cube, even if its dimensions are shown in mm instead of inches.
ahoeben 1,955
