Many thanks for your information. I have a Trinus printer that worked with Pango software which had a start at height setting. This software is no longer working on my printer but Cura is working perfectly. Below are some examples of prints done
My problem now is how to continue printing after pausing and changing filament. I do not have a control (screen) that says print. I am a newcomer to this and have no coding experience
GregValiant 1,364
Cura has things called Post Processors that can add things or replace things in the final gcode. Two of them are "Pause at Height" and "Filament Change". You can find them at "Extensions / Post Processing / Modify Gcode" and then "Add a Script".
Both can be used to change colors during a print. You could have printed the base, paused at the completion of the last base layer, and then changed filament, and resumed the print with the new color. Supports work when you do it this way. It takes a bit of practice to get it just right but if I were you I'd scrap the base that is there and use Pause at Height.
I could walk you through how to print that second model on the existing base but it's involved and requires very specific slicing of the top model and very specific "one-off" startup gcode. Much easier (and in the long run much better) to cut your losses now and use Pause at Height.
You can do a lot of things with Pause at Height on a single extruder printer. The little camper/sleigh is an assembly with 4 pauses in the body. The coasters were printed with a single gcode file with 4 pauses in it for color changes.
