Raft Generation Bug
maxibarmetler
Posted · Raft Generation Bug
When generating rafts, sometimes some of the layers aren't completely generated. I am using 5.2.1, which is the latest version, and it also happened in previous versions.
This usually can be fixed by changing the raft margin.
Example:
This happens with different shapes that have holes. And always the layer below the top raft layer.
    Hey @maxibarmetler,
    Welcome to the Ultimaker Community 🎉
    Thanks for your report 👍
    This looks like an issue that has already been reported on Github.
    You can read more about it here: https://github.com/Ultimaker/Cura/issues/13696
    Do you have a project file for us? It contains the printer and settings we need for troubleshooting.
    To save a project file go to File -> Save project.
    I can add your example so we have more examples to test when we are trying to resolve this issue.
    • Heart 1
