Is there a good reason the S3/S5 don't have magnetic, flexible build plates?
jasonrohrer
Go to solution Solved by jasonrohrer,
Posted · Is there a good reason the S3/S5 don't have magnetic, flexible build plates?
Just a follow-up, for future seekers.
In the end, I moved from Magigoo to Layerneer Bed Weld, and it really is the best.  I did some testing with both, and Bed Weld both holds firmer during printing, and releases better after things cool down.
So I'm now 100% satisfied with my glass plate.  Bed Weld should ship in the box with the S3.
These days, I can pretty much trust my S3 to print any PLA anything.  Bed Weld on the appropriate area, press print, and come back 15 hours later.  It will be done perfectly.
I only need to use brims on tall parts with very tiny bases.
But for anything with a reasonably large base, no brims or rafts are needed.
