Yes, I came home with the S3. It was that good, despite this one flaw. Print quality and reliability is more important than ease of removal. After all, if it can't print well, there's nothing worth removing from the bed!
I'm only printing PLA with PVA supports. Nylon was just a scare story that I heard from the salesman.
But he demo'd PLA with PVA supports for me in the store (a tiny mushroom print).
And he could BARELY get the thing off the bed.
He knew this was a bad demo of the product, and he was kindof embarrassed about it.
I came home thinking, "I'm definitely going to find a flex bed mod for this thing."
gr5 2,071
No, I don't think that's it. It does active leveling and you can't (well there is a nice hack) turn that off on the S3.
I think the best solution for Nylon on glass on an S3 is magigoo. there is a formulation just for nylon on glass.
So did you come home with the S3 or not? 🙂
If you print Nylon and PVA you should know that you need to keep both of those extremely dry. 25% humidity is too high. Desiccant is usually not good enough (unless you have a lot and you get it down to like 16% which isn't easy with desiccant).
If you print PLA you probably won't mind that you don't have a flex plate.
To answer the flex plate question... I think they will some day. Maybe they'll even have an upgrade for the S3. Or you can buy 3rd party solutions right now (many do).
