Cura 5.2.1 not saving correctly
bmink98
Posted · Cura 5.2.1 not saving correctly
Hello, can someone help with this?
  I just updated to Cura 5.2.1 and my G Code files are not saving correctly.  The file type it saves as is "Text (text/plain)" instead of "Text (text/x.gcode)" even though I select GCode as the file type when saving.  I am using my Linux PC which has always worked well with my old version of Cura.  I've already rebooted my system.  Also, it doesn't matter whether I save to my hard drive or an SD card, I get the same results.  I'm running Linux Mint 19.3 (Tricia).
Thanks
    Hey @bmink98,
    Welcome to the Ultimaker Community 🎉
    Thanks for your report 👍
    This issue reminds me of this report we have on Github about the filename is not populated anymore.
    https://github.com/Ultimaker/Cura/issues/12659
    We've added a ticket to the backlog with the intent to improve this.
