thank you for this illuminating response.
I happened to come across it though only by chance. Somehow I am not receiving emails when responses are in.
Is there a forum setting I have overlooked or is there a known issue with notifications at the moment?
MariMakes 199
Hey @printnewb,
There is a special button for that in Cura!
If you select both models | Right Click | Merge Models.
If you exported your models correctly, which you did, they will remember the position they had in CAD.
If this wouldn't have worked you can doublecheck your preferences.
Preferences | Configure Cura.
There is two boxes to you can uncheck
Hope this helps 😊
